Prise 2 HTPC modding - Bitfenix - Z77- Full Watercooling
Prise 2 HTPC modding - Bitfenix - Z77- Full Watercooling - Modding - Overclocking, Cooling & Modding
Marsh Posté le 08-12-2012 à 05:57:16
http://i48.servimg.com/u/f48/17/18/42/87/prodig10.jpg
Salut les amis   :)
Un autre montage (UN GRAND T'AMOUR DES MINI HTPC)
Le terme noir et rouge.
Les composantes pour ce build :
Boîtier : Bitfenix Prodigy mITX Mini-ITX Tower Case Arctic BLACK 1X5.25EXT 5X3.5INT No PS Top USB3.0 HD Audio
PSU : EVGA Supernova NEX650G 650W ATX EPS12V Power Supply 80PLUS Gold
Carte mère : ASUS P8Z77-I Deluxe mITX LGA1155 Z77 DDR3 1PCI-E16 SATA3 DVI HDMI DisplayPort USB3.0 Motherboard
CPU : Intel Core i5 3570K Unlocked Quad Core Processor LGA1155 3.4GHZ Ivy Bridge 6MB Retail
Mémoire : 2X 4GO G.ZKILL RipjawsZ 2133 black CL9-11-10-28 1.65V Memory Kit
GPU : 1x EVGA GTX 480  :lol:
SSD : 2x OCZ Vertex 3 SATA III 2.5" SSD 60GB (Raid0 OS)
HDD : 1x WD Caviar Blue 1TB
Système de refroidissement :
1x Pompe D5
1x Bitspower - D5 Pump Modding Kit - Red
1x Cross-Flow Slim High Density Dual 120mm Radiator XSPC EX240
1x Slim High Density Single 120mm Radiator XSPC EX120
1x EK-Multioption X2 RES 150 ADVANCED - Ver 2 60mm
1x Feser One - Cooling Fluid - UV RED
1x EK waterblock 480
1x Bitspower Universal RAM Module Water Cooling Set (2 Banks)
13x Bitspower 3/8"ID - 5/8"OD Straight Compression Fitting Black
1x Primochill Primoflex Pro LRT Clear 3/8IN ID 5/8IN OD Tubing
5x Stop Plug Fitting - G1/4" Matt Black w/UV Green O-ring
1x Fill/Drain Port Sealing Plug w/ 3/8"ID Tubing Barb - Matt Black
3x 45 Degree High Flow Rotary Adapter M/F G1/4 - Black
4x G1/4" 90 Degree G1/4" Adapter - Black
6x fans ?
1x CUP
Case & GPU Modding
2x Backplate GPU Black + LCD costum (CNC)
2x Side panel Black  + LCD costum (CNC)
6x Guard 120mm black
16x Radiator M4 Mounting Screw & Nut, 25mm (see compatibility)
1x EK-VGA bracket GeForce Black costum
5x XSPC Mini LCD Display with Temperature Sensor - Red
1x 6-Pin PCI-E DarkSide Single Braid Cable - Black & Red
1x 8-Pin PCI-E DarkSide Single Braid Cable - Black & Red
1x 4+4 EPS DarkSide Single Braid Cable - Black & Red
1x 24-Pin ATX DarkSide HSL Single Braid Cable - Black & Red
Message édité par danexmod le 09-12-2012 à 02:05:23
Marsh Posté le 10-12-2012 à 10:10:14
Décidément on ne t'arrete plus ;)
Marsh Posté le 10-12-2012 à 17:05:53
Pourquoi partir sur la Cm Asus, et pas la Asrock? C'est celle qui irait le mieux des mini-ITX Z77 avec ton thème, après on a la Gigabyte. Toutes deux moins chères que la Asus, de mauvais gout et pas largement meilleure ^^
(Drap, tes mods que j'ai pu voir sont à couper le souffle :D )
Message édité par lyechee le 10-12-2012 à 17:06:42
Marsh Posté le 10-12-2012 à 22:17:06
Merci ! :)
J'adore la Asus et très très satisfait de ce produit et je l'ai eu a bon rabais. L'Asrock, le socket est trop près de la slot GPU. Pour le terme noir et rouge, je vais peindre les Heatsinks est les slots en rouge ;)
Message édité par danexmod le 10-12-2012 à 22:20:52
Marsh Posté le 10-12-2012 à 22:24:27
Drap :love:
Marsh Posté le 12-12-2012 à 15:40:57
Les commandes arrive aujourd'hui :) Photo bientôt :)
Marsh Posté le 12-12-2012 à 15:42:57
Je sens qu'on va se régaler.  :love:
Marsh Posté le 12-12-2012 à 15:50:40
J'en ai le kiki tout dur :love: :love:
Marsh Posté le 13-12-2012 à 02:23:48
Pas toute reçu mais demain une autre parti va arrivée et mardi prochain.
