PB NERO DEFAUT DE CIBLE INTERNE
PB NERO DEFAUT DE CIBLE INTERNE - Matériel - Video & Son
Marsh Posté le 24-08-2005 à 13:40:51
HELLO
Je me permets de remettre un post sur ce pb car personne n'a vu mon message hier .
Donc j'ai un pb avec mon graveur et voici le log de nero
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 01/02/2001 15:10:18
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 16:21:30
Nero Version: 6.6.0.6
Recorder:             <PIONEER DVD-RW  DVR-109> Version: 1.50 - HA 1 TA 0 - 6.6.0.6
 Adapter driver:      <atapi>                   HA 1
 Drive buffer  :      2000kB
 Bus Type      :      default (0) -> ATAPI, detected: ATAPI
CD-ROM:               <PIONEER  DVD-RW  DVR-109 >Version: 1.50 - HA 1 TA 0 - 6.6.0.6
=== Scsi-Device-Map ===
DiskPeripheral       : Maxtor 2B020H1                   atapi Port 0 ID 0  DMA: On
DiskPeripheral       : ST3160021A                       atapi Port 0 ID 1  DMA: On
CdRomPeripheral      : PIONEER DVD-RW  DVR-109          atapi Port 1 ID 0  DMA: On
CdRomPeripheral      : MITSUMI CR-48X5TE                atapi Port 1 ID 1  DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW  DVR-109    O:   CDRom0
MITSUMI CR-48X5TE          G:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 1023MB (1047788kB)
Free physical memory: 547MB (560784kB)
Memory in use       : 46 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
24.8.2005
CD-ROM (ISO)
10:56:17 #1 Text 0 File Isodoc.cpp, Line 6168
 Iso document burn settings
 Determine maximum speed : FALSE
 Simulate                : FALSE
 Write                   : TRUE
 Finalize CD             : TRUE
 Multisession            : FALSE
 Burning mode            : DAO
 Mode                    : 1
 ISO Level               : 1 (Max. of 11 = 8 + 3 char)
 Character set           : ISO 9660
 Joliet                  : TRUE
 Allow pathdepth more than 8 directories : TRUE
 Allow more than 255 characters in path  : TRUE
 Write ISO9660 ;1 file extensions        : TRUE
10:56:18 #2 Text 0 File Burncd.cpp, Line 2870
 Protection contre les ruptures activés
10:56:18 #3 Text 0 File Reader.cpp, Line 127
 Reader running
10:56:18 #4 Text 0 File Writer.cpp, Line 122
 Writer PIONEER  DVD-RW  DVR-109  running
10:56:18 #5 ISO9660GEN -11 File geniso.cpp, Line 3286
 First writeable address = 0 (0x00000000)
10:56:18 #6 Text 0 File Burncd.cpp, Line 3155
 Turn on Disque entier, using CD-R/RW media
10:56:19 #7 Text 0 File DlgWaitCD.cpp, Line 257
 Last possible write address on media:   359848 ( 79:59.73)
 Last address to be written:             293222 ( 65:11.47)
10:56:19 #8 Text 0 File DlgWaitCD.cpp, Line 269
 Write in overburning mode: NO (enabled: CD)
10:56:19 #9 Text 0 File DlgWaitCD.cpp, Line 2311
 Recorder: PIONEER DVD-RW  DVR-109;
    CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
    ATIP Data:
      Special    Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
      Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
10:56:19 #10 Text 0 File DlgWaitCD.cpp, Line 431
 >>> Protocol of DlgWaitCD activities: <<<
10:56:19 #11 Text 0 File ThreadedTransferInterface.cpp, Line 829
 Setup items (after recorder preparation)
  0: TRM_DATA_MODE1 ()
     2 indices, index0 (150) not provided
     original disc pos #0 + 293223 (293223) = #293223/65:9.48
     relocatable, disc pos for caching/writing not required/ required, no patch infos
     -> TRM_ULTRARAW96_MODE1, 2448, config 4, wanted index0 0 blocks, length 293223 blocks [PIONEER  DVD-RW  DVR-109]
10:56:19 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1042
 Prepare recorder [PIONEER  DVD-RW  DVR-109] for write in raw writing
 DAO infos:
  MCN: ""
  TOCType: 0x00; Session Closed, disc fixated
  Tracks 1 to 1:
    1: TRM_ULTRARAW96_MODE1, 2448/0x04, FilePos             0        367200     718177104, ISRC ""
 DAO layout:
  __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
     -150 |  lead-in |   0 |    0x41 | 0x00
     -150 |        1 |   0 |    0x41 | 0x00
        0 |        1 |   1 |    0x41 | 0x00
   293223 | lead-out |   1 |    0x41 | 0x00
10:56:19 #13 Phase 24 File dlgbrnst.cpp, Line 1832
 Caching of files started
10:56:37 #14 Text 0 File Burncd.cpp, Line 4042
 Cache writing successful.
10:56:37 #15 Phase 25 File dlgbrnst.cpp, Line 1832
 Caching of files completed
10:56:37 #16 Phase 36 File dlgbrnst.cpp, Line 1832
 Burn process started at 32x (4 800 Ko/s)
10:56:37 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2604
 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:56:37 #18 Text 0 File Mmc.cpp, Line 16327
 StartDAO : CD-Text - Off
10:56:37 #19 Text 0 File Mmc.cpp, Line 21079
 Set BUFE: Buffer underrun protection -> ON
10:56:41 #20 Text 0 File Cdrdrv.cpp, Line 1284
 10:56:41.593 - PIONEER DVD-RW  DVR-109\H1 T0 : Queue again later
10:57:00 #21 Text 0 File Cdrdrv.cpp, Line 1284
 10:57:00.062 - PIONEER DVD-RW  DVR-109\H1 T0 : Queue again later
10:57:01 #22 Text 0 File Cdrdrv.cpp, Line 1284
 10:57:01.125 - PIONEER DVD-RW  DVR-109\H1 T0 : Queue again later
10:57:02 #23 SCSI -1061 File Cdrdrv.cpp, Line 1432
 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x042C0000
 Status:     0x04 (0x01, SCSI_ERR)
 HA-Status   0x00 (0x00, OK)
 TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
 Sense Key:  0x04 (KEY_HARDWARE_ERROR)
 Sense Code: 0x44
 Sense Qual: 0x8E
 CDB Data:   0x2A 0x00 0xFF 0xFF 0xD9 0x5D 0x00 0x00 0x1A 0x00 0x00 0x00
 Sense Data: 0x71 0x00 0x04 0x00 0x00 0x00 0x00 0x0E
             0x00 0x00 0x00 0x00 0x44 0x8E
10:57:02 #24 CDR -1061 File Writer.cpp, Line 311
 Internal target failure
10:57:02 #25 Text 0 File ThreadedTransfer.cpp, Line 228
 all writers idle, stopping conversion
10:57:02 #26 Text 0 File ThreadedTransfer.cpp, Line 222
 conversion idle, stopping reader
10:57:02 #27 Phase 38 File dlgbrnst.cpp, Line 1832
 Burn process failed at 32x (4 800 Ko/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 01/02/2001 15:10:12
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 22:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
on m'a dit qu'il y avait des soucis avec daemons tools mais après avoir viré le registre de d tools et le prog ca marche toujours pas est-ce que qqcn a une idée de solutions
merci  :wahoo:
Marsh Posté le 24-08-2005 à 13:42:49
Merci de (re)lire la Charte
<<< Collectif pour le stickage de l'apéro >>>
