probleme de resoltion - Linux et OS Alternatifs
Marsh Posté le 26-08-2001 à 18:29:05
http://perso.wanadoo.fr/linux_wizard/howto_nvidia.html
fais voir le fichier de conf de XFree.
Marsh Posté le 28-08-2001 à 23:46:17
[root@zero X11]# pwd
/etc/X11
[root@zero X11]# more XF86Config-4
# File generated by anaconda.
Section "ServerLayout"
Identifier "Anaconda Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db" ). There is normally
# no need to change the default.
RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
FontPath "unix/:7100"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "fbdevhw"
Load "pex5"
Load "glx"
Load "pex5"
Load "record"
Load "xie"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
# Option "AutoRepeat" "500 5"
# when using XQUEUE, comment out the above line, and uncomment the
# following line
# Option "Protocol" "Xqueue"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# Option "XkbModel" "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:nocaps"
Option "XkbRules" "xfree86"
Option "XkbLayout" "us"
#Option "XkbVariant" ""
#Option "XkbOptions" ""
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "MouseManPlusPS/2"
Option "Device" "/dev/psaux"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "no"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
HorizSync 27.0-96.0
VertRefresh 50.0-160.0
# -- 1400x1050 --
# 1400x1050 @ 60Hz, 65.8 kHz hsync
Modeline "1400x1050" 129 1400 1464 1656 1960
1050 1051 1054 1100 +HSync +VSync
# 1400x1050 @ 70Hz, 76.8 kHz hsync
Modeline "1400x1050" 151 1400 1464 1656 1960
# 1400x1050 @ 75Hz, 82.3 kHz hsync
Modeline "1400x1050" 162 1400 1464 1656 1960
# 1400x1050 @ 85Hz, 93.2 kHz hsync
Modeline "1400x1050" 184 1400 1464 1656 1960
EndSection
Section "Device"
# no known options
Identifier "NVIDIA GeForce 2 (generic)"
Driver "nvidia"
VendorName "NVIDIA GeForce 2 (generic)"
BoardName "NVIDIA GeForce 2 (generic)"
#BusID
EndSection
Section "Screen"
Identifier "Screen0"
Device "NVIDIA GeForce 2 (generic)"
Monitor "Monitor0"
DefaultDepth 16
Subsection "Display"
Depth 16
Modes "1280x1024"
EndSubsection
EndSection
Section "DRI"
Mode 0666
EndSection
Marsh Posté le 29-08-2001 à 00:02:45
forcément il y a une seule résolution de conf.
le fichier de merde généré par anaconda ! le fichier n'est même pas explicitement conf pour le français !
parcours la FAQ serveur X, comme tu le veras, il faut renseigné plusieurs résolutions si tu veux qu'il switch dans ces résolutions, XFdrake le fait auto en plus !
http://perso.wanadoo.fr/linux_wiza [...] resolution
ton fichier de conf es tellement merdique que j'ai envie de poster le mien.
Marsh Posté le 29-08-2001 à 00:13:35
et bien vas y ne te gene pas ....
Xfrake .... j ai pas .... je suis sous redhat
et ce fichier est celui qui est genere a l install
mais j atend avec impatience ton fichier de conf
Marsh Posté le 25-08-2001 à 17:30:19
j ai installe les drivers nvidia sur une redhat 7.1
losrsque je lance tuxracer j ai l image dans un tout petit cadre en bas a gauche
(ca doit etre du 800*600)
pour quake III c est pareil ....
en 800*600 aussi ca se met en petit a gauche ..
pour l avoir en plein ecran je suis aoblige de le mettre en 1200*1024 (resolution de mon ecran)
en configurant en 1024 ca donne qqchose d intermediare
pas plein eecran mais presque (toujours en bas a gauche)
alors comment resoudre ce probleme ?
