Faible score 3D mark - Améliorer la config
Faible score 3D mark - Améliorer la config - CPU - Overclocking, Cooling & Modding
Marsh Posté le 26-03-2008 à 20:09:14
bonjour à tous ;-)
ma config est en signature ...
J'ai un petit problème, je fais un test 3d Mark pour la première fois ... mais mon score est bien faible d'apres les configs comme moi !
pour moi : 6118 ... le plus haut 6846 ... :(
le lien : http://service.futuremark.com/home [...] ultType=14
--------------------- voici un extrait de ma config sur 3D Mark -----------------------
CPU 1/1
Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
Manufacturer   Intel
Family   Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
Architecture   64-bit
Internal Clock   2.7 GHz
 Internal Clock Maximum   2.7 GHz
External Clock   300.0 MHz
Socket Designation   Socket 775
Upgrade   ZIF Socket
 MultiCore   2 Processor Cores
HyperThreadingTechnology   N/A
Capabilities   MMX, CMov, RDTSC, SSE, SSE2, SSE3, PAE, NX
Version   Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
 Caches
Level 1    32 KB
Level 2    4 MB
Level 3    0 B
Radeon X1950 Series        Driver 6.14.10.6715
Description   Radeon X1950 Series
Manufacturer   ATI Technologies Inc.
Total Local Video Memory   264 MB
Total Local Texture Memory   264 MB
AGP Aperture Size   500 MB
Driver File   ati2dvag.dll
Driver Version   6.14.10.6715
Driver Details   8.401-070815m-052022C-ATI
Driver Date   7-27-2007
Driver WHQL Certified   true
Max Texture Width   4096.000496000001 px
Max Texture Height   4096.000496000001 px
 Max User Clipping Planes   6
Max Active Hardware Lights   8
Max Texture Blending Stages   8
Fixed Function Textures In Single Pass   8
Vertex Shader Version   3.0
Pixel Shader Version   3.0
Max Vertex Blend Matrices   37
Max Texture Coordinates   8
VGA Memory Clock   594.0 MHz
VGA Core Clock   499.5 MHz
Max VGA Memory Clock   0.0 Hz
Max VGA Core Clock   0.0 Hz
 PCI
Name   Radeon X1950 Series
Vendor ID   0x1002
Device ID   0x7244
SubSystem ID   0x0b121002
Revision ID   0x0000
Bus
Type   PCI Express
Revision   1.0
Enabled   true
Rate   16
Sideband Addressing   Not Supported
Fast Write   Not Supported
Que faire pour améliorer tout ça ^^
merci ;)
Marsh Posté le 27-03-2008 à 10:52:03
C'est un score normale pour la carte graphique qu tu as si tu veux ameliorer tout ca faut overclocker ton E6600 et changer ta carte graphique.
Mais bon si ta config te suffit c'est inutile, ca sert a rien de changer une config juste pour avoir plus de points a 3d MArk.
Marsh Posté le 27-03-2008 à 17:53:41
et bien le E6600 est oc : de 2.4GHz a 2.7GHz ...
la carte graphique c'est pas une merde non plus, c'est la
X1950 XT ... donc bon :(
Marsh Posté le 28-03-2008 à 16:12:42
Score tout a fait normal avec cette carte graphique et ce CPU,ne t'inquiètes pas :)
Message édité par Sk_rmouche le 28-03-2008 à 16:13:16
Marsh Posté le 28-03-2008 à 17:47:39
non c'etait pas une merde y'a 1 an 1 an et demi, aujourd'hui elle commence a etre bien dépassée quand meme :p
Message édité par flagadadim le 28-03-2008 à 17:47:49
« Quand j'étais jeune, j'étais très con. Je suis resté très jeune. »Jean-Claude Van Damme
Marsh Posté le 28-03-2008 à 18:00:01
d'accord ^^
je ne sais pas, je me suis monté ça cet été, donc ça fait 0.75 ans :S
m'enfin, vous avez raison, j'ai 200 fps sous CS:S :D ça me suffit ^^
Marsh Posté le 28-03-2008 à 18:21:51
Et 45-50 fps sur crysis en medium avec le E6600 un peu plus O/C :D
Message édité par flagadadim le 28-03-2008 à 18:21:58
