Micro coupure de son - Matériels & problèmes divers - Hardware
Marsh Posté le 15-03-2014 à 20:25:12
On est pas seigneur et encore moins devin ... Caractéristiques du PC ?
Marsh Posté le 15-03-2014 à 20:29:47
Bonsoir Xenon19,
Merci de prendre part à mon problème.
Je suis pas très experte,comment te donner ces informations?
Merci,
Marsh Posté le 15-03-2014 à 20:34:53
Avec le logiciel HW Info 64.
Marsh Posté le 15-03-2014 à 20:43:39
Re bonsoir,
Alors si j'ai compris voilà mes caractéristiques pc:
HWiNFO64 v4.34-2130
Creation Time  15.03.2014 20:38
IMEDIA-PC
[Current Computer]
 Computer Name:	IMEDIA-PC
 Computer Brand Name:	Packard Bell BV IMEDIA D5322 FR
[Operating System]
 Operating System:	Microsoft Windows 7 Professional (x64) Build 7601
 Service Pack:	Service Pack 1
Central Processor(s)
[CPU Unit Count]
 Number Of Processor Packages (Physical):	1
 Number Of Processors Cores:	2
 Number Of Logical Processors:	2
Intel Pentium Dual Core E2220
[General Information]
 Processor Name:	Intel Pentium Dual Core E2220
 Original Processor Frequency:	2400.0 MHz
 Original Processor Frequency [MHz]:	2400
 CPU ID:	000006FD
 CPU Brand Name:	Intel(R) Pentium(R) Dual CPU E2220 @ 2.40GHz
 CPU Vendor:	GenuineIntel
 CPU Stepping:	M0
 CPU Code Name:	Conroe-1M
 CPU S-Spec:	SLA8W
 CPU Thermal Design Power (TDP):	65 W
 CPU Max. Case Temperature (Tcase_max):	73.3 °C
 CPU Type:	Production Unit
 CPU Platform:	LGA775 (FC-LGA6)
 Microcode Update Revision:	A3
 Number of CPU Cores:	2
 Number of Logical CPUs:	2
[Operating Points]
 CPU LFM (Minimum):	1200.0 MHz = 6.00 x 200.0 MHz @ 1.1875 V
 CPU HFM (Maximum):	2400.0 MHz = 12.00 x 200.0 MHz @ 1.3250 V [Locked]
 CPU Current:	2399.7 MHz = 12.00 x 200.0 MHz @ 1.3250 V
 CPU Bus Type:	FSB (QDR)
[Cache and TLB]
 L1 Cache:	Instruction: 2 x 32 KBytes, Data: 2 x 32 KBytes
 L2 Cache:	Integrated: 1 MBytes
 Instruction TLB:	4 KB Pages, 4-way set associative, 128 entries
 Data TLB:	4 MB Pages, 4-way set associative, 32 entries
[Standard Feature Flags]
 FPU on Chip	Present
 Enhanced Virtual-86 Mode	Present
 I/O Breakpoints	Present
 Page Size Extensions	Present
 Time Stamp Counter	Present
 Pentium-style Model Specific Registers	Present
 Physical Address Extension	Present
 Machine Check Exception	Present
 CMPXCHG8B Instruction	Present
 APIC On Chip / PGE (AMD)	Present
 Fast System Call	Present
 Memory Type Range Registers	Present
 Page Global Feature	Present
 Machine Check Architecture	Present
 CMOV Instruction	Present
 Page Attribute Table	Present
 36-bit Page Size Extensions	Present
 Processor Number	Not Present
 CLFLUSH Instruction	Present
 Debug Trace and EMON Store	Present
 Internal ACPI Support	Present
 MMX Technology	Present
 Fast FP Save/Restore (IA MMX-2)	Present
 Streaming SIMD Extensions	Present
 Streaming SIMD Extensions 2	Present
 Self-Snoop	Present
 Multi-Threading Capable	Present
 Automatic Clock Control	Present
 IA-64 Processor	Not Present
 Signal Break on FERR	Present
 Streaming SIMD Extensions 3	Present
 Carryless Multiplication (PCLMULQDQ)/GFMUL	Not Present
 64-Bit Debug Store	Present
 MONITOR/MWAIT Support	Present
 CPL Qualified Debug Store	Present
 Virtual Machine Extensions	Not Present
 Safer Mode Extensions (Intel TXT)	Not Present
 Thermal Monitor 2	Present
 Supplemental Streaming SIMD Extensions 3	Present
 Enhanced SpeedStep Technology	Present
 L1 Context ID	Not Present
 IA32 Debug Interface Support	Not Present
 Fused Multiply Add	Not Present
 CMPXCHG16B Support	Present
 Send Task Priority Messages Disabling	Present
 Performance/Debug Capability MSR	Present
 Processor Context ID	Not Present
 Direct Cache Access	Not Present
 Streaming SIMD Extensions 4.1	Not Present
 Streaming SIMD Extensions 4.2	Not Present
 Extended xAPIC	Not Present
 MOVBE Instruction	Not Present
 POPCNT Instruction	Not Present
 TSC-deadline Timer	Not Present
 AES Cryptography Support	Not Present
 XSAVE/XRSTOR/XSETBV/XGETBV Instructions	Not Present
 XGETBV/XSETBV OS Enabled	Not Present
 AVX Support	Not Present
 Float16 Instructions	Not Present
 Random Number Read Instruction	Not Present
[Extended Feature Flags]
 64-bit Extensions	Present
 RDTSCP and TSC_AUX Support	Not Present
 1 GB large page support	Not Present
 No Execute	Present
 SYSCALL/SYSRET Support	Present
 Read/Write FS/GS Base Instructions	Not Present
 TSC_THREAD_OFFSET	Not Present
 Secure Enclave Support	Not Present
 Bit Manipulation Instructions Set 1	Not Present
 Hardware Lock Elision	Not Present
 AVX2 Instructions	Not Present
 Supervisor Mode Execution Protection	Not Present
 Bit Manipulation Instructions Set 2	Not Present
 Enhanced Performance String Instruction	Not Present
 INVPCID Instruction	Not Present
 Restricted Transactional Memory	Not Present
 Cache QoS Monitoring	Not Present
 Deprecated FPU CS and FPU DS	Not Present
 Memory Protection Extensions	Not Present
 Advanced Vector Extensions 512 (AVX-512)	Not Present
 RDSEED Instruction	Not Present
 Multi-precision Add Carry Instructions	Not Present
 Supervisor Mode Access Prevention (SMAP)	Not Present
 Intel Processor Trace	Not Present
 AVX-512 Prefetch Instructions	Not Present
 AVX-512 Exponential and Reciprocal Instructions	Not Present
 AVX-512 Conflict Detection Instructions	Not Present
 Secure Hash Algorithm (SHA) Extensions	Not Present
