[WorkBlog] ATC 840 Black Watercooler
ATC 840 Black Watercooler [WorkBlog] - Water & Xtreme Cooling - Overclocking, Cooling & Modding
Marsh Posté le 25-05-2010 à 19:45:05
Bonjour a tous
http://img199.imageshack.us/img199/3017/20052010095.jpghttp://img199.imageshack.us/img199/5158/20052010084.jpghttp://img193.imageshack.us/img193/2445/20052010097.jpg
je souhaiterai avoir vos avis sur ma configuration actuel !!! Bon ou mauvais !! je suis preneur ! je veux savoir ce que vous en pensez et apporté des suggestions pour améliorer ce dernier !
Voici la configuration hardware:
Tour : COOLER MASTER ATCS 840
MotherBoard : ASUS Rampage II Extreme
Graphic Card : MSI R5870 + 9800GT Dédiés Physx
Micro Pour sa sœur :Intel I7 920 D0
Mémoire Vive : Corsair 3*1 GO DDR3 Dominator
Alimentation : CoolerMaster Silent Pro-M 1000W
Réobus Zalman ZM-MFC1 PLUS - noir X2
HDD : WesternDigital Vélociraptor 300GOX2
WesternDigital BLACK 2*1TO
Ecran : SamSung T220 X2
Voici le panier du watercooling
http://img6.imageshack.us/img6/4021/paniercompletwatercooli.jpg
Voici les photos :
http://img69.imageshack.us/img69/1091/20052010108.th.jpghttp://img704.imageshack.us/img704/9171/20052010105n.th.jpghttp://img232.imageshack.us/img232/9034/20052010104.th.jpg
http://img237.imageshack.us/img237/3821/20052010102.th.jpghttp://img442.imageshack.us/img442/9158/20052010101.th.jpghttp://img341.imageshack.us/img341/3892/20052010100p.th.jpghttp://img35.imageshack.us/img35/2500/20052010099.th.jpghttp://img195.imageshack.us/img195/6915/20052010098.th.jpghttp://img268.imageshack.us/img268/2445/20052010097.th.jpg
http://img571.imageshack.us/img571/107/20052010096.th.jpghttp://img19.imageshack.us/img19/3017/20052010095.th.jpghttp://img88.imageshack.us/img88/9223/20052010094.th.jpghttp://img20.imageshack.us/img20/1267/20052010093.th.jpghttp://img686.imageshack.us/img686/5754/20052010092w.th.jpghttp://img269.imageshack.us/img269/627/20052010091.th.jpghttp://img594.imageshack.us/img594/9066/20052010090.th.jpghttp://img594.imageshack.us/img594/7081/20052010089.th.jpghttp://img192.imageshack.us/img192/1659/20052010088.th.jpghttp://img442.imageshack.us/img442/4401/20052010087v.th.jpghttp://img189.imageshack.us/img189/5870/20052010086p.th.jpghttp://img195.imageshack.us/img195/5067/20052010085.th.jpghttp://img205.imageshack.us/img205/5158/20052010084.th.jpghttp://img201.imageshack.us/img201/9606/20052010083.th.jpghttp://img121.imageshack.us/img121/1673/20052010082.th.jpghttp://img641.imageshack.us/img641/3071/20052010081.th.jpghttp://img163.imageshack.us/img163/5839/20052010080.th.jpghttp://img225.imageshack.us/img225/7962/20052010079.th.jpghttp://img215.imageshack.us/img215/668/20052010077.th.jpghttp://img228.imageshack.us/img228/6501/20052010076.th.jpghttp://img714.imageshack.us/img714/229/20052010075.th.jpghttp://img171.imageshack.us/img171/9467/20052010074.th.jpg
Je vais posté l'oc et les résultats que j'obtiens demain
Message édité par lord-cronos le 25-05-2010 à 19:46:24
Marsh Posté le 25-05-2010 à 20:44:44
Ouichhh , le price du panier fait mal   :o  :o  , sinon jolie Water ;) !
[My Topic Ventes/Achats]
Marsh Posté le 25-05-2010 à 20:47:39
merci c'est gentil mais dans un water ce qui coute le plus chere c'est les ventilateur 100€ au total !!
Marsh Posté le 25-05-2010 à 20:51:33
Les Waterblock sont chéros aussi , tant CPU que GPU ou Mobale :) mais j'aime bien ;)
Marsh Posté le 25-05-2010 à 21:01:44
Sa reste corecte quand meme ! y as plus chere !
