D3D marche plus depuis reinstall total HDD - Matériel - Video & Son
MarshPosté le 30-09-2007 à 23:57:55
bonjour
voila depuis ma reinstallation totale du mon PC j ai un pb avec les jeux utilisant le D3D
j'ai a priori un PC a jour avec un driver CM nforce2 a jour , un driver Radeon X800GTO a jour et un directx à jour
mais ca marche pas sur des jeux recents comme HL2 (HLife1 marche)
ci joint mon dxdiag
merci de votre aide
------------------ System Information ------------------ Time of this report: 9/30/2007, 23:58:44 Machine name: RENO Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254) Language: French (Regional Setting: French) System Manufacturer: ASUSTeK Computer INC. System Model: A7N8X2.0 BIOS: Phoenix - AwardBIOS v6.00PG Processor: AMD Athlon(tm) XP 2600+, MMX, 3DNow, ~2.1GHz Memory: 1024MB RAM Page File: 812MB used, 1647MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.2180 32bit Unicode
------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Direct3D 7 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x80004005 (Generic failure) Direct3D 8 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code) Direct3D 9 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code) Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found.
---------------------------- DirectPlay Service Providers ---------------------------- DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180) IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180) Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180) Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run DirectPlay Test Result: Not run Registry: OK
------------------- DirectPlay Adapters ------------------- DirectPlay8 Serial Service Provider: COM1 DirectPlay8 Serial Service Provider: COM2 DirectPlay8 TCP/IP Service Provider: Connexion au réseau local 2 - IPv4 -
------------------ DirectX Components ------------------ ddraw.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 266240 bytes ddrawex.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 27136 bytes dxapi.sys: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 10496 bytes d3d8.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 1179648 bytes d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 8192 bytes d3d9.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 1689088 bytes d3dim.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 436224 bytes d3dim700.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 825344 bytes d3dramp.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 590336 bytes d3drm.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 350208 bytes d3dxof.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 47616 bytes d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 34816 bytes dplay.dll: 5.00.2134.0001 French Final Retail 8/5/2004 14:00:00 33040 bytes dplayx.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 229888 bytes dpmodemx.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 24064 bytes dpwsock.dll: 5.00.2134.0001 English Final Retail 8/5/2004 14:00:00 42768 bytes dpwsockx.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 57856 bytes dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 30208 bytes dpnsvr.exe: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 18432 bytes dpnet.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 375296 bytes dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 3584 bytes dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 3584 bytes dpvoice.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 213504 bytes dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 83456 bytes dpvvox.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 116736 bytes dpvacm.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 21504 bytes dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 35328 bytes dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 60928 bytes dpserial.dll: 5.00.2134.0001 French Final Retail 8/5/2004 14:00:00 54032 bytes dinput.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 165376 bytes dinput8.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 187904 bytes dimap.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 44032 bytes diactfrm.dll: 5.01.2600.0000 French Final Retail 8/5/2004 14:00:00 395264 bytes joy.cpl: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 70144 bytes gcdef.dll: 5.01.2600.0000 French Final Retail 8/5/2004 14:00:00 77824 bytes pid.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 35328 bytes gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 01:08:22 10624 bytes dsound.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 367616 bytes dsound3d.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 1294336 bytes dswave.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 19456 bytes dsdmo.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 181760 bytes dsdmoprp.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 72192 bytes dmusic.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 104448 bytes dmband.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 28672 bytes dmcompos.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 61440 bytes dmime.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 181248 bytes dmloader.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 35840 bytes dmstyle.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 105984 bytes dmsynth.