MSI P965 Neo F
MSI P965 Neo F - Carte mère - Hardware
Marsh Posté le 07-05-2008 à 01:20:36
Je possède 2*1Go DDR2 G skill Pc 6400 sur cette carte, je voudrais passer a 4 Go mais les infos que je trouve sur le site constructeur sont plus que vagues.
Sur le site français je trouve ça :
Mémoire
• 4 x DIMM Dual DDR2 533/667/800 Mhz
Mémoire max: 8 GB
Et sur le site US :
Chipset
Intel® P965 Chipset
•  Support Dual channel DDR2 533/667/800 memory interface up to 8GB (with DDR2 800, memory only up to 2GB)
  Main Memory
•  Supports 4 unbuffered DIMM of 1.8 Volt DDR2 SDRAM
•  Supports up to 4GB 533/667memory size (with DDR2 800, memory only up to 4GB)
•  Support Dual Channel DDR2 533/677/800MHz and up
      Due to the High Performance Memory design, motherboards or system configurations may or may not operate smoothly at the JEDEC (Joint Electron Device Engineering Council) standard settings (BIOS Default on the motherboard) such as DDR2 voltage, memory speeds and memory timing. Please confirm and adjust your memory setting in the BIOS accordingly for better system stability.
Example: Kingston HyperX DDR2-800 PC6400 operates at 2.0V, 4-4-4-12.
For more information about specification of high performance memory modules, please check with your Memory Manufactures for more details.
Alors au final ...... Quelqu'un en sait davantage s'il vous plait ?