[Enhanced Features]
 Thermal Monitor 1:	Supported, Enabled
 Thermal Monitor 2:	Supported, Enabled
 Enhanced Intel SpeedStep (GV3):	Supported, Enabled
 Bi-directional PROCHOT#:	Enabled
 Extended Auto-HALT State C1E:	Enabled
 Extended Stop Grant State C2E:	N/A
 Enhanced Halt State C3E:	N/A
 Enhanced Halt State C4E:	N/A
 Enhanced Halt State Hard C4E:	N/A
 Hardware Prefetcher:	Supported, Enabled
 DCU Prefetcher:	Supported, Enabled
 IP Prefetcher:	Supported, Enabled
 Adjacent Cache Line Prefetch:	Supported, Enabled
 MLC Streamer Prefetcher	Not Supported
 MLC Spatial Prefetcher	Not Supported
 DCU Streamer Prefetcher	Not Supported
 DCU IP Prefetcher	Not Supported
 Intel Dynamic Acceleration (IDA) Technology:	Not Supported
 Intel Dynamic FSB Switching:	Not Supported
 Enhanced Multi Threaded Thermal Management:	N/A
 Intel Turbo Boost Technology:	Not Supported
 Programmable Ratio Limits:	Not Supported
 Programmable TDC/TDP Limits:	Not Supported
[Memory Ranges]
 Maximum Physical Address Size:	36-bit (64 GBytes)
 Maximum Virtual Address Size:	48-bit (256 TBytes)
[MTRRs]
 Range 0-80000000 (0MB-2048MB) Type:	Write Back (WB)
 Range 80000000-C0000000 (2048MB-3072MB) Type:	Write Back (WB)
 Range C0000000-D0000000 (3072MB-3328MB) Type:	Write Back (WB)
 Range 100000000-120000000 (4096MB-4608MB) Type:	Write Back (WB)
 Range 120000000-130000000 (4608MB-4864MB) Type:	Write Back (WB)
Motherboard
[Computer]
[Motherboard]
 Motherboard Model:	Packard Bell BV MCP73VT-PM
 Motherboard Chipset:	nVidia nForce 7100-620i (MCP73VE)
 Motherboard Slots:	1xPCI, 1xAGP, 2xPCI Express x1, 1xPCI Express x16
 PCI Express Version Supported:	v1.1
 USB Version Supported:	v2.0
[BIOS]
 BIOS Manufacturer:	American Megatrends
 BIOS Date:	09/10/08
 BIOS Version:	PBDV10.P18
 EFI BIOS:	Not Capable
 Super-IO/LPC Chip:	ITE IT8718F, Rev G
ACPI Devices
Bouton de fonctionnalité définie ACPI
 Device Name:	Bouton de fonctionnalité définie ACPI
Processeur Intel
 Device Name:	Processeur Intel
Processeur Intel
Contrôleur d’interruptions programmable
 Device Name:	Contrôleur d’interruptions programmable
[Assigned Resources]
 I/O Port:	0020 - 0021
 IRQ:	65792
[Alternative 1]
 I/O Port:	00A0 - 00A1
Horloge système
 Device Name:	Horloge système
 I/O Port:	0040 - 0043
[Alternative 1]
Compteur d’événement de haute précision
 Device Name:	Compteur d’événement de haute précision
 Memory Location:	FED00000 - FED00FFF
[Alternative 1]
 IRQ:	2
 IRQ:	8
Contrôleur d’accès direct en mémoire
 Device Name:	Contrôleur d’accès direct en mémoire
 I/O Port:	0089 - 008B
 DMA:	4
[Alternative 1]
 I/O Port:	0000 - 000F
 I/O Port:	0081 - 0083
 I/O Port:	0087
 I/O Port:	008F
 I/O Port:	00C0 - 00DF
 DMA:	4
Clavier standard PS/2
 Device Name:	Clavier standard PS/2
 I/O Port:	0060
 I/O Port:	0000
[Alternative 1]
 I/O Port:	0060
 I/O Port:	0064
 IRQ:	1
Haut-parleur système
 Device Name:	Haut-parleur système
 I/O Port:	0061
[Alternative 1]
 I/O Port:	0061
Bus PCI
 Device Name:	Bus PCI
 I/O Port:	0000 - FFFFFFFF
 Memory Location:	000A0000 - 000BFFFF
 Memory Location:	D0000000 - CFFFFFFF
[Alternative 1]
 I/O Port:	0000 - 0CF7
 I/O Port:	0D00 - FFFF
 Memory Location:	000D0000 - 000DFFFF
 Memory Location:	D0000000 - DFFFFFFF
 Memory Location:	F0000000 - FEBFFFFF
Horloge système CMOS/temps réel
 Device Name:	Horloge système CMOS/temps réel
 I/O Port:	0070 - 0071
[Alternative 1]
Carte système
 Device Name:	Carte système
 Memory Location:	00000000 - 0009FFFF
[Alternative 1]
 Memory Location:	000C0000 - 000CFFFF
 Memory Location:	000E0000 - 000FFFFF
 Memory Location:	00100000 - CFFFFFFF
 Memory Location:	FEC00000 - FFFFFFFF
Ressources de la carte mère
 Device Name:	Ressources de la carte mère
 Memory Location:	FEC00000 - FEC00FFF
[Alternative 1]
 Memory Location:	FEE00000 - FEE00FFF
 I/O Port:	0050 - 005F
 I/O Port:	0080
 I/O Port:	0090 - 009F
 I/O Port:	0800 - 080F
 Memory Location:	000D0000 - 000D3FFF
 Memory Location:	000DE000 - 000DDFFF
 Memory Location:	00000000 - 00000087
 IRQ:	1114369
[Alternative 1]
 I/O Port:	0010 - 001F
 I/O Port:	0022 - 003F
 I/O Port:	0044 - 004D
 I/O Port:	0062 - 0063
 I/O Port:	0065 - 006F
 I/O Port:	0072 - 007F
 I/O Port:	0080
 I/O Port:	0084 - 0086
 I/O Port:	0088
 I/O Port:	008C - 008E
 I/O Port:	00A2 - 00BF
 I/O Port:	00E0 - 00EF
 I/O Port:	04D0 - 04D1
 I/O Port:	4000 - 407F
 I/O Port:	4080 - 40FF
 I/O Port:	4400 - 447F
 I/O Port:	4480 - 44FF
 I/O Port:	4800 - 487F
 I/O Port:	4880 - 48FF
 Memory Location:	000D4000 - 000D7FFF
 Memory Location:	000DE000 - 000DFFFF
 Memory Location:	FEC80000 - FD93FFFF
 Memory Location:	FED02000 - FED03FFF
 Memory Location:	FED04000 - FED04FFF
 Memory Location:	FEE01000 - FEEFFFFF
 Memory Location:	E0000000 - EFFFFFFF
[Alternative 1]
 I/O Port:	0A00 - 0A0F
[Alternative 1]
 I/O Port:	0A10 - 0A1F
 I/O Port:	0A20 - 0A2F
 I/O Port:	0A30 - 0A3F
Coprocesseur arithmétique
 Device Name:	Coprocesseur arithmétique
 I/O Port:	00F0 - 00FF
[Alternative 1]
 IRQ:	13
Bouton marche-arrêt ACPI
 Device Name:	Bouton marche-arrêt ACPI
Interface de gestion Microsoft Windows pour ACPI
 Device Name:	Interface de gestion Microsoft Windows pour ACPI
Souris Microsoft PS/2
 Device Name:	Souris Microsoft PS/2
 IRQ:	12
[Alternative 1]
 IRQ:	12
SMBIOS DMI
BIOS
 BIOS Vendor:	American Megatrends Inc.
