Problème avec formulaire envoi [XML] - XML/XSL - Programmation
Marsh Posté le 22-03-2012 à 13:54:16
Et le formulaire contact.php
<?php
//-----------------Getting data sent by flash---------------------
foreach ($_POST as $key => $value){
if ($key != 'mail_to' && $key != 'smtp_server' && $key != 'smtp_port' && $key != 'mail_from' && $key != 'mail_subject' && $key != 'plain_text'){
$mail_body .= '<b>'.str_replace('_',' ',$key).'</b>:<br/>';
$mail_body .= ''.stripslashes($value).'<br/>';
$message = '<html><body>'.$mail_body.'</body></html>'; // mail body
//------------if plain text is set to true removing html tags------
if ($_POST['plain_text']=='true') {
$message = str_replace('<br/>',"\r\n", $message);
$message = strip_tags($message);
} else {
//----otherwise composing message headers---------------------------
$headers = 'MIME-Version: 1.0' . "\r\n";
$headers .= 'Content-type: text/html; charset=iso-8859-1' . "\r\n";
//------------setting conf data-------------------------------------
$to = $_POST['mail_to'];
$from = $_POST['mail_from'];
$subject = $_POST['mail_subject'];
$smtp_server = $_POST['smtp_server'];
$smtp_port = $_POST['smtp_port'];
//---------setting header info--------------------------------------
$headers .= 'To: '.$to. "\r\n";
$headers .= 'From: Site visitor ' .$from. "\r\n";
if (mail($to, $subject, $message, $headers)){ // sending mail
print('&mail=1'); //succes
} else {
print('&mail=0');//failure
Marsh Posté le 22-03-2012 à 13:46:01
Salut tout le monde,
J'ai déniché un formulaire de contact, mais je n'arrive pas à bien configurer le serveur d'envoi, du coup ça envoie nada.
Quelqu'un saurait comment faut faire ?
"<?xml version="1.0" encoding="utf-8"?>
Please read this information to learn how to set up the contact form integrated
into the template.
This readme file explains in details the meaning of the settings that can be
done in the fcContactFormConfiguration.xml configuration file.
It is recommended for you to use an XML editor to make changes to this file
because it’s less possible to make an error in the markup which can cause to
a not working contact form.
<contactFormConfiguration>
An e-mail address which will be used to receive messages from your contact form.
You can specify several e-mail addresses separating them with a comma.
For example: first_email@domain.com, second_email@domain.com, third@domain.com
<emailTo>your_email@domain.com</emailTo>
A server script type which will process sending e-mails. It depends on your
hosting and in the current version of the contact form it is allowed to use
two types: php (Apache, PHP Hosting); asp (IIS web server, ASP).
<serverProcessorType>php</serverProcessorType>
A name of the script file which process sending e-mails on your server (without
extension). The name contact is used by default.
<serverProcessorFileName>contact</serverProcessorFileName>
Text showing to the user when the form is submitted without any errors.
<messageSentText>THANK YOU FOR YOUR MESSAGE.</messageSentText>
<validationMessages>
<email>This is not a valid e-mail address</email>
<empty>All required fields must be filled</empty>
<ntext>This is not a valid text</ntext>
<digits>Not valid characters</digits>
</validationMessages>
<exitFullScreenMsg>You have to exit fullscreen mode to use contact form</exitFullScreenMsg>
Text showing in case the form is not submitted because of a server error.
<messageSentFailedText>THANK YOU FOR YOUR MESSAGE.</messageSentFailedText>
Text your visitor will see while waiting till the processing is over.
<formProcessingText>PROCESSING...</formProcessingText>
Your SMTP server (for ASP only).
<smtpServer>localhost</smtpServer>
Your SMTP port (for ASP only).
<smtpPort>25</smtpPort>
Set whether to send the message as a plain text (true) or as HTML (false).
<plainText>false</plainText>
ID of the input field (in the structure XML file) to use for the “from: ”
or “sender: ” label in your e-mail client.
<emailFromSource>1</emailFromSource>
Subject of the e-mails that will be sent through this contact form or ID of
the input field (in the structure XML file) to use for the “subject: ” label
<subjectSource>Contact Form from your site</subjectSource>
</contactFormConfiguration>"
