SB Audigy Platinium + Abit KT7A + Bios 64 + WinXP ? ca marche bien ? - Hardware
Marsh Posté le 16-01-2002 à 01:59:40
Bah tu prend un philips acoustic edge et ta la même config ke moi a ce nivo (et un pur son
, ca sort sur les dtt3500 et c du bo)
Marsh Posté le 16-01-2002 à 02:13:26
je veux bien mais je sais pas si ca répondra à mes exigences.
je veux du vrai midi et surtout un rapport s/b de 100db.
elle coute combien la philips ?
(il va falloir qu'on finisse nfs
Marsh Posté le 16-01-2002 à 03:32:28
1300fr la philips acoustic edge, pas de sortie optik mais sortie spdif coaxiale donc ca rulez kan même, sinon c impec:
http://www.pcsound.philips.com/_acoustic706.html pour la fiche du site officiel, pas très détaillée certe, celle la est plus détaillée:
Features:
Music:
Creates 5.1 distinct surround sound channels
Revolutionizes the music listening experience
Movies:
5.1 channel surround from any A/V source
Dolby Digital, QMSS and QSurround DVD playback to 2, 4, or 5.1 speakers*
*Requires compatible soft-DVD player
Games:
2, 4, and 5.1 speaker 3D for every game
Transforms game play into a home theatre experience
Technical Specifications:
Audio Accelerator/Digital Signal Processor:
PHILIPS ThunderBird Avenger ? DSP for extreme hardware acceleration Codec
AC97 CODEC Bus Interface: PCI 2.1 bus master
Industry Specifications:
Exceeds PC98 & PC99 audio requirements
SNR > 92dB typical
Digital Acceleration:
96 streams of 3D audio acceleration including positional reverb
256 streams of DirectSound acceleration and digital mixing
Full-duplex, 48khz digital recording and playback
64 hardware sample rate conversion channels up to 48khz
Wavetable and FM Synthesis
DirectInput devices
Comprehensive Connectivity:
5.1 (6 channel) channel analog output
Digital S/PDIF output (stereo, AC3 or DTS signal)
Digital S/PDIF input
MIDI in/Midi out/dual game port
Additional external inputs: Line in, Mic in
Additional internal inputs: CD in, Aux in, TAD in, S/PDIF in
Special effects can be applied to any audio input including conversion of stereo to quadraphonic or 5.1 output, QXpander, 2D-to-3D remapping and reverb
Music Synthesis:
Up to 576 total wavetable synthesis voices
Reverb and chorus
64 channel hardware CD quality (16 bit, 44.1khz) wavetable synthesizer with 5.9MB sample set
Hardware FM Synthesizer (real mode DOS)
512 voice professional quality soft-synth with XG and GM compatibility
Digital Signal Processor Algorithms:
QSound3DInteractive ? positional 3D for 2 speakers, 4 speakers or 5.1 speakers
QSound Multi Speaker System ? for quadraphonic or 5.1 channel output of stereo music, video and games
QSound Environmental Modeling for EAX ? and DirectSound3D ? games
QXpander ? and ?2D to 3D remapping? for 3D enhancement of stereo playback
QSurround ? virtual 5.1 playback of DVDs using 2 speakers*
* Requires compatible soft-DVD player
pour nfs ouais fodrais un jour mdr, essaye de faire un sezrveur ftp (ftp serv-u par ex
), komm ca y'auras l'auto resume
Marsh Posté le 16-01-2002 à 03:34:41
sinon tout le monde le dit, le son est plus pur ke sur les creatives
Marsh Posté le 16-01-2002 à 11:38:49
92db en rapport s/b c déjà moins bon que les 100db de la creative (meme si c déjà très bon) et puis là il y a une promo à 1000 balles pour la creative. en plus, j'ai besoin d'une sortie optique pour mon md...
donc je pense que la philips ca ira pas
[edtdd]--Message édité par Murphy--[/edtdd]
Marsh Posté le 16-01-2002 à 13:46:08
QUELQun d entre vous a tenté Kt7A + Bios 64
avec ATHLON XP??? ca marche bien?
car il parait que C pas stable
chite question -> ca sert a koi le voltage IO???
avec un V core a fond->1.85 , fo le modifié?
Marsh Posté le 16-01-2002 à 14:13:53
| tekilaz a écrit a écrit : QUELQun d entre vous a tenté Kt7A + Bios 64 avec ATHLON XP??? ca marche bien? car il parait que C pas stable chite question -> ca sert a koi le voltage IO??? avec un V core a fond->1.85 , fo le modifié? |
pas testé mais en principe ca fonctionne très bien
VIO = voltage chipset, ram, CG, etc...
Marsh Posté le 17-01-2002 à 15:41:22
moi c une vieille 1.1
Marsh Posté le 17-01-2002 à 17:57:23
Sur la KT7a j'avais pas de probleme du tout pour l'audigy.
(Pas le même chose pour la KR7A par contre)
Marsh Posté le 17-01-2002 à 17:58:31
ok, donc si je comprends bien, il y a des pb avec la live et pas avec l'audigy, c bien ca ?
Marsh Posté le 18-01-2002 à 09:27:01
| Murphy a écrit a écrit : ok, donc si je comprends bien, il y a des pb avec la live et pas avec l'audigy, c bien ca ? |
quelqu'un confirme ?
Marsh Posté le 16-01-2002 à 01:04:59
j'ai tellement entendu dire que ca déconnait que je ne voudrais pas faire de connerie en achetant cette SB Audigy Platinium.
parce que mon pc marche très bien pour l'instant et j'aimerais que ca continue.
C'est pas moi ! C'est Murphy !
