On Wed 20/02/2013 11:24:37 GMT your computer crashed crash dump file: C:\Windows\Minidump\022013-21840-01.dmp This was probably caused by the following module: hal.dll (hal+0x12A3B) Bugcheck code: 0x124 (0x0, 0xFFFFFA800FE2D028, 0xB2000000, 0x11000402) Error: WHEA_UNCORRECTABLE_ERROR file path: C:\Windows\system32\hal.dll product: Microsoft® Windows® Operating System company: Microsoft Corporation description: Hardware Abstraction Layer DLL Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA). This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Wed 20/02/2013 11:24:37 GMT your computer crashed crash dump file: C:\Windows\memory.dmp This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3) Bugcheck code: 0x124 (0x0, 0xFFFFFA800FE2D028, 0xB2000000, 0x11000402) Error: WHEA_UNCORRECTABLE_ERROR file path: C:\Windows\system32\hal.dll product: Microsoft® Windows® Operating System company: Microsoft Corporation description: Hardware Abstraction Layer DLL Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA). This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sat 16/02/2013 02:01:13 GMT your computer crashed crash dump file: C:\Windows\Minidump\021613-21216-01.dmp This was probably caused by the following module: hal.dll (hal+0x12A3B) Bugcheck code: 0x124 (0x0, 0xFFFFFA800FE19028, 0xB2000000, 0x74000402) Error: WHEA_UNCORRECTABLE_ERROR file path: C:\Windows\system32\hal.dll product: Microsoft® Windows® Operating System company: Microsoft Corporation description: Hardware Abstraction Layer DLL Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA). This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Fri 15/02/2013 2211 GMT your computer crashed crash dump file: C:\Windows\Minidump\021513-20576-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC40) Bugcheck code: 0x101 (0x11, 0x0, 0xFFFFF880009B3180, 0x4) Error: CLOCK_WATCHDOG_TIMEOUT file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Conclusion 4 crash dumps have been found and analyzed. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Marsh Posté le 20-02-2013 à 12:55:15
Signature du problème :
Nom d’événement de problème: BlueScreen
Version du système: 6.1.7601.2.1.0.256.1
Identificateur de paramètres régionaux: 2060
Informations supplémentaires sur le problème :
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA800FE2D028
BCP3: 00000000B2000000
BCP4: 0000000011000402
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Fichiers aidant à décrire le problème :
C:\Users\KD\AppData\Local\Temp\WER-23524-0.sysdata.xml
Lire notre déclaration de confidentialité en ligne :
http://go.microsoft.com/fwlink/?li [...] cid=0x040c
Si la déclaration de confidentialité en ligne n’est pas disponible, lisez la version hors connexion :
C:\Windows\system32\fr-FR\erofflps.txt
est ce que qq'un pourrait me dire de quoi ça provient merci
- - - - - - - - - - -Fusion. Pas bien de faire du flood - - - - - - - - - - -
file:///CUsers/KD/Desktop/WhoCrashedOutput.htm
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
Conclusion
