Tableaux imbriqués
Tableaux imbriqués - HTML/CSS - Programmation
Marsh Posté le 16-09-2004 à 14:11:40
J'ai un problème concernant mes 2eme et 3eme balises <table> dont le contenu ne s'affiche pas dans le navigateur.
Voilà le coupable :
<table width="750" border="0" align="left" cellspacing="0" cellpadding="0">
    <tr>
        <td width="750" height="75"><img src="images/header.jpg" width="750" height="75" hspace="0" vspace="0" border="0" align="top">
        </td>
    </tr>
    <tr>
        <td width="750" align="top">
                <p><script type='text/javascript'>
                function Go(){return}
                </script>
                <script type='text/javascript' src='js\menu\exmplmenu_var.js'>
                </script>
                <script type='text/javascript' src='js\menu\menu_com.js'>
                </script>
                <noscript>Your browser does not support script
                </noscript>
                </p>
        </td>
    </tr>
    <tr>
        <td>
                <tr>
                    <td width="150" height="21" valign="top">
                    </td>
                    <td width="600" valign="top"><a href="index.html" target="_blank" name="Accueil">Accueil</a>
                    </td>
                </tr>
            </table>
        </td>
    </tr>
    <table width="750">
    <colgroup>
<col width="150">
<col width="450">
        <col width="150">
</colgroup>
    <tr>
        <td>
        </td>
        <td>
            <h4>Nos produits en vente et location </h4>
        <form action="" method="post">
            <table>
                 <tr>
                      <td>Catégorie :
                    </td>
                     <td><select name="categorie" size="1">
                     <option value="indifferent">Indifférent</option>
                        <option value="indifferent">Achat</option>
                        <option value="Vente">Vente</option>
                        <option value="Location">Location</option>
                         </select>
                    </td>
                 </tr>
                 <tr>
                      <td>Type :
                    </td>
                     <td><select name="type" size="1">
                     <option value="indifferent">Local commercial</option>
                        <option value="indifferent">Local industriel</option>
                        <option value="Vente">Fonds commercial</option>
                        <option value="Location">Droit au bail</option>
                        <option value="Vente">Bureau</option>
                        <option value="Location">Immobilier de rapport</option>
                        <option value="Location">Terrain</option>
                        <option value="Location">Maison/Appartement</option>
                        </select>
                    </td>
                </tr>
                <tr>
                     <td>Département :
                    </td>
                     <td><select name="type" size=1>
                         <option value="indifferent">64</option>
                     <option value="indifferent">40</option>
                        </select>
                    </td>
                </tr>
                <tr>
                    <td>Budget :
                    </td>
                    <td>entre <input name="min_value" type="text" size=10 value="" /> et <input name="max_value" type="text" size=10 value="" />
                        <select name="currency" size=1>
                         <option value="indifferent">Euros EUR </option>
                     <option value="indifferent">Dollars USD </option>
                        </select>
                    </td>
                </tr>
                <tr>
                    <td>Surface :
                    </td>
                    <td>entre <input name="min_sup" type="text" size=10 value="" /> et <input name="max_sup" type="text" size=10 value="" />
                        <select name="sup" size=1>
                         <option value="indifferent">m<sup>2</sup></option>
                     <option value="indifferent">ha </option>
                        </select>
                    </td>
                </tr>
                <tr>
                    <td colspan="2">Annonces de moins d'un mois <input type="radio" name="" value="check me" />
                    </td>
                </tr>
                <tr>
                    <td><input type="submit" value="Envoyer"/>
                    </td>
                    <td><input type="reset" value="Effacer"/>
                    </td>
                </tr>
            </table>
            </form>
        </td>
        <td valign="top">
        <h4>Zone Membre</h4>
        <form action="php/areaMember.php" method="post" name="">
            <table>
                 <tr>
                    <td><input name="" type="text" value="Login">
                    </td>
                </tr>
                <tr>
                    <td><input name="" type="password" value="Password">
                    </td>
                </tr>
                <tr>
                    <td><input type="submit" value="OK">
                    </td>
                </tr>
            </table>
            </form>
        </td>
    </tr>
    </table>
    <tr>
        <td><p>Voici le footer</p>
        </td>
    </tr>
</table>
A vrai dire la zone membre ne s'affiche pas non plus ...
Vu que j'y ai passé la matinée, ça serait vraiment sympa si qq'un voulait bien m'éclairer ;)
Merci d'avance.
Marsh Posté le 16-09-2004 à 15:16:25
les tableaux c pas beau... fais des div et des ul et des li et tout est plus simple :)
et rien que ça, c'est louche :
  1. </td>
  2.     </tr>
  3.     </table>
  4.     <tr>
  5.         <td><p>Voici le footer</p>
tu ne peux pas avoir d'élément dans quelque chose qui est autre qu'un td... et le fait que tu fermes un table pour commencer un tr juste après montre que quelque chose va pas déjà...
