Info sur carte-mère Matsonic MS7012D
Info sur carte-mère Matsonic MS7012D - Hardware
Marsh Posté le 15-05-2002 à 18:48:12
Pouvez vousm'en dire plus ??? type de chipset ? elle prend koi comme type de P3 ? slot one ???
Sur le site du contructeur, il n'y a plus trop d'info dessus, juste les dernier bios.
Marsh Posté le 15-05-2002 à 18:58:31
il paraitrait qu elle serait equipée du chipset i810e. C le fameux BX ?? sinon, il accepte koi comme cpu ?
Marsh Posté le 15-05-2002 à 19:16:31
http://www.matsonic.com.tw/eng/pro [...] s7012d.htm
[Home][Product]
        MS7012D
[img]http://www.matsonic.com.tw/mbimage/ms7012d.gif
PROCESSOR
Slot 1 / socket 370 supports any one of the following processors:
PentiumIII processor
450/500/550/600
PentiumII processor
233/266/300/333/350/400/450
Celeron processor
266/300/333/366/400/433/466/500MHz
CHIPSET
Intel 82810E & 82801AA Chipset With  133/100/66MHZ FSB
ITE LPC I/O - IT8870F
CMI8738 PCI 3D Audio/HSP 56K V9.0   Fax/Modem
CACHE RAM
None (CPU Embedded)
MEMORY
Two 168-pin DIMM sockets for 3.3V PC 100 SDRAM
Maximum: 512MB
SYSTEM BIOS
Award BIOS with 4Mb Flash ROM in Firmware Hub (FWH)
Supports Plug and Play 1.0A, APM  1.2, Multi Boot, DMI Full support for  ACPI revision 1.0A specification
 I/O INTERFACE
Supports Plug and Play I/O function
One - EPP/ECP mode parallel port
Two - 16550 high-speed serial I/O ports
VGA Connector
Supports 360K~2.88M Byte, 3 Mode FDDs or  LS120
Dual PCI IDE interfaces - supports four IDE devices  (PIO mode 4, DMA Mode 2, Ultra DMA 33/66 )
PS/2 Keyboard and PS/2 Mouse Connectors
ATX Power Supply Connector
Audio Ports(Line-in, Line-out, Mic-in,  CD-in and Game Port)
Two sets of USB connector
3D PCI AUDIO ONBOARD
SB 16/PRO compatible with DirectSound 3D support HRTF 3D Positional Audio Technology with full duplex stereo Supports 44.1K digital audio-in (SPDIF)
56K FAX/MODEM ONBOARD
Supports V.90 Fax/ModemStandard for your internet Communication
OTHER
IrDA/CIR cable Header
Green, HDD, Power indicator LED Connectors
CPU Fan, Power Fan and Chassis Fan Headers
LAN Card Wake Up/Internal Modem Ring Wake-Up Headers
BUS ARCHITECTURE
5 PCI Slots
1 AMR Slot
FORM FACTOR AND LAYERS
ATX Size (305mmx243mm), 4 layers
1+1=10
