XHTML validator
XHTML validator - HTML/CSS - Programmation
Marsh Posté le 21-12-2009 à 19:33:53
Bonsoir.
Dans le head de mon site je fais ceci.
  1. var loader = jQuery('<div id="loader"><img src="images/loading.gif" alt="loading..." /></div>')
Quand je passe ma passe au validateur j'ai une erreur la dessus.
Si vous avez des idées pour contourner cela.
Line 79, Column 40: document type does not allow element "div" here
The element named above was found in a context where it is not allowed. This could mean that you have incorrectly nested elements -- such as a "style" element in the "body" section instead of inside "head" -- or two elements that overlap (which is not allowed).
One common cause for this error is the use of XHTML syntax in HTML documents. Due to HTML's rules of implicitly closed elements, this error can create cascading effects. For instance, using XHTML's "self-closing" tags for "meta" and "link" in the "head" section of a HTML document may cause the parser to infer the end of the "head" section and the beginning of the "body" section (where "link" and "meta" are not allowed; hence the reported error).
Marsh Posté le 21-12-2009 à 19:36:17
normale faut mettre des balise CDATA
  1. <script type="text/javascript">
  2. //<![CDATA[
  3. var loader = jQuery('<div id="loader"><img src="images/loading.gif" alt="loading..." /></div>');
  4. //]]>
  5. </script>
Marsh Posté le 21-12-2009 à 19:49:27
Merci bien :)
