SDL et xcode - C - Programmation
Marsh Posté le 14-05-2010 à 17:33:25
Bon, j'ai finalement trouvé la solution je la met au cas ou quelqu'un rencontre les mêmes soucis, comme je suis en 64 bits il fallait régler dans "project" "edit project setting" "32 bit universal" dans "architectures" ![]()
Marsh Posté le 14-05-2010 à 11:04:56
je viens d'installer la SDL pour xcode et j'ai tenté de compiler le petit exemple intégré et je comprends pas vraiment ce qu'i se passe j'ai pourtant suivi les tutos d'installation et ça donne ça:
Build Untitled of project Untitled with configuration Debug
Ld build/Untitled.build/Debug/Untitled.build/Objects-normal/x86_64/Untitled normal x86_64
cd /Users/christophe/Documents/Untitled
setenv MACOSX_DEPLOYMENT_TARGET 10.6
/Developer/usr/bin/gcc-4.2 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.6.sdk -L/Users/christophe/Documents/Untitled/build/Debug -F/Users/christophe/Documents/Untitled/build/Debug -F/Users/christophe/Library/Frameworks -F/Developer/SDKs/MacOSX10.6.sdk/Library/Frameworks -filelist /Users/christophe/Documents/Untitled/build/Untitled.build/Debug/Untitled.build/Objects-normal/x86_64/Untitled.LinkFileList -mmacosx-version-min=10.6 -framework SDL -framework Cocoa -o /Users/christophe/Documents/Untitled/build/Untitled.build/Debug/Untitled.build/Objects-normal/x86_64/Untitled
ld: warning: directory '/Users/christophe/Library/Frameworks' following -F not found
ld: warning: in /Developer/SDKs/MacOSX10.6.sdk/Library/Frameworks/SDL.framework/SDL, missing required architecture x86_64 in file
Undefined symbols:
"_SDL_SetVideoMode", referenced from:
_SDL_main in main.o
"_SDL_PushEvent", referenced from:
-[SDLApplication terminate:] in SDLMain.o
"_SDL_GetError", referenced from:
_SDL_main in main.o
_SDL_main in main.o
"_SDL_PollEvent", referenced from:
_SDL_main in main.o
"_SDL_Init", referenced from:
_SDL_main in main.o
"_SDL_Quit", referenced from:
_SDL_main in main.o
_SDL_main in main.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
Ld build/Untitled.build/Debug/Untitled.build/Objects-normal/i386/Untitled normal i386
/Developer/usr/bin/gcc-4.0 -arch i386 -isysroot /Developer/SDKs/MacOSX10.6.sdk -L/Users/christophe/Documents/Untitled/build/Debug -F/Users/christophe/Documents/Untitled/build/Debug -F/Users/christophe/Library/Frameworks -F/Developer/SDKs/MacOSX10.6.sdk/Library/Frameworks -filelist /Users/christophe/Documents/Untitled/build/Untitled.build/Debug/Untitled.build/Objects-normal/i386/Untitled.LinkFileList -mmacosx-version-min=10.6 -framework SDL -framework Cocoa -o /Users/christophe/Documents/Untitled/build/Untitled.build/Debug/Untitled.build/Objects-normal/i386/Untitled
Ld build/Untitled.build/Debug/Untitled.build/Objects-normal/ppc/Untitled normal ppc
/Developer/usr/bin/gcc-4.0 -arch ppc -isysroot /Developer/SDKs/MacOSX10.6.sdk -L/Users/christophe/Documents/Untitled/build/Debug -F/Users/christophe/Documents/Untitled/build/Debug -F/Users/christophe/Library/Frameworks -F/Developer/SDKs/MacOSX10.6.sdk/Library/Frameworks -filelist /Users/christophe/Documents/Untitled/build/Untitled.build/Debug/Untitled.build/Objects-normal/ppc/Untitled.LinkFileList -mmacosx-version-min=10.6 -framework SDL -framework Cocoa -o /Users/christophe/Documents/Untitled/build/Untitled.build/Debug/Untitled.build/Objects-normal/ppc/Untitled
merci de votre aide