Le boitier et le PSU de EVGA   :love:
http://i17.servimg.com/u/f17/17/18/42/87/img_3710.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3711.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3712.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3713.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3714.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3715.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3716.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3717.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3718.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3719.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3720.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3721.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3722.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3723.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3724.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3725.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3726.jpg
Marsh Posté le 13-12-2012 à 08:02:31
:love: Je trouve qu'il rend mieux en noir!
La suiteeeeeeeeee :D
Marsh Posté le 13-12-2012 à 20:35:01
La carte mère et le CPU est arrivé  :pt1cable:
Marsh Posté le 14-12-2012 à 00:07:08
Quelque pic   :)
Autre stock qui va arriver encore demain  :pt1cable:
http://i17.servimg.com/u/f17/17/18/42/87/img_3727.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3728.jpg
I love ce board   :love:
http://i17.servimg.com/u/f17/17/18/42/87/img_3729.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3730.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3731.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3732.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3733.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3734.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3735.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3736.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3737.jpg
Marsh Posté le 14-12-2012 à 02:56:51
[:pcgamer]
Workblog Mod
Marsh Posté le 14-12-2012 à 09:46:17
Cay beau ! :D
Achats / Ventes Feed-Back ITX Tower
Marsh Posté le 14-12-2012 à 14:05:53
En enlevant le film plastique de protection sur le rad des DIGI+VRM et sur le rad du chipset, ça serait encore mieux ... :whistle:
Message édité par Scouto le 14-12-2012 à 14:06:37
Marsh Posté le 14-12-2012 à 14:55:21
Ce matos  [:yafaro:2]
Sinon je voudrais connaitre la distance a l'avant, pour savoir si on peut mettre un ventilateur a cet emplacement.
je suis en train de galerer a faire un mod avec mon lian li q11 avec watercooling limite je me prendrais bien celui la au final  :D sans trop le modder  :ange:
quand j'ai vu ton integration  :bounce:
http://img259.imageshack.us/img259/8880/img3714uc.jpg
Uploaded with ImageShack.us
Marsh Posté le 14-12-2012 à 15:54:30
Va voir sur le topic unique du boitier, il y a pas mal d'infos ;)
http://forum.hardware.fr/hfr/Hardw [...] 1140_1.htm
Marsh Posté le 14-12-2012 à 17:36:21
+1
Merci !