 BIOS Release Date:	09/10/2008
 BIOS Start Segment:	F000
 BIOS Size:	1024 KBytes
 System BIOS Version:	8.0
 ISA Support:	Present
 MCA Support:	Not Present
 EISA Support:	Not Present
 PCI Support:	Present
 PC Card (PCMCIA) Support:	Not Present
 Plug-and-Play Support:	Present
 APM Support:	Present
 Flash BIOS:	Present
 BIOS Shadow:	Present
 VL-VESA Support:	Not Present
 ESCD Support:	Present
 Boot from CD:	Present
 Selectable Boot:	Present
 BIOS ROM Socketed:	Present
 Boot from PC Card:	Not Present
 EDD Support:	Present
 NEC PC-98 Support:	Not Present
 ACPI Support:	Present
 USB Legacy Support:	Present
 AGP Support:	Not Present
 I2O Boot Support:	Not Present
 LS-120 Boot Support:	Present
 ATAPI ZIP Drive Boot Support:	Present
 IEE1394 Boot Support:	Not Present
 Smart Battery Support:	Not Present
 BIOS Boot Specification Support:	Present
 Function key-initiated Network Service Boot Support:	Not Present
 Targeted Content Distribution Support:	Present
 UEFI Specification Support:	Not Present
System
 System Manufacturer:	Packard Bell BV
 Product Name:	IMEDIA D5322 FR
 Product Version:	PVU050X014
 Product Serial Number:	PVU050X01490900E209000
 UUID:	{95CD58E0-0222-11DE-FCB3-815CA14DE8BB}
 SKU Number:	To Be Filled By O.E.M.
 Family:	To Be Filled By O.E.M.
Mainboard
 Mainboard Manufacturer:	Packard Bell BV
 Mainboard Name:	MCP73VT-PM
 Mainboard Version:	1.0
 Mainboard Serial Number:	00000000
 Asset Tag:	To Be Filled By O.E.M.
 Location in chassis:	To Be Filled By O.E.M.
System Enclosure
 Case Type:	Desktop
 Version:	To Be Filled By O.E.M.
 Serial Number:	50424E
 Asset Tag Number:	To Be Filled By O.E.M.
Processor
 Processor Manufacturer:	Intel
 Processor Version:	Intel(R) Pentium(R) Dual CPU E2220 @ 2.40GHz
 External Clock:	200 MHz
 Maximum Clock Supported:	2400 MHz
 Current Clock:	2400 MHz
 CPU Socket:	Populated
 CPU Status:	Enabled
 Processor Type:	Central Processor
 Processor Voltage:	1.3 V
 Processor Upgrade:	Socket LGA775
 Socket Designation:	CPU 1
L1-Cache
 Socket Designation:	L1-Cache
 Cache State:	Enabled
 Cache Type:	Internal, Data
 Cache Scheme:	Write-Back
 Supported SRAM Type:
 Current SRAM Type:
 Cache Speed:	Unknown
 Error Correction Type:
 Maximum Cache Size:	64 KBytes
 Installed Cache Size:	64 KBytes
 Cache Associativity:	8-way Set-Associative
L2-Cache
 Socket Designation:	L2-Cache
 Cache Type:	Internal, Unified
 Current SRAM Type:
 Maximum Cache Size:	1024 KBytes
 Installed Cache Size:	1024 KBytes
 Cache Associativity:	4-way Set-Associative
L3-Cache
 Socket Designation:	L3-Cache
 Cache State:	Disabled
 Cache Scheme:	Unknown
 Current SRAM Type:
 Error Correction Type:	Unknown
 Maximum Cache Size:	0 KBytes
 Installed Cache Size:	0 KBytes
 Cache Associativity:	Unknown
Port Connectors
Mouse Port
 Port Type:	Mouse Port
 Internal Reference:	J1A1
 Internal Connector Type:	None
 External Reference:	PS2Mouse
 External Connector Type:	PS/2
Keyboard Port
 Port Type:	Keyboard Port
 External Reference:	Keyboard
USB
 Port Type:	USB
 Internal Reference:	J2A2
 External Reference:	USB1
 External Connector Type:	Access Bus (USB)
USB
 Port Type:	USB
 External Reference:	USB2
Parallel Port ECP/EPP
 Port Type:	Parallel Port ECP/EPP
 Internal Reference:	J4A1
 External Reference:	LPT 1
 External Connector Type:	DB25 pin male
Serial Port 16550A Compatible
 Port Type:	Serial Port 16550A Compatible
 Internal Reference:	J2A1
 External Reference:	COM A
 External Connector Type:	DB-9 pin male
Audio Port
 Port Type:	Audio Port
 Internal Reference:	J6A1
 External Reference:	Audio Mic In
 External Connector Type:	Mini-jack (headphones)
Audio Port
 External Reference:	Audio Line In
Audio Port
 Internal Reference:	J6B1 - AUX IN
 Internal Connector Type:	On Board Sound Input from CD-ROM
 External Reference:	Unknown
 External Connector Type:	None
Audio Port
 Internal Reference:	J6B2 - CDIN
Port Connector
 Port Type:	Unknown
 Internal Reference:	J6J2 - PRI IDE
 Internal Connector Type:	On Board IDE
Port Connector
 Port Type:	Unknown
 Internal Reference:	J6J1 - SEC IDE
Port Connector
 Port Type:	Unknown
 Internal Reference:	J4J1 - FLOPPY
 Internal Connector Type:	On Board Floppy
Port Connector
 Port Type:	Unknown
 Internal Reference:	J9H1 - FRONT PNL
 Internal Connector Type:	9 Pin Dual Inline (pin 10 cut)
Port Connector
 Port Type:	Unknown
 Internal Reference:	J1B1 - CHASSIS REAR FAN
 Internal Connector Type:	Unknown
Port Connector
 Port Type:	Unknown
 Internal Reference:	J2F1 - CPU FAN
Port Connector
 Port Type:	Unknown
 Internal Reference:	J8B4 - FRONT FAN
Port Connector
 Port Type:	Unknown
 Internal Reference:	J9G2 - FNT USB
Port Connector
 Port Type:	Unknown
 Internal Reference:	J6C3 - FP AUD
Port Connector
 Port Type:	Unknown
 Internal Reference:	J9G1 - CONFIG
Port Connector
 Port Type:	Unknown
 Internal Reference:	J8C1 - SCSI LED
Port Connector
 Port Type:	Unknown
 Internal Reference:	J9J2 - INTRUDER
Port Connector
 Port Type:	Unknown
 Internal Reference:	J9G4 - ITP
Port Connector
 Port Type:	Unknown
 Internal Reference:	J2H1 - MAIN POWER
System Slots
AGP
 Slot Designation:	AGP
 Slot Type:	AGP 4X
 Slot Usage:	In use
 Slot Data Bus Width:	32-bit
 Slot Length:	Short
PCI1
 Slot Designation:	PCI1
 Slot Type:	PCI
 Slot Usage:	In use
 Slot Length:	Short
On Board Device
 Device Description:	To Be Filled By O.E.M.
