[Unik]Shuttle Sb61G2 V3.0 -
Shuttle Sb61G2 V3.0 - [Unik] - Mini PC - Hardware
Marsh Posté le 08-06-2004 à 08:08:49
SB61G2 V3 >> Specification
Page principale :
http://www.shuttle.com/hq/product/ [...] sp?B_id=33
Et pour les downloads. :
http://www.shuttle.com/hq/support/ [...] B61G2%20V3
http://www.shuttle.com/share/simages/productimages/sb61g2.jpg
http://www.shuttle.com/share/simages/product_view/SB61G2%20V3_b.gif
http://de.shuttle.com/prod/xpc/sb61g2_side1.jpg
http://de.shuttle.com/prod/mb/fb61.jpg
En fait celui là c'est l'ancien j'ai pas trouver le nouveau bloc qui se trouve sur le cpu on dirait un bloc de ceramique [:sstarshoot]
http://de.shuttle.com/prod/xpc/125/p4_heatpipe.jpg
http://de.shuttle.com/prod/xpc/sb61g2_acc.jpg
http://de.shuttle.com/prod/acc/125/pfx_bags.jpg
Chassis
Dimension  (L)300*(W)200*(H)185  3.6Kg (N.W.)  5.2Kg (G.W.)
Front Panel  (2) USB 2.0 ports,&"  FireWire mini port,  Microphone port,  Headphone port,  Audio Line-in port
Back Panel  PS/2 Keyboard socket, PS/2 Mouse socket,  (4) USB 2.0 ports,  FireWire 400 port,  VGA-out,  10/100 LAN (RJ-45),  6-channel audio out
Extension Bay  5.25" * 1,  3.5" * 2
Mainboard
Form Factor  Shuttle Form Factor
CPU  Socket 478   Pentium 4 & Celeron  400/533/800MHz FSB
Chipsets  North bridge:Intel 865G     South bridge:ICH5
Memory  Dual Channel DDR 266/333/400  (2) DIMM slots (2GB max)
VGA   Intel Extreme Graphics 2 (integrated),  8X AGP slot, DVMT memory architecture
Audio  6-channel audio,  Digital (SPDIF) audio ports, Analog audio ports
Expansion Slot  PCI * 1,  8XAGP * 1
IDE interface  (2)ATA100 headers  (2)Serial ATA 150 headers, FDD header,   (1)5.25" storage bay, (2)3.5" storage bays
Power  Silent X 250W
Accessory  Integrated Cooling Engine (ICE)  Intelligently-engineered airflow mechanics
DETAILS des spécifications :
http://www.shuttle.com/share/produ [...] 3%20DM.pdf
News Bios :
http://www.shuttle.com/hq/support/ [...] 61G2%20V3#
BIOS
File History
fb61s30h.bin , 512KB , SB61G2 V3 (FB61V3.x) , 7/13/2004
Ma config et tout ce que je peuc brancher dessus  [:zerod]
Shuttle SB61G2 V3 I865G
Cpu Intel 2.8c Ghz
2*512 Mb Pc3200 Winbond cas 2.5
Hercules Ati 9800 Pro 128Mo
1 Hdd Maxtor 120 Go 7200t udma100
1 Graveur DVD LG4120B Double couche
Souris EXPLORER OPTICAL USB
Scanner USB 1212u
Canon powershot G1 USB
Camescope TRV33E
Imprimante Canon S900 PHOTO
Ecran 19 pouces IIlyama HM903DT
ADSL 2048/256
En externe boitier UBS2 et firewire
1 hdd 120 Go Seagate 7200 udma100
1 Hdd Seagate 80 Go Barracuda IV
1 Hdd Ibm 60 Go Gwp 7200T udma100
Message édité par the gentleman le 17-02-2005 à 08:27:10
-= Fight =-
Marsh Posté le 08-06-2004 à 09:31:47
normalement aucun problème...
je dirais même plus, ca marche obligé...
reste à savoir si c'est nécéssaire...
les différences :
alim qui passe de 200 à 250 W (inutile dans l'absolu si 200 W te suffisent pour le moment...)
un peu plus silencioeux.. mais je ne sais pas de quelle ordre... (un peu, beaucoup, à la folie, passionnement, pas du tout...)
et un problèmes avec le son en moins... (à vérifier...)
Marsh Posté le 08-06-2004 à 10:09:12
les différences :
Ouep oki ben en revendant mon ancier boitier ca devrait le faire je devrait pas trop dépenser..  pi pour le son les cartes de maintenant AC97 du shuttle non plus de bugs de sons [:sstarshoot]
Thx.
