Faire des films à moto [expérience perso] - Matériel - Video & Son
Marsh Posté le 19-12-2006 à 21:29:53
Précisions sur la mini caméra :
21CWSHR
1/3" DSP Color higher grade Sony CCD, (Super HAD, EX-View HAD version)
It is the world's first High performance Color camera in a bullet style. It is noticeable in that the unit is used with the most high end 1/3" Color CCD chip set among the list of Sony grade. It is highly recommended for a special requirement where need more precise, more bright and high resolution
Lens Exchangeable
The smart idea with user friendly housing mechanism make it possible to adapt a wide range of different focal lens. Installer can change the lens with no special skill, very easily without changing the camera in order to fix the exact angle of view and suitable focal distance.
Condensation free
Our weatherproof versions provide a perfect solution for moisture leakage problem against any harsh weather condition. The camera is assembled in a clear vacuum status and further protected to stop moisture or water smearing into the camera under the continuous heating and cooling conditions by the fluctuating sunny and rainy weather.
Compact Size
Incorporating all innovative features, those are used with 1/3" CCD format and made with the world's smallest size.
Beautiful design
Our fine craftsmanship reaches not only to the picture quality and compact size but also to the products GD (Good Design). All we manufacture have their own unique face and shape firstly aiming to best fit to the environment decorable to any place.
Easy Installation
Universal type of mounting structure plus user friendly developed camera design provide a useful way of installation mountable to any place
Reverse Polarity protection built in
http://www.sports-camera.com/21CWSHR.pdf
Marsh Posté le 19-12-2006 à 21:47:24
perso je fait partis d'un club de paint ball et archos a une excellente "camera stylo" que l'on fixe au canon et qui donne de tres bons resultats
maintenant a moto vu la vitesse j'en sais rien....
Marsh Posté le 19-12-2006 à 23:57:53
Je ne connais pas cette marque.
C'est une caméra vraiment miniaturisée dans un stylo ?
Marsh Posté le 19-12-2006 à 21:23:15
Bonsoir !
![:hello: :hello:](https://forum-images.hardware.fr/icones/smilies/hello.gif)
Il y a quelques temps j'ai acheté un caméscope Canon MV960 en vue de faire des vidéos à moto. J'ai pris ce caméscope car :
- il n'est pas trop cher
- il m'a l'air de qualité honnête
- il dispose d'une entrée analogique (AV IN) ce qui n'est pas très répandu, nécessaire pour pouvoir enregistrer les images provenant de la mini caméra fixée sur le casque
L'étape suivante consistait à trouver une mini caméra. J'ai écumé le net et les prix me paraissaient assez exorbitants !
Jusqu'à ce qu'un pote me conseille un site sur lequel il avait acheté lui-même sa mini caméra : http://www.sports-camera.com/
Oui je sais, spam tout ça, enfin bon là je fais plus un feedback que du spam. Si ce topic est considéré comme étant du spam, je le dégage
Bref, le site est tout pourri mais les prix sont raisonnables et le service est de qualité. La boutique est située en Irlande du nord, peut-être que ça explique les prix intéressants.
J'ai passé commande dimanche soir et j'ai reçu la caméra tout à l'heure par UPS, chapeau pour la rapidité !
Donc tout marche bien, il ne me reste plus qu'à fixer la caméra sur le casque (une fixation, autocollante d'un côté et velcrotisé de l'autre, est fournie) et à aller faire un tour de moto
La dernière étape consistera à trouver un microphone de qualité, car un pote qui a déjà réalisé ce montage a été très déçu par la qualité du micro fourni avec le caméscope ou la mini caméra. Le son sature très vite...
Une ultime étape constisterait à trouver le moyen d'alimenter le caméscope à partir de la batterie de ma moto, mais j'avoue que je n'aime pas trop les bidouillages électriques
Voilà, si vous avez des questions n'hésitez pas !
Message édité par Profil supprimé le 19-12-2006 à 21:25:00
