Asus P6T6 WS Revolution : 6 Ports PCI-Express 16X ! [Topic Unique] - Carte mère - Hardware
Marsh Posté le 28-11-2008 à 22:23:56
Ouufff, quel monstre !
La finesse et la concentration des composants ...
Marsh Posté le 28-11-2008 à 23:20:53
grave c'est comme si la Rampage II Extreme était une bouze
Marsh Posté le 28-11-2008 à 23:38:39
Spécifications complètes :
Specifications
CPU
Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor Supports Intel® Dynamic Speed Technology
*Refer to www.asus.com for Intel CPU support list
Chipset
Intel® X58 + ICH10R
Nvidia® nForce200
System Bus
Up to 6400 MT/s ; Intel® QuickPath Interconnect
Memory
6 x DIMM, Max. 12 GB, DDR3 1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
Triple channel memory architecture
Support Intel Extreme Memory Profile (XMP)
* Due to Intel spec definition, DIMMs of DDR3-1333 or above are supported by specific CPU models only.
** Refer to www.asus.com or this user manual for the Memory QVL (Qualified Vendors Lists)
Expansion Slots
2 x PCIe 2.0 x16 (@ x16 or x8)
1 x PCIe x16
2 x PCIe x8
1 x PCIe x4
True @ x16 3-Way SLI in Slot 1, 3, &5 when Slot 2&4 are not occupied
Multi-GPU Support
Supports NVIDIA 2-Way and 3-Way SLITM techonology
Supports ATI CrossFireXTM technology, up to Quad CrossFireXTM
Storage
Intel ICH10R controller
6 xSATA 3 Gb/s ports
Intel® Matrix Storage supporting SATA RAID 0, 1, 10, and 5
Marvell 88SE6320 SAS controller
2 x SAS ports supporting SAS RAID 0, 1, 10*
Marvell 88SE6121 SATA controller
2 xExternal SATA 150/300 (SATA On-the-G0), supporting SATA RAID 0, 1, 10, and 5**
* A SAS expander (excluded in package) is required while using RAID 10 on SAS ports.
** A port-multiplier (excluded in package) is required while using RAID 5 or 10 on eSATA ports.
LAN
2 x Realtek 8111C Dual Gb LAN Support Teaming Technology
Audio
ADI 2000B, 8 -Channel High Definition Audio CODEC
Multi-Streaming
Jack-Sensing
Front Panel Jack-Retasking
Coaxial / Optical S/PDIF out ports at back I/O
ASUS Noise-Filer
USB
12 USB 2.0 ports
ASUS Workstation Special Features
6 PCIe Gen2.0 x 16 slots
G.P. Dignosis Card bunddle
ASUS SASsaby Cards support
ASUS WS Diag. LED
ASUS WS Heartbeat
SAS Onboard
Special Features
EPU - 6 Engine
True 16+2 Phase Power Design
Turbo V
Fan Xpert
Express Gate
AI Nap
Q-Shield
Q-Connector
Fanless Design: Heat-pipe solution
Fanless Design: Stack Cool 2
My Logo 2
CrashFree BIOS 3
EZ Flash 2
C.P.R.(CPU Parameter Recall)
SFS (Stepless Frequency Selection)
O.C. Profile
Back Panel I/O Ports
1 x PS/2 Keyboard
1 x PS/2 Mouse
2 x External SATA
1 x S/PDIF Out (Coaxial + Optical)
2 x LAN(RJ45) port
6 x USB 2.0/1.1
8 -Channel Audio I/O
Internal I/O Connectors
24-pin EATX Power connector
8-pin ATX +12V Power connector
Chassis intrusion
CPU fan with PWM control
Chassis fan1 with Q-fan control
Chassis fan2 with Q-fan control
Chassis fan3 with Q-fan control
PWR fan
CD audio in
3 x USB connectors support additional 6 USB ports
20-pin Panel connector
TPM header
Front panel connector
S/PDIF Out header
BIOS
16 Mb Flash ROM
AMI BIOS, Green, PnP, DMI v2.0, Wfm2.0, ACPI v2.0a, SMBIOS v 2.4
Manageability
WOL/WOR by PME,WOR by Ring,Chasis Intrusion,AI NET2
Accessories
BIOS flash utility under DOS
AI Suite
ASUS Update
ASUS PC Probe II
Anti-Virus Software (OEM version)
Adobe Acrobat Reader ver 8.0
Microsoft DirectX ver 9.0C
Image-Editing Suite
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.5 cm )
Dispo ici pour 328 pounds soit 397 €
http://cgi.ebay.co.uk/Asus-P6T6-WS [...] 118001r315
Marsh Posté le 28-11-2008 à 23:42:44
ReplyMarsh Posté le 28-11-2008 à 23:44:25
je ne dirais qu'une chose :
Fssabbagh : l'homme au topic made in asus
en tout cas je n'avais pas de lien pour l'acheter, merci !
