[Eng] Help for a monitor in Paris
Help for a monitor in Paris [Eng] - Ecran - Hardware - Périphériques
Marsh Posté le 18-05-2007 à 15:20:35
Hi and sorry for not speaking french.
I am an italian guy, living in Bruxelles. I would like to buy a LCD screen, 22" or 24", and I feel I can have larger choice and better prices in Paris than in Bruxelles. I will be in Paris this weekend and I wonder if anyone can suggest shops that have a large choice of this kind of monitors and cheap prices; the best would be a place where I could check the price online and then go there to buy it.
Merci beaucop pour votre aide  :bounce:
Marsh Posté le 18-05-2007 à 15:32:12
maybe grosbill.com
Marsh Posté le 18-05-2007 à 17:36:10
Scusi amico, ma non hai raggione... Troverai piu facilmente piccolini prezzi a Brusselle...
Ma se capisce un puo di francese, poi andare su www.rue-montgallet.com o www.monsieurprix.com
Ci sono doppia siti per valuare i prezzi del mercato.
Spero ché ti sarai utile :)
Ce n'est pas parce qu'on a rien à dire qu'il faut fermer sa gueule! ///[-]\\\ Mon feedback Achats/Ventes
Marsh Posté le 19-05-2007 à 13:51:01
merci :)
If anyone else wants to suggest any other name, please feel free to do so. Those above do not have the monitors I'm looking for:
- Samsung Syncmaster 225MW
- LG M228WA
Marsh Posté le 19-05-2007 à 15:37:55
or
- Samsung Syncmaster 225BW
Marsh Posté le 20-05-2007 à 03:48:26
devi scegliere qualcosa d'altro ché samsung, perché questa firma é una grossa merda sulla testa d'un peloso :D
Prendi la LG, é meglio.