 Device Type:	Video Adapter
 Device Status:	Enabled
BIOS Language
 	en|US|iso8859-1 <Active>
System Event Log
Memory Devices
Physical Memory Array
 Array Location:	System board
 Array Use:	System memory
 Error Detecting Method:	None
 Memory Capacity:	16777216 KBytes
 Memory Devices:	2
Memory Array Mapped Address
 Starting Address:	00000000
 Ending Address:	003FFFFF
 Partition Width:	4
Memory Device
 Total Width:	64 bits
 Data Width:	64 bits
 Device Size:	2048 MBytes
 Device Form Factor:	DIMM
 Device Locator:	DIMM0
 Bank Locator:	BANK0
 Device Type:	SDRAM
 Device Type Detail:	Synchronous
 Manufacturer:	Manufacturer00
 Serial Number:	SerNum00
 Part Number:	ModulePartNumber00
 Asset Tag:	AssetTagNum0
Memory Device Mapped Address
 Ending Address:	001FFFFF
 Partition Row Position:	1
 Interleave Position:	Non-interleaved
 Interleave Data Depth:	1
Memory Device
 Data Width:	64 bits
 Device Locator:	DIMM1
 Bank Locator:	BANK1
 Device Type:	SDRAM
 Manufacturer:	Manufacturer01
 Serial Number:	SerNum01
 Part Number:	ModulePartNumber01
 Asset Tag:	AssetTagNum1
 Starting Address:	00200000
System Boot Information
 Boot Status:	No error occured
Memory
[General information]
 Total Memory Size:	4 GBytes
 Total Memory Size [MB]:	4096
[Current Performance Settings]
 Current Memory Clock:	333.3 MHz (5 : 3 ratio)
 Current Timing (tCAS-tRCD-tRP-tRAS):	5.0-4-4-14
 Command Rate:	2T
 Read to Write Delay (tRD_WR) Same Rank:	6T
 Write to Read Delay (tWR_RD) Same Rank (tWTR):	10T
 Read to Precharge Delay (tRTP):	4T
 Write to Precharge Delay (tWTP):	12T
 Write Recovery Time (tWR):	5T
 RAS# to RAS# Delay (tRRD):	3T
 Row Cycle Time (tRC):	20T
 Four Activate Window (tFAW):	13T
Row: 0 - 2048 MB PC2-6400 DDR2-SDRAM Samsung M3 78T5663QZ3-CF7
[General Module Information]
 Module Number:	0
 Module Size:	2048 MBytes
 Memory Type:	DDR2-SDRAM
 DIMM Type:	Regular Unbuffered (UDIMM)
 Error Check/Correction:	None
 Memory Speed:	400.0 MHz (PC2-6400)
 Module Manufacturer:	Samsung
 Module Model:	M3 78T5663QZ3-CF7
 Serial Number:	977501824
 Manufacturing Date:	Year: 2009, Week: 4
[Module Characteristics]
 Module Width:	64-bits
 Module Voltage:	SSTL 1.8V
 SPD Revision:	1.2
 Number Of Ranks:	2
 Row Address Bits:	14
 Column Address Bits:	10
 Number Of Banks:	8
[Module timing]
 Supported Burst Lengths:	4, 8
 Refresh Rate:	Reduced 0.5x (7.8 us)
 Supported CAS Latencies (tCAS):	6.0, 5.0, 4.0
 Min. RAS-to-CAS Delay (tRCD):	15.00 ns
 Min. Row Precharge Time (tRP):	15.00 ns
 Min. RAS Pulse Width (tRAS):	45 ns
 Supported Module Timing at 400.0 MHz:	6.0-6-6-18
 Supported Module Timing at 333.3 MHz:	5.0-5-5-15
 Supported Module Timing at 266.7 MHz:	4.0-4-4-12
 Min. Row-Activate To Row-Activate Delay (tRRD):	7.50 ns
 Write Recovery Time (tWR):	15.00 ns
 Internal write to read command delay (tWTR):	7.50 ns
 Internal read to precharge command delay (tRTP):	7.50 ns
 Minimum Activate to Activate/Refresh Time (tRC):	60.00 ns
 Minimum Refresh to Activate/Refresh Command Period (tRFC):	127.50 ns
 Address and Command Setup Time Before Clock (tIS):	0.17 ns
 Address and Command Setup Time After Clock (tIH):	0.25 ns
 Data Input Setup Time Before Strobe (tDS):	0.05 ns
 Data Input Setup Time After Strobe (tDH):	0.12 ns
Row: 1 - 2048 MB PC2-6400 DDR2-SDRAM Samsung M3 78T5663QZ3-CF7
 Module Number:	1
 Serial Number:	1682144896
 SPD Revision:	1.2
 Number Of Ranks:	2
 Number Of Banks:	8
[Module timing]
Bus
PCI Bus #0
NVIDIA nForce 7100-620i (MCP73VE) - Host Bridge
 Device Name:	NVIDIA nForce 7100-620i (MCP73VE) - Host Bridge
 Original Device Name:	NVIDIA nForce 7100-620i (MCP73VE) - Host Bridge
 Device Class:	Host-to-PCI Bridge
 Revision ID:	A2
 Bus Number:	0
 Device Number:	0
 Function Number:	0
 PCI Latency Timer:	0
 Hardware ID:	PCI\VEN_10DE&DEV_07C5&SUBSYS_E0381631&REV_A2
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 Bus Mastering:	Enabled
 Running At 66 MHz:	Capable
 Fast Back-to-Back Transactions:	Capable
[Driver Information]
 Driver Manufacturer:	(Périphériques système standard)
 Driver Description:	Pont CPU hôte standard PCI
 Driver Provider:	Microsoft
 Driver Version:	6.1.7601.17514
 Driver Date:	21-Jun-2006
 DeviceInstanceId	PCI\VEN_10DE&DEV_07C5&SUBSYS_E0381631&REV_A2\3&267A616A&0&00
NVIDIA MCP73 - Host Bridge 2
 Device Name:	NVIDIA MCP73 - Host Bridge 2
 Original Device Name:	NVIDIA MCP73 - Host Bridge 2
 Device Class:	RAM/Memory Controller
 Revision ID:	A2
 Bus Number:	0
 Device Number:	0
 Function Number:	1
 Hardware ID:	PCI\VEN_10DE&DEV_07CB&SUBSYS_E0381631&REV_A2
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 Driver Description:	Contrôleur de RAM standard PCI
 DeviceInstanceId	PCI\VEN_10DE&DEV_07CB&SUBSYS_E0381631&REV_A2\3&267A616A&0&01
NVIDIA MCP73 - Memory Controller
 Device Name:	NVIDIA MCP73 - Memory Controller
 Original Device Name:	NVIDIA MCP73 - Memory Controller
 Revision ID:	A1
 Bus Number:	0
 Device Number:	1
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_07CD&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 Bus Mastering:	Disabled
 Fast Back-to-Back Transactions:	Not Capable
 DeviceInstanceId	PCI\VEN_10DE&DEV_07CD&SUBSYS_E0381631&REV_A1\3&267A616A&0&08
NVIDIA MCP73 - Memory Controller 2
 Device Name:	NVIDIA MCP73 - Memory Controller 2
 Original Device Name:	NVIDIA MCP73 - Memory Controller 2
 Revision ID:	A1
 Bus Number:	0
 Device Number:	1
 Function Number:	1
 Hardware ID:	PCI\VEN_10DE&DEV_07CE&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_07CE&SUBSYS_E0381631&REV_A1\3&267A616A&0&09
