Probleme avec Java-Acces-Bridge
Probleme avec Java-Acces-Bridge - Linux et OS Alternatifs
Marsh Posté le 06-03-2006 à 18:19:07
Voila plusieurs heures que j'essaie d'installer Java-Acces-Bridge chez moi, afin de pouvoir essayer le support de reconnaissance vocale de OpenOffice.
Malheureusement , des que je lance le make voila ce que je me mange :
CLASSPATH=../../../../idlgen javac AccessibleHelper.java
1. ERROR in AccessibleHelper.java
 (at line 15)
        public static void insert (org.omg.CORBA.ANY a, org.GNOME.Accessibility.Accessible that)
org.omg cannot be resolved to a type
2. ERROR in AccessibleHelper.java
 (at line 17)
        org.omg.CORBA.portable.OutputStream out = a.create_output_stream ();
3. ERROR in AccessibleHelper.java
 (at line 18)
        a.type (type ());
The method type() is undefined for the type AccessibleHelper
4. ERROR in AccessibleHelper.java
 (at line 20)
        a.read_value (out.create_input_stream (), type ());
5. ERROR in AccessibleHelper.java
 (at line 23)
        public static org.GNOME.Accessibility.Accessible extract (org.omg.CORBA.Any a)
6. ERROR in AccessibleHelper.java
 (at line 28)
        private static org.omg.CORBA.TypeCode __typeCode = null;
7. ERROR in AccessibleHelper.java
 (at line 29)
        synchronized public static org.omg.CORBA.TypeCode type ()
8. ERROR in AccessibleHelper.java
 (at line 31)
        if (__typeCode == null)
__typeCode cannot be resolved
9. ERROR in AccessibleHelper.java
 (at line 33)
        __typeCode = org.omg.CORBA.ORB.init ().create_interface_tc (org.GNOME.Accessibility.AccessibleHelper.id (), "Accessible" );
10. ERROR in AccessibleHelper.java
 (at line 33)
11. ERROR in AccessibleHelper.java
 (at line 35)
        return __typeCode;
12. ERROR in AccessibleHelper.java
 (at line 43)
        public static org.GNOME.Accessibility.Accessible read (org.omg.CORBA.portable.InputStream istream)
13. ERROR in AccessibleHelper.java
 (at line 48)
        public static void write (org.omg.CORBA.portable.OutputStream ostream, org.GNOME.Accessibility.Accessible value)
14. ERROR in AccessibleHelper.java
 (at line 50)
        ostream.write_Object ((org.omg.CORBA.Object) value);
15. ERROR in AccessibleHelper.java
 (at line 53)
        public static org.GNOME.Accessibility.Accessible narrow (org.omg.CORBA.Object obj)
16. ERROR in AccessibleHelper.java
 (at line 60)
        throw new org.omg.CORBA.BAD_PARAM ();
17. ERROR in AccessibleHelper.java
 (at line 63)
        org.omg.CORBA.portable.Delegate delegate = ((org.omg.CORBA.portable.ObjectImpl)obj)._get_delegate ();
18. ERROR in AccessibleHelper.java
 (at line 63)
19. ERROR in AccessibleHelper.java
 (at line 70)
        public static org.GNOME.Accessibility.Accessible unchecked_narrow (org.omg.CORBA.Object obj)
20. ERROR in AccessibleHelper.java
 (at line 78)
21. ERROR in AccessibleHelper.java
 (at line 78)
21 problems (21 errors)make[4]: *** [AccessibleHelper.class] Erreur 255
make[4]: quittant le répertoire « /home/esox/Desktop/java-access-bridge-1.4.5/idlgen/org/GNOME/Accessibility »
make[3]: *** [all-recursive] Erreur 1
make[3]: quittant le répertoire « /home/esox/Desktop/java-access-bridge-1.4.5/idlgen/org/GNOME »
make[2]: *** [all-recursive] Erreur 1
make[2]: quittant le répertoire « /home/esox/Desktop/java-access-bridge-1.4.5/idlgen/org »
make[1]: *** [all-recursive] Erreur 1
make[1]: quittant le répertoire « /home/esox/Desktop/java-access-bridge-1.4.5/idlgen »
make: *** [all-recursive] Erreur 1
Ce qui me fait penser qu'il ne trouve pas la directory ou se trouve le jar de org.omg.CORBA. J'ai controlé , il est bel et bien sur mon systeme, avez vous une idée de ou je dois aller mettre le path pour qu'îl trouve aussi mon autre package?
Merci beaucoup
Esox
Si la vérité est découverte par quelqu'un d'autre,elle perd toujours un peu d'attrait
Marsh Posté le 07-03-2006 à 12:48:50