Machinage les 2 side panel PSU sur la CNC Serious Business Photo à venir Smile
Marsh Posté le 14-12-2012 à 19:06:20
Voici les ventilateurs   :love:
Prochaine commande mardi et le montage par la suite   :bounce:
http://i17.servimg.com/u/f17/17/18/42/87/img_3738.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3739.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3740.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3741.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3742.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3743.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3744.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3745.jpg
Message édité par danexmod le 14-12-2012 à 19:07:51
Marsh Posté le 14-12-2012 à 20:01:53
Drap ! :D
Lego à vendre : https://forum.hardware.fr/hfr/Achat [...] 4737_1.htm || Lian Li O11D XL - MSI MPG B550 Gaming Plus - Ryzen 9 5900x - 2x16Go Corsair 3200c16 - Sapphire Pulse RX 9070XT - Bequiet Pure Power 12M 1000w - Full
Marsh Posté le 14-12-2012 à 20:24:22
Je l'ai pas enlever pour les protéger parce que je vais peindre les heatsink en rouge + la slot PCI EXPRESS ;)
Message édité par danexmod le 14-12-2012 à 20:26:26
Marsh Posté le 15-12-2012 à 08:54:47
drap :o
Marsh Posté le 15-12-2012 à 08:59:23
Marsh Posté le 15-12-2012 à 22:53:40
Voici les plaques  du PSU, machiné  avec une CNC :D
http://i17.servimg.com/u/f17/17/18/42/87/img_3746.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3747.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3748.jpg
Marsh Posté le 17-12-2012 à 23:25:09
Backplate GPU  :)
http://i17.servimg.com/u/f17/17/18/42/87/img_3811.jpg
La dernière commande reçu  :)
http://i17.servimg.com/u/f17/17/18/42/87/img_3749.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3750.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3751.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3752.jpg
Message édité par danexmod le 17-12-2012 à 23:27:43
Marsh Posté le 17-12-2012 à 23:31:53
Très jolis les rads en noir mat   :love:
Marsh Posté le 18-12-2012 à 01:01:37
drap :love:
Mess With The Best | Die Like The Rest -- I'd rather be hated for who I am than loved for who i'm not
Marsh Posté le 18-12-2012 à 07:14:43
Du lourd en perspective.  :pt1cable:
Marsh Posté le 18-12-2012 à 18:09:39
Drapoil :o
ACH/VDS // HyperMod // Qu4tr // µBox
Marsh Posté le 19-12-2012 à 23:58:23
Quelques photos du stock avant le montage  :)
http://i17.servimg.com/u/f17/17/18/42/87/img_3812.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3813.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3814.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3815.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3816.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3817.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3818.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3819.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3820.jpg
Message édité par danexmod le 19-12-2012 à 23:58:53
Marsh Posté le 20-12-2012 à 10:05:05
Très sympa tout ça ! :D
Dis moi où as tu commandé tes jupes transparentes ?
Message édité par romain13tuning le 20-12-2012 à 10:05:16
Marsh Posté le 20-12-2012 à 17:58:20
Salut ! Chez http://www.dazmode.com/
Installation du réservoir   :wahoo:
http://i17.servimg.com/u/f17/17/18/42/87/img_3822.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3823.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3824.jpg
http://i17.servimg.com/u/f17/17/18/42/87/img_3825.jpg
Marsh Posté le 20-12-2012 à 18:10:31
Tu va nous faire croire que tout ce bowdel rentre dans un prodigy :o
J'attends de voir ça[:merlin l'enchanteur:2]
(au passage, la question du noob: c'est quoi fait pour les jupes?)
Marsh Posté le 20-12-2012 à 18:22:44
Ça sent le lourd ! Je met en favori !
Marsh Posté le 20-12-2012 à 18:43:39
Marsh Posté le 20-12-2012 à 19:27:56
Drap !
Marsh Posté le 20-12-2012 à 19:41:49
Ça va tout rentrer ?  :ouch:
Corsair 300R WaterCooled
Marsh Posté le 20-12-2012 à 19:43:40
Déjà que l'alim' rentre pas, j'ai hâte de voir comment tu vas faire pour caser tout ce beau monde, drap.  :o
Marsh Posté le 21-12-2012 à 01:41:52
Courage, ca va rentrer !   [:cyberjo:1]
LOL
Sans maitrise, la puissance n'est rien - Pirelli ;)
Marsh Posté le 21-12-2012 à 02:35:47
aller un joli drap ^^