NVIDIA MCP73 - Memory Controller (CPURR)
 Device Name:	NVIDIA MCP73 - Memory Controller (CPURR)
 Original Device Name:	NVIDIA MCP73 - Memory Controller (CPURR)
 Revision ID:	A1
 Bus Number:	0
 Device Number:	1
 Function Number:	2
 Hardware ID:	PCI\VEN_10DE&DEV_07CF&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_07CF&SUBSYS_E0381631&REV_A1\3&267A616A&0&0A
NVIDIA MCP73 - Memory I/O Controller
 Device Name:	NVIDIA MCP73 - Memory I/O Controller
 Original Device Name:	NVIDIA MCP73 - Memory I/O Controller
 Revision ID:	A1
 Bus Number:	0
 Device Number:	1
 Function Number:	3
 Hardware ID:	PCI\VEN_10DE&DEV_07D0&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_07D0&SUBSYS_E0381631&REV_A1\3&267A616A&0&0B
NVIDIA MCP73 - Memory Controller (PAD CAL)
 Device Name:	NVIDIA MCP73 - Memory Controller (PAD CAL)
 Original Device Name:	NVIDIA MCP73 - Memory Controller (PAD CAL)
 Revision ID:	A1
 Bus Number:	0
 Device Number:	1
 Function Number:	4
 Hardware ID:	PCI\VEN_10DE&DEV_07D1&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_07D1&SUBSYS_E0381631&REV_A1\3&267A616A&0&0C
NVIDIA MCP73 - Memory Controller (SSO)
 Device Name:	NVIDIA MCP73 - Memory Controller (SSO)
 Original Device Name:	NVIDIA MCP73 - Memory Controller (SSO)
 Revision ID:	A1
 Bus Number:	0
 Device Number:	1
 Function Number:	5
 Hardware ID:	PCI\VEN_10DE&DEV_07D2&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_07D2&SUBSYS_E0381631&REV_A1\3&267A616A&0&0D
NVIDIA MCP73 - Memory I/O Controller 2
 Device Name:	NVIDIA MCP73 - Memory I/O Controller 2
 Original Device Name:	NVIDIA MCP73 - Memory I/O Controller 2
 Revision ID:	A1
 Bus Number:	0
 Device Number:	1
 Function Number:	6
 Hardware ID:	PCI\VEN_10DE&DEV_07D3&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_07D3&SUBSYS_E0381631&REV_A1\3&267A616A&0&0E
NVIDIA MCP73 - Memory I/O Controller 3
 Device Name:	NVIDIA MCP73 - Memory I/O Controller 3
 Original Device Name:	NVIDIA MCP73 - Memory I/O Controller 3
 Revision ID:	A1
 Bus Number:	0
 Device Number:	2
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_07D6&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_07D6&SUBSYS_E0381631&REV_A1\3&267A616A&0&10
NVIDIA MCP73 - LPC Bridge
 Device Name:	NVIDIA MCP73 - LPC Bridge
 Original Device Name:	NVIDIA MCP73 - LPC Bridge
 Device Class:	PCI-to-ISA Bridge
 Revision ID:	A2
 Bus Number:	0
 Device Number:	3
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_07D7&SUBSYS_E0381631&REV_A2
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
 I/O Base Address 0	4F00
[Features]
 Driver Description:	Pont ISA standard PCI
 DeviceInstanceId	PCI\VEN_10DE&DEV_07D7&SUBSYS_E0381631&REV_A2\3&267A616A&0&18
NVIDIA MCP73 - SMBus Controller
 Device Name:	NVIDIA MCP73 - SMBus Controller
 Original Device Name:	NVIDIA MCP73 - SMBus Controller
 Device Class:	SMBus (System Management Bus)
 Revision ID:	A1
 Bus Number:	0
 Device Number:	3
 Function Number:	1
 Hardware ID:	PCI\VEN_10DE&DEV_07D8&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	IRQ11
 Interrupt Pin:	INTA#
 I/O Base Address 0	4900
 I/O Base Address 4	4D00
 I/O Base Address 5	4E00
[Features]
 Driver Manufacturer:	NVIDIA
 Driver Description:	Gestion de système NVIDIA nForce PCI
 DeviceInstanceId	PCI\VEN_10DE&DEV_07D8&SUBSYS_E0381631&REV_A1\3&267A616A&0&19
NVIDIA MCP73 - Shape/Trim
 Device Name:	NVIDIA MCP73 - Shape/Trim
 Original Device Name:	NVIDIA MCP73 - Shape/Trim
 Revision ID:	A1
 Bus Number:	0
 Device Number:	3
 Function Number:	2
 Hardware ID:	PCI\VEN_10DE&DEV_07D9&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_07D9&SUBSYS_E0381631&REV_A1\3&267A616A&0&1A
NVIDIA MCP73 - Miscellaneous P4 Controller for FSB
 Device Name:	NVIDIA MCP73 - Miscellaneous P4 Controller for FSB
 Original Device Name:	NVIDIA MCP73 - Miscellaneous P4 Controller for FSB
 Revision ID:	A1
 Bus Number:	0
 Device Number:	3
 Function Number:	4
 Hardware ID:	PCI\VEN_10DE&DEV_07C8&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_07C8&SUBSYS_E0381631&REV_A1\3&267A616A&0&1C
NVIDIA MCP73 - OHCI USB 1.1 Controller
 Device Name:	NVIDIA MCP73 - OHCI USB 1.1 Controller
 Original Device Name:	NVIDIA MCP73 - OHCI USB 1.1 Controller
 Device Class:	Universal Serial Bus (USB)
 Revision ID:	A1
 Bus Number:	0
 Device Number:	4
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_07FE&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	IRQ21
 Memory Base Address 0	F9EFF000
[Features]
 Driver Manufacturer:	(Contrôleur hôte USB standard)
 Driver Description:	Contrôleur hôte USB OpenHCD standard
 Driver Version:	6.1.7601.18328
 DeviceInstanceId	PCI\VEN_10DE&DEV_07FE&SUBSYS_E0381631&REV_A1\3&267A616A&0&20
USB Root Hub
[Port1] : No Device Connected
[Port2] : No Device Connected
[Port3] : No Device Connected
[Port4] : No Device Connected
[Port5] : No Device Connected
[Port6] : No Device Connected
[Port7] : No Device Connected
[Port8] : No Device Connected
NVIDIA MCP73 - EHCI USB 2.0 Controller
 Device Name:	NVIDIA MCP73 - EHCI USB 2.0 Controller
 Original Device Name:	NVIDIA MCP73 - EHCI USB 2.0 Controller
 Revision ID:	A1
 Bus Number:	0
 Device Number:	4
 Function Number:	1
 Hardware ID:	PCI\VEN_10DE&DEV_056A&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	IRQ20
 Interrupt Pin:	INTB#
 Memory Base Address 0	F9EFEC00
[Features]
 Driver Description:	Contrôleur hôte PCI vers USB standard étendu
 DeviceInstanceId	PCI\VEN_10DE&DEV_056A&SUBSYS_E0381631&REV_A1\3&267A616A&0&21