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 103424 bytes dmscript.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 82432 bytes dx7vb.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 619008 bytes dx8vb.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 1227264 bytes dxdiagn.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 2113536 bytes mfc40.dll: 4.01.0000.6140 English Final Retail 8/5/2004 14:00:00 924432 bytes mfc42.dll: 6.02.4131.0000 English Final Retail 8/5/2004 14:00:00 1028096 bytes wsock32.dll: 5.01.2600.2180 French Final Retail 8/5/2004 14:00:00 25088 bytes amstream.dll: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 70656 bytes devenum.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 59904 bytes dxmasf.dll: 6.04.0009.1133 French Final Retail 8/24/2006 13:17:20 500278 bytes mciqtz32.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 35328 bytes mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 148992 bytes msdmo.dll: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 14336 bytes encapi.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 20480 bytes qasf.dll: 9.00.0000.3250 French Final Retail 8/5/2004 14:00:00 237568 bytes qcap.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 192512 bytes qdv.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 279040 bytes qdvd.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 386048 bytes qedit.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 563200 bytes qedwipes.dll: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 733696 bytes quartz.dll: 6.05.2600.2749 French Final Retail 8/30/2005 05:55:43 1293312 bytes strmdll.dll: 4.01.0000.3936 French Final Retail 8/24/2006 13:19:40 246814 bytes iac25_32.ax: 2.00.0005.0053 English Final Retail 8/5/2004 14:00:00 199680 bytes ir41_32.ax: 4.51.0016.0003 English Final Retail 8/5/2004 14:00:00 848384 bytes ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/5/2004 14:00:00 120320 bytes ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/5/2004 14:00:00 338432 bytes ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/5/2004 14:00:00 755200 bytes ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/5/2004 14:00:00 200192 bytes ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/5/2004 14:00:00 183808 bytes ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/5/2004 14:00:00 154624 bytes mswebdvd.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 204800 bytes ks.sys: 5.03.2600.2180 French Final Retail 8/3/2004 23:15:22 140928 bytes ksproxy.ax: 5.03.2600.2180 French Final Retail 8/4/2004 00:55:04 130048 bytes ksuser.dll: 5.03.2600.2180 French Final Retail 8/4/2004 00:54:30 4096 bytes stream.sys: 5.03.2600.2180 French Final Retail 8/3/2004 23:08:04 48640 bytes mspclock.sys: 5.03.2600.2180 French Final Retail 8/4/2004 00:58:40 5376 bytes mspqm.sys: 5.01.2600.2180 French Final Retail 8/4/2004 00:58:42 4992 bytes mskssrv.sys: 5.03.2600.2180 French Final Retail 8/4/2004 00:58:42 7552 bytes swenum.sys: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 4352 bytes mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 118272 bytes msvidctl.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 1433600 bytes vbisurf.ax: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 30720 bytes msyuv.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 17408 bytes wstdecod.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 51200 bytes
DirectShow Filters: WMAudio Decoder DMO,0x00800800,1,1,, WMSpeech Decoder DMO,0x00600800,1,1,, Mpeg4s Decoder DMO,0x00800001,1,1,, WMV Screen decoder DMO,0x00800001,1,1,, WMVideo Decoder DMO,0x00800001,1,1,, Mpeg43 Decoder DMO,0x00800001,1,1,, Mpeg4 Decoder DMO,0x00800001,1,1,, WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000 Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749 DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180 Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749 WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250 AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749 WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749 Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055 Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487 AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180 WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180 WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749 Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055 WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000 Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487 MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749 SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749 MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050 MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180 ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000 Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749 MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749 File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250 WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000 DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180 Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487 Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749 Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000 WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250 NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749 Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250 Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749 Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180 Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180 Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749 WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180 Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749 WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250 WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180 Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487 File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180 WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000 DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180 Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180 AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749 .RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250 WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000 MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180 DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180 Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053 Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250 ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250 9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000 Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180 Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180 WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000 WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180 Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180 Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180 AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749 Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749 QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749 Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749 MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749 Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749 File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749 XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250 AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180 Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749 File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749 File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749 WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180 QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749 MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749 Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003 Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Transformateurs de répartition de données WDM: Suppresseur d'écho acoustique (Noyau Microsoft),0x00000000,0,0,, Synthétiseur de table de sons GC noyau Microsoft,0x00200000,1,1,,5.03.2600.2180 Synthétiseur DLS du noyau Microsoft,0x00200000,1,1,,5.03.2600.2180 Filtre de décodeur DRM (Noyau Microsoft),0x00200000,1,1,,5.03.2600.2180
Video Compressors: MSScreen encoder DMO,0x00600800,1,1,, WMVideo9 Encoder DMO,0x00600800,1,1,, MSScreen 9 encoder DMO,0x00600800,1,1,, DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180 Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055 MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749 Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180 Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180 Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180 Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180 Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180 Codec Intel IYUV,0x00200000,1,1,qcap.dll,6.05.2600.2180 Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180 Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180 Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180 Microsoft Vidéo 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors: WM Speech Encoder DMO,0x00600800,1,1,, WMAudio Encoder DMO,0x00600800,1,1,, IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749 IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749 PCM,0x00200000,1,1,quartz.dll,6.05.2600.2749 Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749 ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749 DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749 Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749 Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749 GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749 Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749 CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749 CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749 MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Marsh Posté le 30-09-2007 à 23:57:55
bonjour
ci joint mon dxdiag
merci de votre aide
System Information
Machine name: RENO
Memory: 1024MB RAM
DxDiag Notes
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON X800 GTO
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Graphics Processor AGP (0x554F)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_554F&SUBSYS_1600174B&REV_00
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (85Hz)
Monitor: Écran Plug-and-Play
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6719 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/22/2007 04:07:59, 268800 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 8/22/2007 04:07:39, 2417664 bytes
