Mon 1er overlock Phenom II x4 965 RB-C3
Mon 1er overlock Phenom II x4 965 RB-C3 - CPU - Overclocking, Cooling & Modding
Marsh Posté le 15-03-2011 à 11:09:52
bonjour à tous voila mon premier OC j'aurais besoin de votre aide pour l'optimiser et si possible faire mieux!
voila ma config :
QuadCore AMD Phenom II X4 Black Edition 965, 3800 MHz (19 x 200)
Nom de la carte mère: Asus Crosshair IV Extreme  (1 PCI, 5 PCI-E x16, 4 DDR3 DIMM, Audio, Gigabit LAN, IEEE-1394)
Chipset de la carte mère: AMD 890FX, AMD K10
Mémoire système: 16384 Mo  (DDR3-1333 DDR3 SDRAM)
DIMM1: G Skill F3-10666CL9-4GBXL 4 Go DDR3-1333 DDR3 SDRAM  (8-8-8-22 @ 609 MHz)  (7-7-7-20 @ 533 MHz)  (6-6-6-17 @ 457 MHz)
DIMM2: G Skill F3-10666CL9-4GBXL 4 Go DDR3-1333 DDR3 SDRAM  (8-8-8-22 @ 609 MHz)  (7-7-7-20 @ 533 MHz)  (6-6-6-17 @ 457 MHz)
DIMM3: G Skill F3-10666CL9-4GBXL 4 Go DDR3-1333 DDR3 SDRAM  (8-8-8-22 @ 609 MHz)  (7-7-7-20 @ 533 MHz)  (6-6-6-17 @ 457 MHz)
DIMM4: G Skill F3-10666CL9-4GBXL 4 Go DDR3-1333 DDR3 SDRAM  (8-8-8-22 @ 609 MHz)  (7-7-7-20 @ 533 MHz)  (6-6-6-17 @ 457 MHz)
Type de BIOS: AMI (11/04/10) ver.0502
Carte vidéo: Sapphire Vapor X 5870 1Go
HDD1: Hitachi HDS721010CLA332 ATA Device  (1000 Go, 7200 RPM, SATA-II)
HDD2: WDC WD1001FALS-00J7B0 ATA Device  (931 Go, IDE)
Alimentation: Corsair TX950 watts
Refroidissement: Corsair H50 Hydro series
j'ai tout laisse en auto, changé le profile OC de ma memoire en 1600 et augmenté le coef à 19
1 heure de OCCT terminé sans erreur
http://img198.imageshack.us/img198/6241/2011031409h51cpu1.th.png http://img841.imageshack.us/img841/612/2011031409h51cpu2.th.png http://img844.imageshack.us/img844/2844/2011031409h51cpu3.th.png
http://img818.imageshack.us/img818/8922/2011031409h51cpu4.th.png http://img535.imageshack.us/img535/9840/2011031409h51vcore.th.pnghttp://img863.imageshack.us/img863/9521/2011031409h51volt3.th.png
http://img833.imageshack.us/img833/6518/2011031409h51volt5.th.pnghttp://img43.imageshack.us/img43/9369/2011031409h51volt12.th.png http://img833.imageshack.us/img833/3549/cpuz2d.th.pnghttp://img196.imageshack.us/img196/7159/cpuz1q.th.png
sachant que cette config tourne en H24,j' ai besoin de vos conseil pour optimise tous ça!
j'ai essaye de monté plus haut en passant le coef a 19.5 mais BSOD
qu'est ce que je peux faire mieux ? c'est bon pas bon ? je vai tout brulé bref...help me!
ps: si j'ai oublie un truc merci de me le faire savoir c'est mon 1 er post soyez indulgent.
Marsh Posté le 15-03-2011 à 17:14:39
Déjà 1ère chose à faire regarde un peu les posts concernant les phenom et les tutos pour l'overclocking.
Pour ma part j'ai un 955BE C3 qui est sensibleent identique.
J'ai pu augmeneter le FSB a 250 donc HT LINK 2500.
Le vcore va dépendre de la fréquence que tu souhaite obtenir je suis monter jusqu'a 4.3Ghz au lieu de 3.2Ghz @ 1.6vcore mais juste pour tester.
Le mieux est de ne pas dépasser les 1.55v pour le proco.
Mais ne laisse rien en auto!!!!
Merci l'oc pour tourner aussi puissant que des machines qui valent le double ;-)
Marsh Posté le 15-03-2011 à 19:10:46
merci pour ta réponse ,mais mon bios est tellement rempli que je sais pas quoi mettre en auto et quoi enlever !!
je me demande si les température sont pas trop élevé ?
Marsh Posté le 16-03-2011 à 16:38:49
bon j'arrive pas a monter plus haut j'ai monté le FSB à 205,mais  bsod !
j'ai regardé les post sur les phenom mais j'ai des termes dans mon bios qui sont pas pareil ?bon je cherche quand meme!
Marsh Posté le 16-03-2011 à 23:56:39
Salut blackmackina,
déjà vu sur OCM ton post.
Et comme on te le dis, il faut lire les tutos que tu trouve sur les fofos.
On ne peut pas te faire ton O/C, car comme tu le dis, il y a pleins d'options dans les bios, et on ne les connais pas toutes.
Quand tu aura un soucis bien précis, n'hésites pas.
O/C, c'est long, surtout quand on débute.
Bon courage
Asus M4A785TD-v evo, AthlonIIX4 630 (@3.5GHz) (vcore 1.525V) temp max : 45°C, HD4670 (OC 802 MHz) HD4200 (IGP) (OC 1000MHz), 4Go dominator ddr3 1600, Thermalright Silver Arrow, Corsair CX400, ssd Kingston Now 120Go + 2X500 Go mirror + 5To, W8pro, 4 écrans