USB Root Hub
NVIDIA MCP73 - Parallel ATA Controller
 Device Name:	NVIDIA MCP73 - Parallel ATA Controller
 Original Device Name:	NVIDIA MCP73 - Parallel ATA Controller
 Device Class:	IDE Controller
 Revision ID:	A1
 Bus Number:	0
 Device Number:	8
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_056C&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
 I/O Base Address 4	FFA0
[Features]
 Driver Manufacturer:	(Contrôleurs ATA/ATAPI IDE standard)
 Driver Description:	Contrôleur IDE standard double canal PCI
 Driver Version:	6.1.7601.18231
 DeviceInstanceId	PCI\VEN_10DE&DEV_056C&SUBSYS_E0381631&REV_A1\3&267A616A&0&40
NVIDIA MCP73 - High Definition Audio Controller
 Device Name:	NVIDIA MCP73 - High Definition Audio Controller
 Original Device Name:	NVIDIA MCP73 - High Definition Audio Controller
 Device Class:	Mixed mode device
 Revision ID:	A1
 Bus Number:	0
 Device Number:	9
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_07FC&SUBSYS_E0381631&REV_A1
[System Resources]
 Interrupt Line:	IRQ23
 Memory Base Address 0	F9EF8000
[Features]
 Driver Manufacturer:	Microsoft
 Driver Description:	Contrôleur audio haute définition
 Driver Date:	19-Nov-2010
 DeviceInstanceId	PCI\VEN_10DE&DEV_07FC&SUBSYS_E0381631&REV_A1\3&267A616A&0&48
NVIDIA MCP73 - PCI-to-PCI Bridge
 Device Name:	NVIDIA MCP73 - PCI-to-PCI Bridge
 Original Device Name:	NVIDIA MCP73 - PCI-to-PCI Bridge
 Device Class:	PCI-to-PCI Bridge
 Revision ID:	A1
 Bus Number:	0
 Device Number:	10
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_056D&SUBSYS_00000000&REV_A1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 Driver Description:	Pont PCI vers PCI standard PCI
 DeviceInstanceId	PCI\VEN_10DE&DEV_056D&SUBSYS_E0381631&REV_A1\3&267A616A&0&50
PCI Bus #1
RealTek Semiconductor RTL8139 PCI Fast Ethernet NIC [A/B/C]
 Device Name:	RealTek Semiconductor RTL8139 PCI Fast Ethernet NIC [A/B/C]
 Original Device Name:	RealTek Semiconductor RTL8139 PCI Fast Ethernet NIC [A/B/C]
 Device Class:	Ethernet Adapter
 Revision ID:	10
 Bus Number:	1
 Device Number:	4
 Function Number:	0
 PCI Latency Timer:	64
 Hardware ID:	PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10
[System Resources]
 Interrupt Line:	IRQ18
 I/O Base Address 0	D800
 Memory Base Address 1	F9FFFC00
[Features]
 Running At 66 MHz:	Not Capable
 Driver Manufacturer:	Realtek Semiconductor Corp.
 Driver Description:	Realtek RTL8139/810x Family Fast Ethernet NIC
 Driver Provider:	Realtek Semiconductor Corp.
 Driver Version:	6.111.723.2009
 Driver Date:	23-Jul-2009
 DeviceInstanceId	PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\4&29300B9F&0&2050
NVIDIA MCP73 - PCI Express Root Port (x16)
 Device Name:	NVIDIA MCP73 - PCI Express Root Port (x16)
 Original Device Name:	NVIDIA MCP73 - PCI Express Root Port (x16)
 Revision ID:	A1
 Bus Number:	0
 Device Number:	11
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_056E&SUBSYS_00000000&REV_A1
[PCI Express]
 Version:	1.1
 Maximum Link Width:	16x
 Current Link Width:	16x
 Maximum Link Speed:	2.5 Gb/s
 Current Link Speed:	2.5 Gb/s
 Device/Port Type:	Root Port of PCI Express Root Complex
 Slot Implemented:	Yes
 Hot-Plug:	Not Capable
 Hot-Plug Surprise:	Not Capable
 Slot Power Limit:	75.000 W
 Active State Power Management (ASPM) Support:	L0s and L1
 Active State Power Management (ASPM) Status:	Disabled
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 Driver Description:	Port racine PCI Express standard
 DeviceInstanceId	PCI\VEN_10DE&DEV_056E&SUBSYS_E0381631&REV_A1\3&267A616A&0&58
PCI Express x16 Bus #2
Zotac GeForce GT 120
 Device Name:	Zotac GeForce GT 120
 Original Device Name:	NVIDIA GeForce GT 120 (G96)
 Device Class:	VGA Compatible Adapter
 Revision ID:	A1
 Bus Number:	2
 Device Number:	0
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_0646&SUBSYS_9630174B&REV_A1
[PCI Express]
 Version:	1.1
 Device/Port Type:	PCI Express Endpoint
 Slot Implemented:	No
[System Resources]
 Interrupt Line:	IRQ17
 Memory Base Address 0	FD000000
 Memory Base Address 1	D0000000
 Memory Base Address 3	FA000000
 I/O Base Address 5	EC00
[Features]
 Driver Description:	NVIDIA GeForce GT 120
 Driver Provider:	NVIDIA
 Driver Version:	9.18.13.3523
 Driver Date:	04-Mar-2014
 DeviceInstanceId	PCI\VEN_10DE&DEV_0646&SUBSYS_9630174B&REV_A1\4&2D909E4A&0&0058
NVIDIA MCP73 - PCI Express Root Port (x1)
 Device Name:	NVIDIA MCP73 - PCI Express Root Port (x1)
 Original Device Name:	NVIDIA MCP73 - PCI Express Root Port (x1)
 Revision ID:	A1
 Bus Number:	0
 Device Number:	12
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_056F&SUBSYS_00000000&REV_A1
[PCI Express]
 Version:	1.1
 Maximum Link Width:	1x
 Current Link Width:	1x
 Slot Power Limit:	10.000 W
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_056F&SUBSYS_E0381631&REV_A1\3&267A616A&0&60
PCI Express x1 Bus #3
 Revision ID:	A1
 Bus Number:	0
 Device Number:	13
 Function Number:	0
[PCI Express]
 Version:	1.1
[System Resources]
 Interrupt Line:	N/A
 Interrupt Pin:	N/A
[Features]
 DeviceInstanceId	PCI\VEN_10DE&DEV_056F&SUBSYS_E0381631&REV_A1\3&267A616A&0&68
PCI Express x1 Bus #4
NVIDIA MCP73 - SATA AHCI Controller
 Device Name:	NVIDIA MCP73 - SATA AHCI Controller
 Original Device Name:	NVIDIA MCP73 - SATA AHCI Controller
 Device Class:	Serial ATA Controller
 Revision ID:	A2
 Bus Number:	0
 Device Number:	14
 Function Number:	0
 Hardware ID:	PCI\VEN_10DE&DEV_07F4&SUBSYS_E0381631&REV_A2
[System Resources]
