CHERCHE PERSONNE POUR M AIDER CA SERAI COOL MERCI - Overclocking, Cooling & Modding
MarshPosté le 15-04-2001 à 23:10:15
BORDELE JE NARRIVE PAS A ALLER PLUS LOIN QUE 115 FSB AVEC MA CARTE MERE GIGA BYTE 7ZX SERIES ET JE NE PEUX CHANGER DE COEF. MEME AVEC SOFTFSB UNE/MA CARTE EST PAS DANS LA LISTE DEUX/MON PLL N EST PAS DANS LA LISTE AUSSI J AI RELIELES POINT L1 DU CPU AVEC DU REPARATEUR DE PISTE A L ARGENT SOLUTION SOLUTION SOLUTION SOLUTION SOLUTION SOLUTION SOLUTION
Marsh Posté le 15-04-2001 à 23:10:15
