je voudrai changer le timing de ma ram manuellement !
carte mere ms platinum p35 amibios 1.9 ram 2X 1024 ballistix 1066
ma carte mere a mit par defaut des timings qui ne correspondent pas du tout a ceux du constructeur ceux indiques par crucial sont 5.0 .5.5.15 j ai bien trouver dans le bios de la carte le cell menu ou rentrer les parametres sauf que dans les derniers parametres, je ne sais pas quoi mettre voila un copier coller de la doc du bios pour changer les parametres! merci .
Configuration DRAM Timing by SPD Setting to [Enabled] enables DRAM CAS# Latency automatically to be determined by BIOS based on the configurations on the SPD (Serial Presence Detect) EEPROM on the DRAM module.
DRAM CAS# Latency When the Configuration DRAM Timing by SPD sets to [Disabled], the field is adjustable.This controls the CAS latency, which determines the timing delay (in clock cycles) before SDRAM starts a read command after receiving it.
DRAM RAS# to CAS# Delay When the Configuration DRAM Timing by SPD sets to [Disabled], the field is adjustable. When DRAM is refreshed, both rows and columns are addressed separately. This setup item allows you to determine the timing of the transition from RAS (row address strobe) to CAS (column address strobe). The less the clock cycles, the faster the DRAM performance.
DRAM RAS# Precharge When the Configuration DRAM Timing by SPD sets to [Disabled], this field is adjustable. This setting controls the number of cycles for Row Address Strobe (RAS) to be allowed to precharge. If insufficient time is allowed for the RAS to accumulate its charge before DRAM refresh, refresh may be incomplete and DRAM may fail to retain data. This item applies only when synchronous DRAM is installed in the system.
DRAM TRFC When the Configuration DRAM Timing by SPD sets to [Disabled], the field is adjustable. This setting determines the time RFC takes to read from and write to a memory cell.
DRAM TWR When the Configuration DRAM Timing by SPD sets to [Disabled], the field is adjustable. Minimum time interval between end of write data burst and the start of a precharge command. Allows sense amplifiers to restore data to cells.
DRAM TWTR When the Configuration DRAM Timing by SPD sets to [Disabled], the field is adjustable. Minimum time interval between the end of write data burst and the 3-23 BIOS Setup start of a column-read command. It allows I/O gating to overdrive sense amplifiers before read command starts.
DRAM TRRD When the Configuration DRAM Timing by SPD sets to [Disabled], the field is adjustable. Specifies the active-to-active delay of different banks. Time interval between a read and a precharge command.
DRAM TRTP When the Configuration DRAM Timing by SPD sets to [Disabled], thestart of a column-read command. It allows I/O gating to overdrive sense amplifiers before read command starts.
DRAM TRTP When the Configuration DRAM Timing by SPD sets to [Disabled], the field is adjustable. Time interval between a read and a precharge command.
Marsh Posté le 10-08-2008 à 12:39:32
bjr,
merci .
on the DRAM module.
DRAM CAS# Latency
DRAM RAS# Precharge
DRAM TRFC
a memory cell.
DRAM TWR
DRAM TWTR
3-23
BIOS Setup
DRAM TRRD
DRAM TRTP
DRAM TRRD
DRAM TRTP
merci.