 I/O Base Address 0	C480
 I/O Base Address 1	C400
 I/O Base Address 2	C080
 I/O Base Address 3	C000
 I/O Base Address 4	BC00
 Memory Base Address 5	F9EFC000
[Features]
[SATA Host Controller]
 Interface Speed Supported:	Gen2 3.0 Gbps
 Number Of Ports:	4
 External SATA Support:	Not Capable
 Aggressive Link Power Management:	Capable
 Staggered Spin-up:	Not Capable
 Mechanical Presence Switch:	Not Capable
 Command Queue Acceleration:	Not Capable
 AHCI Status:	Enabled
 AHCI Version:	1.10
 Ports Implemented:	0, 1, 2, 3
[SATA Port#0]
 Port Status:	Device Present, Phy communication established
 Current Interface Speed:	Gen2 3.0 Gbps
 External SATA Port:	Not Capable
 Hot Plug:	Capable
 Device Type:	SATA
[SATA Port#1]
 Current Interface Speed:	Gen1 1.5 Gbps
 Hot Plug:	Capable
 Device Type:	ATAPI
[SATA Port#2]
 Port Status:	No Device Present
 Hot Plug:	Capable
[SATA Port#3]
 Hot Plug:	Capable
 Driver Manufacturer:	NVIDIA Corporation
 Driver Description:	NVIDIA nForce Serial ATA Controller
 Driver Provider:	NVIDIA Corporation
 Driver Version:	11.1.0.43
 Driver Date:	09-Apr-2010
 DeviceInstanceId	PCI\VEN_10DE&DEV_07F4&SUBSYS_E0381631&REV_A2\3&267A616A&0&70
Video Adapter
[Video chipset]
 Video Chipset:	NVIDIA GeForce GT 120
 Video Chipset Codename:	G96
 Video Memory:	1024 MBytes of DDR2 SDRAM
[Video Card]
 Video Card:	Zotac GeForce GT 120
 Video Bus:	PCIe v1.1 x16 (2.5 Gb/s) @ x16 (2.5 Gb/s)
 Video RAMDAC:	Integrated RAMDAC
 Video BIOS Version:	62.94.4a.00.24
 Video Chipset Revision:	A1
[Performance]
 Processor Clock:	550.0 MHz
 Geometry Unit Clock:	550.0 MHz
 Shader Unit Clock:	1350.0 MHz
 Memory Clock:	509.1 MHz (Effective 1018.3 MHz)
 Memory Bus Width:	128-bit
 Number Of ROPs:	8
 Number Of Unified Shaders:	32
 nVidia SLI Status:	Enabled
Monitor
Hewlett-Packard vs17
 Monitor Name:	Hewlett-Packard vs17
 Monitor Name (Manuf):	HP vs17
 Serial Number:	CNC52310Y6
 Date Of Manufacture:	Week: 23, Year: 2005
 Monitor Hardware ID:	Monitor\HWP2647
 Max. Vertical Size:	27 cm
 Max. Horizontal Size:	34 cm
 Horizontal Frequency:	30 - 83 kHz
 Vertical Frequency:	50 - 76 Hz
 Maximum Pixel Clock:	140 MHz
[Advanced parameters]
 Input Signal:	Analog: 0.700 V / 0.000 V (0.700 V p-p)
 Display Type:	RGB color
 Gamma Factor:	2.40
[DPMS Modes]
 Standby:	Supported
 Suspend:	Supported
 Active Off:	Supported
 Standard Colour Space:	Supported
 Preferred Timing Mode:	Supported
 Default GTF Supported:	Not Supported
[DPMS Input Signal]
 Serration VSync:	Not Supported
 Sync On Green:	Not Supported
 Composite Sync:	Not Supported
 Separate Syncs:	Supported
 Blank-to-black Setup:	Not Supported
[Supported Video Modes]
 1280 x 1024	60 Hz
 1280 x 1024	340 x 270 mm, Pixel Clock 108.00 MHz
Drives
Floppy Drives
(S)ATA/ATAPI Drives
WDC WD10EAVS-00D7B1
 Drive Controller:	Serial ATA 3Gb/s
 Drive Model:	WDC WD10EAVS-00D7B1
 Drive Revision:	01.01A01
 Drive Serial Number:	WD-WCAU45734497
 World Wide Name:	50014EE2AD04E7C9
 Drive Capacity:	953,869 MBytes (1000 GB)
 Drive Capacity [MB]:	953869
[Drive Geometry]
 Number of Cylinders:	16383
 Number of Heads:	16
 Sectors Per Track:	63
 Number Of ECC Bytes:	50
 Number of Sectors:	16514064
 Total 32-bit LBA Sectors:	268435455
 Total 48-bit LBA Sectors:	1953525168
 Cache Buffer Size:	8192 KBytes
[Transfer Modes]
 Sectors Per Interrupt:	Total: 16, Active: 16
 Max. PIO Transfer Mode:	4
 Multiword DMA Mode:	Total: 2, Active: -
 Singleword DMA Mode:	Total: -, Active: -
 Ultra-DMA Mode:	Total: 6 (ATA-133), Active: 6 (ATA-133)
 Max. Multiword DMA Transfer Rate:	16.7 MBytes/s
 Max. PIO with IORDY Transfer Rate:	16.7 MBytes/s
 Max. PIO w/o IORDY Transfer Rate:	16.7 MBytes/s
 Transfer Width:	16-bit
 Native Command Queuing:	Supported, Max. Depth: 32
 TRIM Command:	Not Supported
[Device flags]
 Fixed Drive:	Present
 Removable Drive:	Not Present
 Magnetic Storage:	Present
 LBA Mode:	Supported
 DMA Mode:	Supported
 IORDY:	Supported
 IORDY Disableable:	Supported
[Features]
 Write Cache:	Present, Active
 S.M.A.R.T. Feature:	Present, Active
 Security Feature:	Present, Inactive
 Removable Media Feature:	Not Present, Disabled
 Power Management:	Present, Active
 Advanced Power Management:	Not Present, Inactive
 Packet Interface:	Not Present, Disabled
 Look-Ahead Buffer:	Present, Active
 Host Protected Area:	Present, Enabled
 Power-Up In Standby:	Supported, Inactive
 Automatic Acoustic Management:	Supported, Inactive
 48-bit LBA:	Supported, Active
 Host-Initiated Link Power Management:	Supported
 Device-Initiated Link Power Management:	Not Supported
 In-Order Data Delivery:	Not Supported
 Hardware Feature Control:	Not Supported
 Software Settings Preservation:	Supported, Enabled
 NCQ Autosense:	Not Supported
 Link Power State Device Sleep:	Not Supported
 Hybrid Information Feature:	Not Supported
 All Write Cache Non-Volatile:	Not Supported
 Extended Number of User Addressable Sectors:	Not Supported
 Device Encrypts All User Data:	Not Supported
 CFast Specification:	Not Supported
 NCQ Priority Information:	Not Supported
 Host Automatic Partial to Slumber Transitions:	Not Supported
 Device Automatic Partial to Slumber Transitions:	Not Supported
 NCQ Streaming:	Not Supported
 NCQ Queue Management Command:	Not Supported
 DEVSLP to Reduced Power State:	Not Supported
 Extended Power Conditions Feature:	Not Supported
 Sense Data Reporting Feature:	Not Supported
 Free-Fall Control Feature:	Not Supported
[Self-Monitoring, Analysis and Reporting Technology (S.M.A.R.T.)]