Marsh Posté le 28-11-2008 à 23:53:03
je la veux, nan moi d'abord moi d'abord
Marsh Posté le 29-11-2008 à 00:00:51
bon alors mettons le pied dans le plat :
asus rampage II extreme vs Asus P6T6 WS Revolution
sachant que généralement les workstations de chez asus met leur piquette au série rog ...
Marsh Posté le 29-11-2008 à 09:10:02
Citation : C'est certain? |
Absolument à 100%
Citation : asus rampage II extreme vs Asus P6T6 WS Revolution |
un p'tit test ?
Marsh Posté le 30-11-2008 à 19:14:48
Concernant les cartes graphiques, c'est vrai qu'elles prennent toutes 2 voire 3 slots, mais en configuration standard car c'est bien le ventilateur (ou ventirad pour certaines) qui prend le plus de place et fait qu'elles occupent 2 ou 3 slots.
Perso, je suis en train de monter un nouveau PC à bas de la carte mère Asus Revolution (date dispo ?) et pour les cartes graphique je prévois deux HD4870X2 avec système de refroidissement à eau Coolit Extreme Liquid Cooling :
http://www.generation-3d.com/actua [...] c12765.htm
Avantages :
- diminution du bruit (pas de ventilateur sur les cartes)
- chaque carte occupe un seul slot PCI-E
Marsh Posté le 08-12-2008 à 03:43:46
big e a écrit : C'est certain? |
Il y a bien 6 ports physiques 16x, mais câblés comme ceci:
Fssabbagh a écrit : Expansion Slots |
Cela dit on ne sait pas où est câblé le NF200. Parce que les ports qui y sont reliés ne seront pas en vrai 2.0 16x:
http://www.hardware.fr/news/imprimer/9908/
Citation : attention toutefois, chaque nForce 200 gérant 2 ports x16 et étant lui-même connecté au chipset en x16, la bande passante totale restera identique. |
16 lanes PCI-E 2.0 en entrée, et 32 lanes PCI-E 2.0 en sortie. Pas de secret donc.
Et si on est pointilleux, on purrait même dire que le NF200 ajoute de la latence. Le seul avantage est quand 2 cartes (connectées aui même NF200) n'utilisent pas leur bus en même temps.
Fssabbagh a écrit : non pas une mais deux puces nforce 200 ] |
Sur cette photo il n'y en a qu'une: http://xs232.xs.to/xs232/08441/img_5761028464.jpg
Où est l'autre ?
Marsh Posté le 14-12-2008 à 11:48:23
lol je suis venu par rapport à ton lien dans mon topic de La Gainward GLH....
purée de carte mère lol
faut que du single slot ici pas plus et bien refroidit
Marsh Posté le 14-12-2008 à 11:58:01
watercooling bien sur
un waterblock c'est pas épais
Marsh Posté le 19-12-2008 à 09:54:47
Yes, watercooling of course :-) Avec un Reserator XT que j'ai déjà, encore dans son emballage et qui attend le reste des composants...