Marsh Posté le 25-05-2010 à 21:32:11
les embout les mec 4.90 l'embout je fait mon worckblog ats 840 dici 2 semaine sur le tout en water
FEED-BACK -cigarette et alcool tue plus vite que les armes http://valid.canardpc.com/show_oc.php?id=2347824
Marsh Posté le 26-05-2010 à 05:53:41
ah l'acts l'objet de toutes les convictions actuellement !! c'est un super boitier !!
Marsh Posté le 26-05-2010 à 15:38:13
uppp !! j'attends vos avis !
Marsh Posté le 26-05-2010 à 16:19:38
Je pense sérieusement que l'ordre du circuit est à revoir pour diminuer ces longueurs inutiles. Il y a moyen de faire mieux
Genre sur le bloc GPU - rentre et sort sur la même face ( en bas ) tu va gagner cette courbe pas top qui passe devant
Perso et ce n'est que mon avis je repense un peu le truc
Je pars de la pompe - je monte au GPU par en dessous, je file sur le NB - puis sur le 120 que je fais rentrer dans le boitier - le CPU ensuite - le 360 - le réservoir ( oui je sais c'est pas orthodoxe et peu pratique pour amorcer mais çà doit pouvoir fonctionner  ) le 240 et je reviens sur la pompe.
Sinon les photos sont surex ou floue on ne voit pas grand chose :/
Voilà mon avis - par contre tu dois avoir de super temp.
Mon Feedback - Mes Ventes - Simplexity 650D
Marsh Posté le 26-05-2010 à 16:26:01
ouais j'ai de super temps jss a 60° en full a 4.2ghz dans une piece a 30°
je pensais faire cela aussi au début mais la pompe est trop en dessous de la cg pour pouvoir faire monté le tuyaux directement au niveau de la cg part le bas !
tu pense que je devrai passé directement cg===> Chipset===>rad120==> CPU===> Rad360 ===>>Réservoir===Rad 240 ?
Message édité par lord-cronos le 26-05-2010 à 16:32:50
Marsh Posté le 26-05-2010 à 16:34:14
Bah si tu peux le faire oui tu aura un vrai loop et pas un octopus dans ton pc ;)
Marsh Posté le 26-05-2010 à 16:34:58
qu'est ce qu'un octopus ? pour le water ?
Marsh Posté le 26-05-2010 à 17:21:42
Ca veut dire que ton tubing ressemblera pas à une pieuvre mais à une vrai boucle water propre ;-)
Projet 0251 - En cours :D
Marsh Posté le 26-05-2010 à 17:41:52
en effet je viens de voir ce que sa voulais dire sur le web !! mais est ce que je vais gagné en température ? ou performance ?
Marsh Posté le 26-05-2010 à 18:07:48
En staïle tu va gagner et en clarté :D
En perfs sur le papier oui car tu va réduire les pdc dans l'absolu je doute
Marsh Posté le 26-05-2010 à 18:09:02
ah d'accord
mais je pensais que sa poserai pas de probleme ce montage puisque la cg chauffe pas mal c'est pas mieux de refroidir le liquide avant qu'il passe sur le chipset ?
Marsh Posté le 26-05-2010 à 18:11:12
La t° est la même en tout point d'un circuit à quelques pouillèmes près
Marsh Posté le 26-05-2010 à 18:12:10
ah d'accord ! mais sa sert a quoi d'avoir autant de rad ?
Message édité par lord-cronos le 26-05-2010 à 18:14:23
Marsh Posté le 26-05-2010 à 18:33:16
bah à avoir une surface de dissipation plus importante et donc de diminuer la t° globale du circuit.
Marsh Posté le 26-05-2010 à 19:08:49
ah d'accord donc c'est toujours utile !!
sinon que pensez vous du rad a l'intérieur du boitier ?
Marsh Posté le 26-05-2010 à 19:11:24
wich one - le 240 ou le 360 ?
Marsh Posté le 26-05-2010 à 19:12:18
il doit parler du 120 qui est dehors
Marsh Posté le 26-05-2010 à 19:12:29
ah oui bah le 240 il est pas sur les coté exterieur du boitier comme le 120 ou le 360 sa peux faire chauffé le liquide ?
Marsh Posté le 28-05-2010 à 16:25:43
Un petit conseil en plus a donné ? up