-= Fight =-
Marsh Posté le 11-06-2004 à 13:48:25
Vais pi etre prendre un ST61G4 en fait je sais plus trop !!! :/
-= Fight =-
Marsh Posté le 17-06-2004 à 16:06:11
nan je reprend un sb61g2 v3 c'est sur NOW....
-= Fight =-
Marsh Posté le 17-06-2004 à 19:37:11
Et si tu achetais separement la nouvelle alimentation.
Non c'est juste une suggestion...
http://www.clubic.com/s/produits/82307.html?o=4
Marsh Posté le 18-06-2004 à 07:35:23
:D oui spa con je sais :D MAIS  ;)
J'ai revendu mon ancier sb61g2 à 200euros  Vu le prix de la version 3 à 269 euros que j'ai commandé et le prix de l'alim seule à 68 euros je perds rien je gagne rien SI un ensemble NEUF avec alim 250 et des ventilos silencieux, c'est bien NON ;)
P.S. : A ceux qui on OC leur shuttle, a combien je peux monter mon 2.8c GHz dans mon shuttle sb61g2, j'avais lu un truc du genre 3.2 Ghz Vrai ou Faux ?
Message édité par the gentleman le 18-06-2004 à 07:36:55
-= Fight =-
Marsh Posté le 21-06-2004 à 14:52:08
UP, pour l'oc please ?
Sinon je le recois Mercredi soir mon new sb61g2 v3 :love:
-= Fight =-
Marsh Posté le 01-07-2004 à 07:54:07
Ok nickel, le bruit est nettement inférieur et le radiateur qui repose sur le cpu on dirait de la céramique en tout cas mon cpu au ralenti avec pate thermique Artci III est à 33 degres..  Content je suis.
Et pour l'oc personne ne peut me donner une réponse please Merci.
-= Fight =-
Marsh Posté le 03-07-2004 à 11:05:30
y a pas grand chose qui change entre la V1 et la V3 sauf l'alim, le rad... donc si tu OC avant, tu OC de la meme manière voir peut etre un peut plus vue le nouveau Ice ;)
Marsh Posté le 05-07-2004 à 07:37:01
Ben vais m'y coller tonight, mais j'ai gagné sans oc 7 degre facile boitier ferme avec le nouveau ice spa rien quand même :love: le bruit est moindre aussi...  A suivre.
-= Fight =-
Marsh Posté le 05-07-2004 à 10:22:23
Interessant ! et dans la V3 tu n’as plus les prob de son ?
Marsh Posté le 05-07-2004 à 11:40:36
Aucun souci avec mon ati9800pro pour l'instant :D
-= Fight =-
Marsh Posté le 09-07-2004 à 14:16:45
slt,
niveau bruit ca donne quoi cette v3 ?
Marsh Posté le 12-07-2004 à 12:54:13
Ben en fiat c'est moins bruyant de ql'ancien, ca refroidi mieux de 5 degres au demarrage et par la suite aussi :D, pour le bruit j'ai rien pour mesurer la différnce mais en smart fan c'est nettement moins bruyant ;)
-= Fight =-
Marsh Posté le 16-07-2004 à 15:41:17
News Bios :
BIOS
File History
-= Fight =-
Marsh Posté le 16-07-2004 à 23:25:30
salut gentleman,
je viens d'acheter le SB61G2 V3 et j'ai 2 ou 3 questions :
- y'a quoi comme ameliorations ds le nouveau bios ?
- j'ai enlevé le ventilo d'origine (pour le proc) car beaucoup trop bruyant et je l'ai remplacé par le ventilo livré avec le p4 2.8C (j'ai du adapter un peu car il ne passait pas d'ailleurs) est ce que ca risque pas de plus chauffer ?
Marsh Posté le 19-07-2004 à 10:43:36
Ben je les cherche encore les amélioratiosn, ca fonctionne sans bug donc je vois pas trop je creuse la question ce jour mais depuis vendredi dernier que j'ai mis à jour ca roulezzzzz.....
Sinon moi je le trouve pas bruyant en smart fan le ventilo d'origine et il est même moins bruyant que la première version :D
-= Fight =-
Marsh Posté le 20-07-2004 à 12:02:09
maj de la page 1 :D en fait y a qu'une page, je fais un gros FLOP avec topic sur mon shuttle qui pourtant déchire bien :D
-= Fight =-
Marsh Posté le 20-07-2004 à 18:23:08
Mais nan c'ets pas un Flop c'est seulement que l'on est rare a avoir des shuttle (surtout avec des pentium) ici :(..