Bon, j'ai juste changé le choix du block depuis mon dernier post, je vais prendre celui de Koolance : http://www.koolance.com/water-cool [...] uct_id=731
Et un tournevis pour enlever la plaque qui occupe 2 slots côté connexions et la remplacer par une plaque 1 slot :-) Ou une scie à métaux ???? Jamais fait attention comment c'était fixé...
Marsh Posté le 26-12-2008 à 11:21:26
test matbe pour bientôt :
http://www.matbe.com/actualites/56 [...] x58-nf200/
au fait, la asus a 2 ports SAS intégrés ce qui autorise le branchement de HDD 15 000 trs comme les Seagate Cheetah
Marsh Posté le 26-12-2008 à 11:33:20
Elle m'interesse vraiment ! Elle à l'air d'être au Top cette mobal !
Si un block Water sort pour elle elle pourrait très bien atterir dans mon TJ07
Marsh Posté le 26-12-2008 à 16:15:14
La mienne est arrivée! Je vais la chercher demain matin!!!
J'ai hâte de la voir en vrai cette carte! Ca fait déjà quelques semaines que je "bave dessus"...
Malheureusement, je ne saurai pas encore la monter demain, parce que je n'ai pas encore tous les composants... Ca devrait arriver la semaine prochaine! Demain, c'est la P6T6 avec son Core i7 920.
Marsh Posté le 26-12-2008 à 17:14:34
Et le reste de la config ?
Marsh Posté le 26-12-2008 à 17:47:39
Non de Zeus, elle dépote ! (drap inside )
Marsh Posté le 26-12-2008 à 19:41:55
Fssabbagh a écrit : test matbe pour bientôt : |
On espère qu'ils vont révéler la supercherie de nVidia...
Marsh Posté le 27-12-2008 à 09:58:34
Entre cette carte et la R2E, mon cœur balance...
(genre y mettre 2 voir 3 GPU + carte contrôleur)
Marsh Posté le 27-12-2008 à 12:38:23
Et l'interet des 6 PCI-E ?
A part pour le "travail" peut etre..
Mais en usage courant..je vois pas..
Autant prendre la version "normale" avec 2 PCI-X.
Pour le reste,effectivment les "WS" mettent une patée aux ROG...ça se verifie quasi sur chaque chipset.
Y a pas de bling bling sur les Workstation,que du fonctionnel.
Sauf peut etre sur celle là..Arf!
Marsh Posté le 27-12-2008 à 13:02:22
Citation : On espère qu'ils vont révéler la supercherie de nVidia... |
de quelle supercherie parles tu stp ?
Marsh Posté le 27-12-2008 à 15:31:51
Très belle carte, j'hésite encore entre l'EVGA X58 et celle ci, étant donné que je compte y brancher 3 Carte Graph.
Une petite question tout de même, cette carte étant clairement destiné au marché "workstation and Co" peut-on y brancher une carte X-fi Pci-x?
Je ne vois pas de port prévu à cet effet, les port x8 et x4 peuvent-ils recevoir autre chose qu'une carte graphique?
Marsh Posté le 27-12-2008 à 15:36:16
Fssabbagh a écrit :
Celle-ci
Citation de Marllt2 sur le topic des CM X58 :
Citation : |
Marsh Posté le 27-12-2008 à 15:52:36
djffff a écrit : Très belle carte, j'hésite encore entre l'EVGA X58 et celle ci, étant donné que je compte y brancher 3 Carte Graph. |
salut
comme elle ne comporte pas de port PCI --> pas de x-fi en version PCI ( sauf si adaptateur PCIe vers PCI )
djffff a écrit : |
oui , l avantage du PCIe express c'est que tu puisses mettre des carte ayant des debit plus faible , dans port a debit plus grand ( normalement , le contraire fonctionne aussi )
c'est pour cela que les port PCIe de cet cm sont tous au format 16x
Marsh Posté le 27-12-2008 à 18:02:24
Merci pour ta réponse
Je compte y mettre une X-fi Titanium (donc model en PCI-e)
Marsh Posté le 27-12-2008 à 19:28:34
Schtroumpfetto a écrit : La mienne est arrivée! Je vais la chercher demain matin!!! |
tu l'a commandée où ?
