Problème lors de la génération de la javadoc - Java - Programmation
Marsh Posté le 10-04-2013 à 03:00:09
Salut tout le monde, j'ai un petit soucis quand j'essaye de générer la javadoc de mon projet... Voici les erreurs que netbeans retourne :
Warning: Leaving out empty argument '-windowtitle' Generating Javadoc Javadoc execution Loading source file E:\JavaWorkspace\java-v2\src\java\Business\Manager.java... warning: [options] bootstrap class path not set in conjunction with -source 1.6 Loading source file E:\JavaWorkspace\java-v2\src\java\Controller\Controller.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Data\ConnexionSingleton.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Data\DbAccess.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Exception\DataException.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Attribution.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Budget.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Demande.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Model\GroupeUnite.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Personne.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Section.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Statut.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Transaction.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Unite.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\AddBudgetFrame.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\AddDemandFrame.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\AddTransactionFrame.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllAttributionsModel.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllDemandsModel.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllDepQuotModel.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllTradeModel.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\CenterRenderer.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\ComptaRenderer.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\EtatCellEditor.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\GestionFrame.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\InfoSectionPane.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\LoginFrame.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\Main.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\StateRenderer.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\WindowListenerPerso.java... error: unsupported encoding: ${source.encoding} Loading source file E:\JavaWorkspace\java-v2\src\java\View\budgetPreviewPanel.java... error: unsupported encoding: ${source.encoding} 31 errors error: unsupported encoding: ${source.encoding} 1 warning E:\JavaWorkspace\java-v2\nbproject\build-impl.xml:1133: Javadoc returned 1 BUILD FAILED (total time: 0 seconds)
J'ai viré tous les caractères spéciaux de mes annotations mais rien n'y fait... Quelqu'un a une solution ou sait d'où ça vient?? Merci
Generating Javadoc
Javadoc execution
31 errors
1 warning
Message édité par t0um le 10-04-2013 à 03:01:31
