BlueScreen intempestifs et imprévisibles
BlueScreen intempestifs et imprévisibles - Matériels & problèmes divers - Hardware
Marsh Posté le 31-05-2015 à 16:41:45
Bonjour !
Je viens vous voir car j'ai un problème avec ma config, et j'en ai marre de m'arracher les cheveux avec.
De temps en temps, sans que je puisse établir de patern particulier, mon ordinateur blueScreen.
Voici les derniers rapport "WhoCrashed" :
Spoiler :
windows version: Windows 8.1 , 6.2, build: 9200
windows dir: C:\Windows
Hardware: All Series, ASUS, ASUSTeK COMPUTER INC., Z87-A
CPU: GenuineIntel Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 8455995392 total
VM: 2147352576, free: 1858465792
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sun 31/05/2015 13:14:34 GMT your computer crashed
crash dump file: C:\Windows\Minidump\053115-16203-01.dmp
This was probably caused by the following module: hal.dll (hal+0x37213)
Bugcheck code: 0x124 (0x0, 0xFFFFE0014F363028, 0xBF800000, 0x124)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0xCF)
On Sun 31/05/2015 10:54:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\053115-19484-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE001393EF028, 0xBF800000, 0x124)
On Fri 29/05/2015 11:34:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052915-17000-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE0003AFFA028, 0xBF800000, 0x124)
On Thu 28/05/2015 13:36:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052815-16531-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE001A2BF6028, 0xBF800000, 0x124)
On Thu 28/05/2015 11:37:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052815-15984-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE00187B1D028, 0xBF800000, 0x124)
On Wed 27/05/2015 17:41:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052715-16796-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE0005ABA3028, 0xBF800000, 0x124)
On Sat 16/05/2015 23:50:12 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051715-35453-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE001237CC028, 0xBF800000, 0x124)
On Sat 16/05/2015 19:06:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051615-35125-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE001D64C1028, 0xBF800000, 0x124)
On Fri 15/05/2015 15:41:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051515-34171-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE0009D1A9028, 0xBF800000, 0x124)
Conclusion
19 crash dumps have been found and analyzed. Only 10 are included in this report. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Voici ma config :
Spoiler :
- Carte mère : Asus Z87-A
- Processeur : Intel I5 4670K non-overclocké
- Boitier : http://www.materiel.net/boitier-pc [...] 28633.html  ( Le ventilateur 250mm est mort :s )
- 4 Disques durs, dont 1 hybride
- GTX 770
- 8Go de RAM DDR3
- Une Alim Corsair GS700 ( et donc 700W ) [nb : elle commence à être un peu vieille, genre 5ans je pense]
J'ai pourtant essayé de le pousser à bout, pour identifier le problème, mais je n'ai rien trouvé.
- Verification de la RAM (outil windows 8)
- Bourinage CPU (outil Intel)
- Benchmark graphiques (3dmark)
J'utilise mon PC pour jouer, virtualiser, et pour de la bureautique "basique".
Ce qui est bizare, c'est que parfois je bluescreen en jeux, mais souvent sur le bureau, même lorsque je n'utilise pas le PC. ( donc idle sur bureau windows, avec eventuellement chrome lancé )
Pour vous donner une idée, the Witcher 3 et GTA5 ne provoquent pas plus de problèmes que Word ou Virtualbox.
J'ai commencé par mettre en cause mon Alim qui ne pousserais peu être pas assez, mais d'après ce site, tout semble être bon ...
http://www.extreme.outervision.com [...] orlite.jsp
Pour les températures, mon CPU, bien qu'avec le ventirad stock, ne chauffe pas outre-mesure ( en tout cas pas plus que ce qu'intel préconise : ~=73°C )
En idle, je suis entre 45 et 55°C, et en jeu, je monte parfois à 75°C
( donnée OpenHardwareMonitor )
Mais ceci-dis, je n'ai jamais le relevé au moment du bluescreen, j'ai aucune certitude.
J'ai également mis en cause le faîte que j'ai 1 écran sur mon chipset graphique processeur ( port de ma CM ) et deux autres sur ma carte graphique, mais en désactivant dans le BIOS l'option qui me l'autorise, écran débranché, je bluescreen aussi.
J'ai fais une mise a jour BIOS il y'a 2 semaines, mes drivers sont à jours, et la poussière est à peu près faite dans mon PC.
Au cas où, voici un rapport CrystalDisk :
http://image.noelshack.com/fichier [...] e-disk.png
Dites moi si vous avez besoin de quoi que ce soit, je vous le fait !
Un grand merci d'avance !
Olbaid