Device Identifier: {D7B71EE2-160F-11CF-C46E-0A36A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x554F
SubSys ID: 0x1600174B
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Failure at step 8 (Creating 3D Device): HRESULT = 0x80004005 (Generic failure)
D3D8 Test Result: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
D3D9 Test Result: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
Sound Devices
Description: Creative Sound Blaster PCI
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1274&DEV_5880&SUBSYS_80011274&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: es1371mp.sys
Driver Version: 5.01.3612.0000 (English)
WHQL Logo'd: Yes
Date and Size: 6/3/2002 11:18:32, 40832 bytes
Other Files:
Driver Provider: Creative Technology Ltd.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
Creative Sound Blaster PCI, Software (Kernel Mode), Output, DLS, Internal
Mappeur MIDI Microsoft [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
SynthÚ. SW table de sons GS Mic [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Émulé], Hardware (Not Kernel Mode), Output, No DLS, External
Creative Sound Blaster MPU-401 [Émulé], Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401 [Émulé], Hardware (Not Kernel Mode), Input, No DLS, External
Creative Sound Blaster MPU-401 [Émulé], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Souris
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Clavier
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ Concentrateur USB racine
| Vendor/Product ID: 0x10DE, 0x0067
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/5/2004 14:00:00, 57600 bytes
| Driver: usbd.sys, 8/5/2004 14:00:00, 4736 bytes
Gameport Devices
+ Bus PCI
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/5/2004 14:00:00, 68608 bytes
+-+ Port jeu standard
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/4/2004 01:08:22, 10624 bytes
PS/2 Devices
+ Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/5/2004 14:00:00, 54400 bytes
| Driver: kbdclass.sys, 8/5/2004 14:00:00, 25216 bytes
+ Pilote clavier de Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:55:12, 40840 bytes
+ Souris compatible PS/2
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/5/2004 14:00:00, 23680 bytes
+ Pilote souris de Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Registry: OK
DirectPlay Adapters
DirectPlay Voice Codecs
Voxware VR12 1,4 Kbit/s
Voxware SC06 6,4 Kbit/s
Voxware SC03 3,2 Kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 256.3 GB
Total Space: 302.2 GB
File System: NTFS
Model: SiI RAID 0 Set 0 SCSI Disk Device
Drive: F:
Free Space: 1.4 GB
Total Space: 3.0 GB
File System: NTFS
Drive: D:
Model: PIONEER DVD-RW DVR-106D
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (French), 8/5/2004 14:00:00, 49536 bytes
Drive: E:
Model: HG3041P VCO510J SCSI CdRom Device
System Devices
Name: Creative AudioPCI (ES1371,ES1373) (WDM)
Device ID: PCI\VEN_1274&DEV_5880&SUBSYS_80011274&REV_04\4&3B1D9AB8&1&4040
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (French), 8/4/2004 00:54:30, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (French), 8/4/2004 00:55:04, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (French), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (French), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\es1371mp.sys, 5.01.3612.0000 (English), 6/3/2002 11:18:32, 40832 bytes
Name: NVIDIA nForce2 Memory Controller
Device ID: PCI\VEN_10DE&DEV_01EF&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&05
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EE&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&02
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01ED&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EC&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&04
Driver: n/a
Name: NVIDIA nForce2 Ultra 400 Memory Controller
Device ID: PCI\VEN_10DE&DEV_01EB&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&01
Driver: n/a
Name: NVIDIA nForce2 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_01E8&SUBSYS_00000000&REV_C1\3&13C0B0C5&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\nv_agp.SYS, 4.12.0001.0436 (English), 4/2/2004 15:40:00, 21760 bytes
Driver: C:\WINDOWS\system32\NVCOG.DLL, 1.00.0000.0015 (English), 4/2/2004 15:40:00, 32256 bytes
Name: Pont CPU hôte standard PCI
Device ID: PCI\VEN_10DE&DEV_01E0&SUBSYS_00000000&REV_C1\3&13C0B0C5&0&00
Driver: n/a
Name: Contrôleurs hôte IEEE 1394 compatible OHCI
Device ID: PCI\VEN_10DE&DEV_006E&SUBSYS_809A1043&REV_A3\3&13C0B0C5&0&68
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 23:46:40, 6400 bytes
Name: Pont PCI vers PCI standard PCI
Device ID: PCI\VEN_10DE&DEV_006D&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&60
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (French), 8/5/2004 14:00:00, 68608 bytes
Device ID: PCI\VEN_10DE&DEV_006C&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&40
Name: Contrôleur hôte PCI vers USB standard étendu
Device ID: PCI\VEN_10DE&DEV_0068&SUBSYS_0C111043&REV_A4\3&13C0B0C5&0&12
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (French), 8/4/2004 02:54:44, 77312 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 7168 bytes
Name: Contrôleur hôte USB OpenHCD standard
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_0C111043&REV_A4\3&13C0B0C5&0&11
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_0C111043&REV_A4\3&13C0B0C5&0&10