marllt2 a écrit : |
rien n'est sur tant qu'on a pas de tests, pourquoi asus aurait choisi de prendre cette puce sur cette carte, ça m'étonnerait que ce soit juste du marketing mais on verra bien
Marsh Posté le 27-12-2008 à 20:31:56
Fssabbagh a écrit :
L'histoire du vrai SLI hardware avec le NF200 est du 100% marketing de nVidia.
Le NF200 (BR04) est un contrôleur PCI-E avec 16 lanes PCI-E 2.0 en entrée, et 32 lanes PCI-E 2.0 en sortie. Pas de secret donc.
Et si on est pointilleux, on pourrait même dire que le NF200 ajoute de la latence. Le seul avantage est quand 2 cartes (connectées au même NF200) n'utilisent pas leur bus en même temps. Plutôt léger non ? Et qui ne correspond absolument pas à 2 ports PCI-E 2.0 reliés par 32 lanes au northbridge, contrairement à ce que nVidia essaye de faire croire.
elpachato a écrit : pourquoi asus aurait choisi de prendre cette puce sur cette carte, ça m'étonnerait que ce soit juste du marketing mais on verra bien |
Parce que Asus profite aussi du marketing de nVidia.
Annoncer 2 ports PCI-E 2.0 pseudo 16x étant plus vendeur que 2 ports PCI-E 8x.
Tellement vendeur qu'on appelle ça du "vrai" SLI: http://www.clubic.com/actualite-24 [...] e-200.html
Marsh Posté le 27-12-2008 à 22:13:26
elpachato a écrit : |
Salut Elpachato,
Je l'ai commandé chez Power4PC, site de vente IT belge... et pour cause... je suis belge... ;-)
Et je viens de voir que sur Ebay Allemagne, il la propose depuis aujourd'hui soir.
Pour Power4PC, c'est malheureusement un site flammand, mais on peut s'en sortir facilement en anglais.
Le site est bilingue.
Et voilà... Comme le reste du matos n'est pas encore arrivé, je n'y ai pas encore vraiment touché, mais elle est vraiment magnifique!!!
A+
Schtroumpfetto
Marsh Posté le 27-12-2008 à 22:14:55
Oups... adresse du site (on ne sait jamais!):
http://www.power4pc.be
Schtroumpfetto
Marsh Posté le 28-11-2008 à 20:34:03
Salut à tous et bienvenue sur le topic unique de la Asus P6T6 WS Revolution. Après une Rampage II Extreme au bundle et au potentiel d'overclocking démesurées, Asus nous sort la P6T6 WS Revolution. Malgré que cette mobo soit destinée aux stations de travail, il est tout à fait possible de la détourner de son premier usage pour en faire la meilleure carte au monde pour le jeu et l'overclocking, la raison est que les 6 ports PCI Express oui vous avez bien lus sont câblés en 16X graâce à non pas une mais deux puces nforce 200 ! cette mobo est avant tout basée sur le chipset Intel X58 ce qui autorise le SLI ainsi que le Crossfire comme toutes les cartes mères à base de X58. Attention si il vous faudra opter pour des cartes graphiques single slot si vous comptez remplir tous les ports PCI-Express : le problème est que toutes les cartes graphiques décentes prennent 2 voire 3 slot...
Photo détaillées de la bête
Message édité par Fssabbagh le 29-11-2008 à 09:28:23
Messatsu !
