La premiere Mobo Sys735 arrive!!!! - Overclocking, Cooling & Modding
Marsh Posté le 16-07-2001 à 12:55:12
pierrotlemaboule a écrit a écrit  :
sys = ali = pourri !
la qualité cela se paye !
Marsh Posté le 16-07-2001 à 13:07:03
ReplyMarsh Posté le 16-07-2001 à 13:20:12
| thekiller a écrit a écrit  : sys = ali = pourri ! la qualité cela se paye !  |
via c etait pourri et ils ont bien progressé alors pk SIS .?
franchement si les perfs sont a la hauteur j achete sans pb
Marsh Posté le 16-07-2001 à 13:23:34
voici les spec de la mobo
c'est po mal du tt pr une mobo a 550frs!!!
carte reseaux/chip sonore integree!!!
et si je comprend bien il y a aussi port firewire!!!
The advanced features of the SiS 735 System Board include : System Board include :
Supports AMD K7 Athlon/Duron 500M~1.4GHz CPUs with frequency at 200/266MHz in Socket A for ATX Form Factor.
Provides 2 DIMMs for PC133 SDRAM, 2 DDR DIMM for DDR SDRAM modules, and memory size is expand up to 1GB.
Provides an AGP slot and 5 PCI slots; supports AGP 4X mode, fully compliant AGP2.0 and PCI 2.2 specification.
Provide an AMR slot; DirectSound AC97 Codec on board, for Audio and Modem applications.
10/100Mbps Fast Ethernet on board, supports IEEE802.3 and 802.3u standards, and fully compliant ANSI X3.263 TP-PMD physical sub-layer.
Bundled optional an AMR V.90 56K Fax/Modem card for internet communication.
2MB Flash ROM on board, provides complete Advance Configuration Power Interface (ACPI) and Legacy PMU; Ultra DMA 66/100 ; fully compliant with PC'97 and PC98 Spec.
Provides ATX power connector supports various functions of ATX Power such as Suspend, Shutdown, Wake on LAN, Wake on Modem, Wake on Alarm, Interrupt Wake-Up from Keyboard/Mouse, and Keyboard Power On/Off.
Built-in Hardware Monitor circuit supports Thermal, Power and Fan Speed monitor.
Supports PC99 Color Connector for easy identification of peripheral devices.
Optional external USB card for extra USB ports connection.
Bundled 3Deep, to deliver the precise imagery and display accurate color in your monitor.
Bundled Super Voice for Fax/Modem and Voice applications; MediaRing Talk for Internet Phone communication.
Marsh Posté le 16-07-2001 à 13:25:06
SIS c'est pas du tout pourri, au contraire!!!
Vous avez déjà testé un CUSI-FX? c'est de la balle, avec un chipset SIS, il y a le VGA,sound,LAN, tout integré, et c'est vraiment pas mal du tout pour des up-grade pas tropcher...
Marsh Posté le 16-07-2001 à 15:38:19
c thekiller qui est pourri, la qualite ne se paie pas, elle recompense l'expertise et la rigueur, choses qui manque cruellement a letueur...
et pas en petite quantite...
dommage qu'il ne fassent pas de prix sur le QI chez Risko!
Marsh Posté le 16-07-2001 à 16:45:07
On se demande pourquoi tant de gens dépensent autant d'argent pour faire des truc pourris, il ferait mieux de me le filer leur pognon
 pour en rajouter, chacun y trouvera son compte, et si les cartes mères sys sont fiables et moins chères, comme le dit l'expression, y a pas photo, j'irai au moins cher.
[edtdd]--Message édité par Romeo309--[/edtdd]
Marsh Posté le 16-07-2001 à 16:49:59
Marsh Posté le 16-07-2001 à 12:53:10
Our HK Correspondent told us that at HK Golden 1st floor, you can buy the PCCHIPS M830LR mainboard for HK $540 (~ USD 69). M830LR is a SiS735 mainboard. It looks like this is a pretty good buy in terms of price/performance.
Check out OC WorkBench for more details.
550frs la mobo sys735
a hong kong bien sur mais comme je part la bas cet ete
en tt cas ce chipset sera vraiment tres bon marche
[edtdd]--Message édité par pierrotlemaboule--[/edtdd]
mon topic de vente
