ASUS P5LD2 et sortie optique (S/PDIF) - Matériel - Video & Son
Marsh Posté le 23-03-2006 à 18:44:07
Voici un copier/coller des messages de VLC qd je suis sur nrj 5.1 :
main debug: audio output is too slow (624123), trashing 32000us
main debug: audio output is too slow (592123), trashing 32000us
main debug: audio output is too slow (560123), trashing 32000us
main debug: audio output is too slow (528123), trashing 32000us
main debug: audio output is too slow (496123), trashing 32000us
main debug: audio output is too slow (464123), trashing 32000us
main debug: audio output is too slow (432123), trashing 32000us
main debug: audio output is too slow (400123), trashing 32000us
main debug: audio output is too slow (368123), trashing 32000us
main debug: audio output is too slow (336123), trashing 32000us
main debug: audio output is too slow (304123), trashing 32000us
main debug: audio output is too slow (272123), trashing 32000us
main debug: audio output is too slow (240123), trashing 32000us
main debug: audio output is too slow (208123), trashing 32000us
main debug: audio output is too slow (176123), trashing 32000us
main debug: audio output is too slow (144123), trashing 32000us
main debug: audio output is too slow (112123), trashing 32000us
main debug: audio output is too slow (80123), trashing 32000us
main debug: audio output is too slow (48123), trashing 32000us
main debug: audio output is too slow (-47877), trashing 32000us
main debug: audio output is too slow (-143877), trashing 32000us
main debug: audio output is too slow (-207877), trashing 32000us
main debug: audio output is too slow (-303877), trashing 32000us
main debug: audio output is too slow (648123), trashing 32000us
main debug: audio output is too slow (616123), trashing 32000us
main debug: audio output is too slow (584123), trashing 32000us
main debug: audio output is too slow (552123), trashing 32000us
main debug: audio output is too slow (520123), trashing 32000us
main debug: audio output is too slow (488123), trashing 32000us
main debug: audio output is too slow (456123), trashing 32000us
main debug: audio output is too slow (424123), trashing 32000us
main debug: audio output is too slow (392123), trashing 32000us
main debug: audio output is too slow (360123), trashing 32000us
main debug: audio output is too slow (328123), trashing 32000us
main debug: audio output is too slow (296123), trashing 32000us
main debug: audio output is too slow (264123), trashing 32000us
main debug: audio output is too slow (232123), trashing 32000us
main debug: audio output is too slow (200123), trashing 32000us
main debug: audio output is too slow (168123), trashing 32000us
main debug: audio output is too slow (136123), trashing 32000us
Comprend po ?!?
Marsh Posté le 23-03-2006 à 17:39:41
Salut à tous !
Voilà j'ai acheté une CM ASUS P5LD2 avec un p4 3GHZ.
J'ai installé windobe XP pro, tous les drivers.
Aucun problème dans le gestionnaire des périphériques.
J'ai préféré installer la version 1.33 des pilotes REALTEK HD AUDIO plutot que celle dispo sur le site d'asus ou sur le cd de la carte mère.
J'ai installé KLite codec pack (le full) et videolan pour le multiposte TV FREE.
J'ai branché par la sortie S/PDIF le PC à mon ampli home cinéma (6.1).
Lorsque je met du son, l'ampli détecte du 2.1 (ce qui est normal).
Mais lorsque je me met sur NRJ 5.1 (dispo sur vlc avec free multiposte), l'ampli détecte bien du 5.1 mais le son saccade à mort (répétition du même son).
Si je désactive la fonction "utiliser la sortie S/PDIF" dans VLC, le son sort normalement en 2.1.
Dans l'outil de configuration REALTEK (barre des taches), j'ai bien séléctionné S/PDIF (48k) avec un ensemble 6 enceintes. Et qd je fais les tests sur chaque enceinte, le son ne fonctionne que sur les enceintes avant droite et gauche. (le reste n'émet aucun son étant donné que mon ampli ne détecte que du 2.1).
J'ai beau installer désinstaller les pilotes HD AUDIO mais rien n'y fait.
Est-ce que celà peut venir des codecs K LITE ?? de VLC ??
Message édité par cirius le 23-03-2006 à 19:44:50
