bonjour, mon application comprend l'enregistrement des données sur PHPMYAdmin via netbeans, et donc tout marche bien du moin pour les premiére valeurs enregistrées puis ben une exeption est affiché du genre:
Exception in thread "AWT-EventQueue-0" java.lang.IndexOutOfBoundsException: Index: 1082429, Size: 1082429 at java.util.ArrayList.RangeCheck(ArrayList.java:547) at java.util.ArrayList.get(ArrayList.java:322) at memoire.MemoireView.jButton1ActionPerformed(MemoireView.java:663) at memoire.MemoireView.access$800(MemoireView.java:49) at memoire.MemoireView$4.actionPerformed(MemoireView.java:154) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236) at java.awt.Component.processMouseEvent(Component.java:6263) at javax.swing.JComponent.processMouseEvent(JComponent.java:3267) at java.awt.Component.processEvent(Component.java:6028) at java.awt.Container.processEvent(Container.java:2041) at java.awt.Component.dispatchEventImpl(Component.java:4630) at java.awt.Container.dispatchEventImpl(Container.java:2099) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168) at java.awt.Container.dispatchEventImpl(Container.java:2085) at java.awt.Window.dispatchEventImpl(Window.java:2478) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.EventQueue.dispatchEvent(EventQueue.java:599) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161) at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Et on peut même dire que tableau_vachement_long.size() vaut 1082429 Lire la première ligne d'un log d'erreur, c'est pas si dur... A+,
--------------- There's more than what can be linked! -- Le capitaine qui ne veut pas obéir à la carte finira par obéir aux récifs. -- Il ne faut plus dire Sarkozy, mais Sarkozon -- (╯°□°)╯︵ ┻━┻
Marsh Posté le 31-05-2012 à 12:22:56
bonjour,
de l'aide SVP! merci d'avance