Name: NVIDIA nForce Networking Controller
Device ID: PCI\VEN_10DE&DEV_0066&SUBSYS_80A71043&REV_A1\3&13C0B0C5&0&20
Driver: C:\WINDOWS\system32\DRIVERS\NVENET.sys, 4.14.0001.0416 (English), 1/29/2004 01:45:50, 93764 bytes
Driver: C:\WINDOWS\system32\NVCOE.DLL, 1.00.0000.0014 (English), 1/29/2004 02:22:48, 31744 bytes
Name: NVIDIA nForce2 ATA Controller (v2.6)
Device ID: PCI\VEN_10DE&DEV_0065&SUBSYS_0C111043&REV_A2\3&13C0B0C5&0&48
Driver: C:\WINDOWS\system32\DRIVERS\nvatabus.sys, 5.10.2600.0446 (English), 6/3/2004 10:40:46, 79360 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 6/3/2004 10:40:48, 294400 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0064&SUBSYS_0C111043&REV_A2\3&13C0B0C5&0&09
Driver: n/a
Name: Pont ISA standard PCI
Device ID: PCI\VEN_10DE&DEV_0060&SUBSYS_00000000&REV_A4\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (French), 8/5/2004 14:00:00, 36224 bytes
Name: 3Com 3C920B-EMB Integrated Fast Ethernet Controller
Device ID: PCI\VEN_10B7&DEV_9201&SUBSYS_80AB1043&REV_40\4&35344E25&1&0860
Driver: C:\WINDOWS\system32\DRIVERS\el90Xbc5.SYS, 4.31.0000.0000 (English), 8/13/2002 21:27:22, 74338 bytes
Name: Silicon Image SiI 3112 SATARaid Controller
Device ID: PCI\VEN_1095&DEV_3112&SUBSYS_61121095&REV_02\4&3B1D9AB8&1&5840
Driver: C:\WINDOWS\system32\DRIVERS\SI3112r.sys, 1.00.0056.0000 (French), 1/12/2006 12:56:56, 102528 bytes
Driver: C:\WINDOWS\system32\DRIVERS\SiWinAcc.sys, 1.00.0000.0011 (French), 11/1/2004 12:21:32, 10368 bytes
Driver: C:\WINDOWS\system32\SilSupp.cpl, 3.00.0021.0000 (French), 10/19/2005 12:17:00, 77824 bytes
Name: RADEON X800 GTO Secondary
Device ID: PCI\VEN_1002&DEV_556F&SUBSYS_1601174B&REV_00\4&102AC5BC&1&01F0
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6719 (French), 8/22/2007 04:07:39, 2417664 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0012 (English), 8/22/2007 03:13:01, 49152 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 8/22/2007 04:33:04, 46432 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 5/30/2007 18:43:05, 2096 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 4/18/2007 14:19:24, 929 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 4/18/2007 14:19:24, 1311202 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativdkxx.vp, 4/18/2007 14:19:50, 2096 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6719 (English), 8/22/2007 04:07:59, 268800 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0350 (English), 8/22/2007 03:11:38, 450560 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 8/22/2007 03:59:04, 26112 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0523 (English), 8/22/2007 03:47:23, 3091392 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0010.0164 (English), 8/22/2007 03:35:39, 1586816 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 8/14/2007 23:11:53, 156671 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dat, 8/22/2007 03:35:20, 3107788 bytes
Driver: C:\WINDOWS\system32\ativva5x.dat, 8/22/2007 03:35:20, 3107788 bytes
Driver: C:\WINDOWS\system32\ativva6x.dat, 8/22/2007 03:35:20, 972072 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 8/22/2007 03:56:19, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 8/22/2007 03:17:54, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 17:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4176 (English), 8/22/2007 03:57:14, 487424 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4175 (English), 8/22/2007 03:58:42, 122880 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2522 (English), 8/22/2007 03:59:26, 143360 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0016 (English), 3/23/2007 22:23:23, 77824 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2512 (English), 8/22/2007 03:58:56, 43520 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0064 (French), 8/22/2007 03:19:38, 266240 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 4/12/2007 03:33:47, 7069 bytes
Driver: C:\WINDOWS\system32\ATIDEMGX.dll, 2.00.2789.38075 (French), 8/22/2007 04:09:12, 352256 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.6847 (English), 8/22/2007 03:21:01, 5435392 bytes
Driver: C:\WINDOWS\system32\atiok3x2.dll, 6.14.0010.0001 (French), 8/22/2007 03:15:37, 172032 bytes
Driver: C:\WINDOWS\system32\atioglx2.dll, 6.14.0010.6847 (English), 8/22/2007 03:48:15, 8306688 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4005 (English), 8/22/2007 04:07:22, 307200 bytes
Driver: C:\WINDOWS\atiogl.xml, 5/3/2007 19:52:52, 11557 bytes
Device ID: PCI\VEN_1002&DEV_554F&SUBSYS_1600174B&REV_00\4&102AC5BC&1&00F0
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Audio Capture Sources:
Creative Sound Blaster PCI,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Creative Sound Blaster MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Synthé. SW table de sons GS Mic,0x00200000,1,0,quartz.dll,6.05.2600.2749
Périphériques de capture de flux WDM:
,0x00000000,0,0,,
Creative Sound Blaster MPU-401,0x00200000,2,2,,5.03.2600.2180
Creative Sound Blaster PCI,0x00200000,2,2,,5.03.2600.2180
Périphériques de répartition de rendu WDM:
,0x00000000,0,0,,
Périphériques de répartition de mélangeur WDM:
Mélangeur audio Wave de noyau Microsoft,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.2600.2749
Périphériques système répartis WDM:
MPU-401,0x00200000,3,2,,5.03.2600.2180
Creative Sound Blaster PCI,0x00200000,10,2,,5.03.2600.2180
