OC E8500 Rev E0 sur ma P5Q DELUXE help réglages poussés BIOS
OC E8500 Rev E0 sur ma P5Q DELUXE help réglages poussés BIOS - CPU - Overclocking, Cooling & Modding
Marsh Posté le 17-11-2008 à 20:12:45
Voilà, j'aimerais dans un premier temps stabiliser mon E8500 à 4530Mhz (8.5 x 533) pour du H24 mais pour l'instant c'est pas trop ça, erreur sous cpu stress à 8 min, vcore à 1.424. Mes réglages BIOS sont surement à peaufiner afin de pouvoir stabiliser ma machine (config dans ma signature), voici le détail:
http://images1.hiboox.com/images/4708/c2cb95a85672589ae5f7b35b1ed39959.jpg
AI Overclock tuner: Manual
CPU Ratio Setting: 8.5
FSB Strap to North Bridge: 333
FSB Frequency: 533
PCI-E Frequency: 101
DRAM Frequency: DDR-2  1066
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information:
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
Common Performance Level: pas dispo en Auto
CPU Voltage: 1.43125 = 1.424 CPU-Z
CPU GTL Voltage Reference (0/2): Auto
CPU GTL Voltage Reference (1/3): Auto
CPU PLL Voltage: 1.56
FSB Termination Voltage: 1.40
DRAM Voltage:  2.1
NB Voltage: 1.40
NB GTL Reference: Auto
SBridge Voltage: 1.20
PCIE SATA Voltage: Auto
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
CPU Margin Enhancement : Optimized
Configuration CPU
CPU Ratio : 8.5
C1E Support: Disabled
Max CPUID: Disabled
Intel Virtualization: Disabled
CPU TM: Disabled
Execute Disable Bit: Disabled
Je suis stable après 30min OCCT par contre à 533 x 8 (4264Mhz) avec 1.312vcore cpu-z et la même config BIOS:
http://images1.hiboox.com/images/4708/bae12bbc4f9d542810b09a4c7506cb69.jpg
Enfin une fois stabilisé pour le H24, j'essayerais de voir ce qu'il a dans le ventre dans la limite des T°.
"Les cons, ça ose tout. C'est même à ça qu'on les reconnaît!" Audiard
Marsh Posté le 17-11-2008 à 20:13:57
http://images4.hiboox.com/images/4708/4b003847aa85f21cbcdb364e12ef340f.jpg
et juste avec le freeze!
http://images4.hiboox.com/images/4708/61526cf145885c59ac7da8b98db439cd.jpg
Marsh Posté le 17-11-2008 à 21:23:12
j'ai parfois des freeze à l'arrêt et parfois après 20min de cpu stress j'ai l'écran bleu et donc reboot...
