Drivers sqlsrv - PHP - Programmation
Marsh Posté le 24-06-2011 à 15:52:45
Bonjour, si je fais ceci:
$serverName = "xxx";$connectionOptions = array("Database"=>"xxx","UID"=>"xxx","PWD"=>"xxx","CharacterSet"=>"UTF-8" ); $conn = sqlsrv_connect( $serverName, $connectionOptions); if( $conn === false) die(sqlsrv_errors());$sql = "select top 10 * from clients";$res = sqlsrv_query( $conn, $sql);while( $row = sqlsrv_fetch_array( $res, SQLSRV_FETCH_ASSOC)){ print_r($row);}
ca marche très bien. Par contre si je fais ceci:
$serverName = "xxx";$connectionOptions = array("Database"=>"xxx","UID"=>"xxx","PWD"=>"xxx","CharacterSet"=>"UTF-8" ); $conn = sqlsrv_connect( $serverName, $connectionOptions); if( $conn === false) die(sqlsrv_errors());$sql = "use MADB;select top 10 * from clients";$res = sqlsrv_query( $conn, $sql);while( $row = sqlsrv_fetch_array( $res, SQLSRV_FETCH_ASSOC)){ print_r($row);}
(j'ajoute juste "use MADB;" à ma query) Ça ne me retourne rien ! comment ceci est-il possible ?
si je fais ceci:
