toujours ptit probleme de script - HTML/CSS - Programmation
Marsh Posté le 12-12-2004 à 10:47:54
oupss ma page:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
<meta name="GENERATOR" content="Microsoft FrontPage 6.0">
<meta name="ProgId" content="FrontPage.Editor.Document">
<title>Nouvelle page 1</title>
</head>
<!-- DEBUT DU SCRIPT -->
<SCRIPT LANGUAGE="JavaScript">
SCRIPT EDITE SUR L'EDITEUR JAVASCRIPT
http://www.editeurjavascript.com
imgPath = new Array;
SiClickGoTo = new Array;
if (document.images)
i0 = new Image;
i0.src = 'images/produits1.jpg';
SiClickGoTo[0] = "images/produits1.jpg";
imgPath[0] = i0.src;
i1 = new Image;
i1.src = 'images/produits2.jpg';
SiClickGoTo[1] = "images/produits2.JPG";
imgPath[1] = i1.src;
i2 = new Image;
i2.src = 'images/produits3.jpg';
SiClickGoTo[2] = "images/produits3.jpg";
imgPath[2] = i2.src;
i3 = new Image;
i3.src = 'images/produits4.jpg';
SiClickGoTo[3] = "images/produits4.jpg";
imgPath[3] = i3.src;
i4 = new Image;
i4.src = 'images/produits5.jpg';
SiClickGoTo[4] = "images/produits5.jpg";
imgPath[4] = i4.src;
i5 = new Image;
i5.src = 'images/produits6.jpg';
SiClickGoTo[5] = "images/produits6.jpg";
imgPath[5] = i5.src;
i6 = new Image;
i6.src = 'images/produits7.jpg';
SiClickGoTo[6] = "images/produits7.jpg";
imgPath[6] = i6.src;
a = 0;
function ejs_img_fx(img)
if(img && img.filters && img.filters[0])
img.filters[0].apply();
img.filters[0].play();
function StartAnim()
document.write('<A HREF="#" onClick="ImgDest();return(false)"><IMG SRC="photo1.jpg" BORDER=0 ALT=Menu NAME=defil style="filter:progid:DXImageTransform.Microsoft.Pixelate(MaxSquare=100,Duration=1)"></A>');
defilimg()
else
document.write('<A HREF="images/photo1.jpg"><IMG SRC="images/photo1.jpg" BORDER=0></A>')
function ImgDest()
document.location.href = SiClickGoTo[a-1];
function defilimg()
if (a == 8)
a = 0;
ejs_img_fx(document.defil)
document.defil.src = imgPath[a];
tempo3 = setTimeout("defilimg()",3000);
a++;
</SCRIPT>
<!-- FIN DU SCRIPT -->
<body background="images/fond%20logo%20final%20test.jpg" topmargin="0">
http://editeurjavascript.com/scrip [...] s_1_55.php
StartAnim()
</SCRIPT>
<blockquote style="text-align: left">
<p style="text-align: justify"> </p>
<p style="text-align: center"> </p>
<SCRIPT LANGUAGE="JavaScript" SRC="ejs_menu_dyn.js"></SCRIPT>
</blockquote>
<p align="center"> </p>
<blockquote>
</blockquote>
</body>
</html>
Marsh Posté le 12-12-2004 à 23:12:15
sauf erreur de ma part (j'y connais rien en JS), il me semble que tu a bien 7 photo mais que ton script utilise les numéro 0 à 6 (ça fait bien 7, mais ya pas d'image qui porte le numéro 7)
Donc dans ton if c'est a==7 et non a==8 qu'il faut tester pour le remettre à 0
Marsh Posté le 13-12-2004 à 14:52:21
Merci à toi xav, je vais essayer ce soir cette solution, par contre pour l'histoire d'emplacement des images c'est parametrable??
Marsh Posté le 13-12-2004 à 18:41:15
c'est bien ça xav merci bcp, par contre pour descendre l'emplacement des images (elle restent en haut .....) c'est faisable?
Marsh Posté le 14-12-2004 à 09:53:06
s'il vous plait? quelqun pour m'expliquer comment mettre les images ou je desire? c'est à die plus bas dans ma page ....
Marsh Posté le 12-12-2004 à 10:25:07
j'ai presqueterminé ma page mais il subsisite un peit probleme pour mon script, je vous met ce scipt ci après:
probleme1: je n'arrive pas a centrer ou meme descendre les images pixelisés qui ce succedent , celareste ne haut a gauche de la page, je ne vois pas dans le script l'endroit pour centrer ça
probleme2: j'ai 7 photos, lors de l'affichagede la page ca marche super mais apres la 7eme photo au lieu d'enchainer directement sur la 1ere, il affichie un petit carre blanc avec une croix rouge .... pourtant dans le script je m'arrete à 7
voilà, merci de votre aide
soud.