 [01] Raw Read Error Rate:	200/51, Worst: 200 (Data = 3)
 [03] Spin Up Time:	160/21, Worst: 160 (Data = 6966)
 [04] Start/Stop Count:	98/Always OK, Worst: 98 (Data = 2305)
 [05] Reallocated Sector Count:	200/140, Worst: 200
 [07] Seek Error Rate:	100/Always OK, Worst: 253
 [09] Power-On Hours/Cycle Count:	64/Always OK, Worst: 64 (Data = 26768)
 [0A] Spin Retry Count:	100/Always OK, Worst: 100
 [0B] Calibration Retry Count:	100/Always OK, Worst: 100
 [0C] Power Cycle Count:	98/Always OK, Worst: 98 (Data = 2298)
 [C0] Power-Off Retract Count:	199/Always OK, Worst: 199 (Data = 950)
 [C1] Load/Unload Cycle Count:	200/Always OK, Worst: 200 (Data = 2305)
 [C2] Temperature	120/Always OK, Worst: 107 (Data = 30.0 °C)
 [C4] Reallocation Event Count:	200/Always OK, Worst: 200
 [C5] Current Pending Sector Count:	200/Always OK, Worst: 200
 [C6] Off-Line Uncorrectable Sector Count:	200/Always OK, Worst: 200
 [C7] UltraDMA/SATA CRC Error Rate:	200/Always OK, Worst: 200 (Data = 1)
 [C8] Write/Multi-Zone Error Rate:	200/Always OK, Worst: 200
HL-DT-ST DVDRAM GH40F
 Drive Model:	HL-DT-ST DVDRAM GH40F
 Drive Revision:	MG01
 Firmware Date:	2008-12-26 12:34:56
 Serial Number:	5AB34063CE3F
 Device Type:	DVD+R DL
[Device capabilities]
 Drive can read:	CD-R, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
 Drive can write:	CD-R, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
Audio
 Audio Adapter:	NVIDIA MCP73 - High Definition Audio Controller
 Audio Controller Hardware ID:	PCI\VEN_10DE&DEV_07FC&SUBSYS_E0381631&REV_A1
 High Definition Audio Codec:	Unknown 10000000
 Audio Codec Hardware ID:	HDAUDIO\FUNC_01&VEN_1000&DEV_0000&SUBSYS_10EC0888
Network
 Network Card:	RealTek Semiconductor RTL8139 PCI Fast Ethernet NIC [A/B/C]
 Vendor Description:	Realtek RTL8139/810x Family Fast Ethernet NIC
 MAC Address:	00-E0-4C-43-15-CB
[Capabilities]
 Maximum Link Speed:	100 Mbps
 Transmit Buffer Size:	32768 Bytes
 Receive Buffer Size:	65536 Bytes
Ports
Serial Ports
Parallel Ports
USB
Root Hub
Root Hub
Voilà ^^
Marsh Posté le 15-03-2014 à 20:54:42
Déjà Packard Bell, comment dire, ça commence plutôt mal.
Le processeur est très peu puissant, ça peut venir de là, j'avais ce soucis sur un Acer portable. Regardes dans les options d'alimentations (panneau de configuration), si tu es sur le mode "performance élevé".
Marsh Posté le 15-03-2014 à 20:57:39
Bien Oui Packard Bell oui et alors?
Tout le monde n'est pas un spécialiste , encore moin assez riche pour se permettre tout caprices...
Et oui suis en mode performances élevées.
Merci,
Marsh Posté le 16-03-2014 à 09:10:08
Packard Bell comme toutes les marques de supermarché c'est de la m****
  Y a pas besoin d'être riche pour avoir un PC de qualité et qui dure surtout dans le temps, exemple : http://www.materiel.net/ordinateur [...] 02109.html au contraire c'est les PC fait sur mesure qui sont moins chères, et surtout d'une qualité laaargement supérieur
La plupart du temps les PC constructeurs sont fournit avec une fioriture de logiciels inutiles (anti-virus payant, logiciel de traitement de texte payant et autre logiciel du constructeur), et qui font grimper la note finale du PC ...
Pour revenir au sujet, télécharges Ccleaner et fait un petit nettoyage. Désinstalles aussi les logiciels qui tu n'utilises pas, un disque dur trop remplis, peut aussi causer des dégradations dans le son à cause des accès fréquents de la tête de lecture sur le disque.
Marsh Posté le 16-03-2014 à 09:16:18
As-tu un port audio à l'avant du boitier pour brancher temporairement tes enceintes ?
Marsh Posté le 16-03-2014 à 09:41:23
Merci Artouillassse de te joindre à cette discussion.
CCleaner intallé et nettoyage + registre effectué.
Et pour répondre à Artouill ma prise audio arrière me donne que du mono bizarrement,et celle de devant fonctionnent mais avec ce problème.
Merci,
Marsh Posté le 16-03-2014 à 09:45:38
Un petit nettoyage de printemps ne ferait pas de mal je pense (poussière dans le PC), les connecteurs n'aiment pas trop ça
Marsh Posté le 16-03-2014 à 09:48:02
Oki je vais demander à mon voisin de regarder car moi et mes petite mimines là je pense pas savoir.
Je vous tiens au courant.
Merci,
Marsh Posté le 15-03-2014 à 20:19:42
Je sais que beaucoups de posts en parle mais je ne trouve pas de cas réellement similaire:
Depuis deux jours j'ai même sans écouter de music des coupures son sur mon pc fixe.
sans music j'entend des tap tap dans mon casque toutes les 4/5 secondes.
Et niveau musique,que ce soit sur cd,fichier,ou clé usb c'est pareil.
Si un grand seigneur pouvait m'aider...
Merci,