Sinon tu pourrais mettre une photo de l'Ice que tu as ?
Car a mon avis c'est ce nouveau refroidissement qui me ferai changé mon V1 ;)
Marsh Posté le 20-07-2004 à 19:25:27
Ok vais y travailler à la photo :D
Marsh Posté le 27-07-2004 à 16:06:36
Hmm tiens j'ai oublie de faire la photo du ventilo/refroidisseur :D oupsss
-= Fight =-
Marsh Posté le 31-07-2004 à 11:29:51
oui oui c'est vrai !, pas bien  :pfff:
 :D
Marsh Posté le 18-08-2004 à 13:49:10
Et toujours pas de photo, vais la faire c'est sur mais fo que je demonte et cela me fait un peu chie quoi :D
-= Fight =-
Marsh Posté le 18-08-2004 à 14:56:09
enleve seulment la partie avec les lecteur, ça suffira pour comparer la taille ;)
Mika ! #Lyon
Marsh Posté le 10-09-2004 à 07:56:26
http://www.materiel.be/bbones/xpc775_939/images/19.jpg
C'est le meme sauf pour les fixation  [:zerod]
-= Fight =-
Marsh Posté le 12-09-2004 à 01:33:00
moi avec mon ancien sb65G2 avec mon p4 3ghz je l'overclockais @ 3.65 Ghz
bon ok j'avais un sp-94 dedans :D
Marsh Posté le 13-09-2004 à 15:59:35
il y plus de différence que simplement les fixation !!!
Déjà y a plus le soble noir pour le ventilo d'origine, puis le rad à l'air plus fin mais avec des lame plus épaisse.
La fixation par 4 visses + ressort c'est quand meme mieu.
Ensuite la CM semble différente de la mienne (V1) la pile est maintenant a plat, y a un second chips avec rad passif.
Et c'est quoi le rad derrière celui du proce ?
Marsh Posté le 16-09-2004 à 14:55:31
LOL ^^ Sorry Chezwam ce n'est pas la photo d'un sb61g2v3 c'est une carte mèe FB83 :D mais le ventilo ressemble à ca sans les vis avec la meme fixation que le V1 stou.
-= Fight =-
Marsh Posté le 16-09-2004 à 15:27:30
aahh oki je pige mieu là, j'usse peur lolol
En tout cas il est sympas ce new rad !!
Marsh Posté le 17-09-2004 à 22:59:02
http://www.shuttle.com/hq/support/ [...] b61g2%20v3
New bios je sais ce qu'il améliore encore :D
-= Fight =-
Marsh Posté le 22-09-2004 à 19:01:04
Ayai j'ai flashe mon bios vois pas grande diff mais ca corrige un bug avec les prescott et un sur le vpu :D et ca fonctionne sans bug
-= Fight =-
Marsh Posté le 05-10-2004 à 21:56:42
Y'a tout de même un truc qui me tracasse, moi qui rechigne à monter un processeur sur une carte mère normale... Comment se passe l'installation d'un Shuttle, et en particulier de ce modèle ? Si j'ai bien compris, le système de refroidissement est fourni avec le Shuttle. Mais... ça se branche sans qu'on risque de tout défoncer en 3 secondes ? Bref, je suis très intéressé par les solutions de Shuttle, la seule chose qui me retient, c'est la peur de m'arracher les cheveux à l'installation. Ce serait sympa de me faire partager vos expériences.
Marsh Posté le 05-10-2004 à 22:36:05
pour l'installation y a rien de compliquer, tu met le proce, le rad dessus, les barettes de ram dans leurs slot, tu branche les DD/lecteur et c'est tout..
C'ets un puzzle super simple ;)
Marsh Posté le 05-10-2004 à 22:42:21
Mouarf... Bah y'a plus qu'à émouvoir le banquier alors  :lol:
Marsh Posté le 06-10-2004 à 15:43:13
Kler c'est tout simple même avec des petits moufles tu devrais y arriver :D
-= Fight =-
Marsh Posté le 26-10-2004 à 07:35:30
UP QUOI :D
-= Fight =-
Marsh Posté le 28-10-2004 à 13:09:18
dsl y a bien un vcore ki monte jusqu'à 1.75V ds le sb61g2 non ? :??:
dites moi oui svp :'(
Marsh Posté le 29-10-2004 à 20:09:52
vous pensez k'un flashage avec un bios de v1 est possible ? :??:
Marsh Posté le 29-10-2004 à 22:35:03
oui, c possible, mais ca applike pas les tensions apres...
testé cet aprem meme :lol:
