Plantage systematique + rapport whocrashed
Plantage systematique + rapport whocrashed - Matériels & problèmes divers - Hardware
Marsh Posté le 26-04-2014 à 18:44:57
bonjour,
depuis quelques jours mon pc plante chaque fois que je lance une vidéo sur youtube avec chrome (je n'ai pas essayé avec d'autres navigateurs...)
J'ai mis à jour le driver de ma carte graphique (nvidia 8800 GT) en vain.
Voici ce que me dit Whocrashed, mais je ne sais pas interpréter.
Merci de votre aide. D'avance désolé si je n'ai pas posté au bon endroit.
On Sat 26/04/2014 00:46:12 GMT your computer crashed
crash dump file: C:\Windows\memory.dmp
uptime: 07:55:47
This was probably caused by the following module: ntkrnlmp.exe (nt!KeRemoveQueueEx+0x1849)
Bugcheck code: 0x116 (0xFFFFFA8008DB74E0, 0xFFFFF880053BC6C0, 0x0, 0x2)
Error: VIDEO_TDR_ERROR
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Fri 25/04/2014 16:44:21 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042514-23025-01.dmp
uptime: 1 day, 00:40:44
This was probably caused by the following module: Unknown (0xFFFFF88004C297F2)
Bugcheck code: 0x116 (0xFFFFFA8008751130, 0xFFFFF880053796C0, 0x0, 0x2)
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: Unknown .
Google query: Unknown VIDEO_TDR_ERROR
On Thu 24/04/2014 16:03:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042414-22027-01.dmp
uptime: 04:06:41
This was probably caused by the following module: ntoskrnl.exe (nt+0x7E6F9)
Bugcheck code: 0x116 (0xFFFFFA8007EC34E0, 0xFFFFF8800538D6C0, 0x0, 0x2)
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Marsh Posté le 26-04-2014 à 18:57:52
Bonjour jazziest et bienvenue sur HFR :o ,
Flash Player est-il à jour? Et en désactivant l'accélération matérielle?
Message édité par Tigrou le 26-04-2014 à 18:59:33
Feedback - Stacy's mom
