Tension carte mère ou alim ?
Tension carte mère ou alim ? - Carte mère - Hardware
Marsh Posté le 28-08-2009 à 07:17:31
Je rencontre des problèmes de tension que je peux voir sous occt.
Voici mes tests sous occt :
http://www.monsterup.com/upload/1251436135934.png
http://www.monsterup.com/upload/1251436191323.png
http://www.monsterup.com/upload/125143619225.png
http://www.monsterup.com/upload/1251436192931.png
http://www.monsterup.com/upload/1251436257830.png
http://www.monsterup.com/upload/1251436257593.png
http://www.monsterup.com/upload/125143625797.png
Voici les graph généré par everest lors de ce test :
http://www.monsterup.com/upload/125143642093.png
http://www.monsterup.com/upload/1251436420976.png
http://www.monsterup.com/upload/1251436420296.png
http://www.monsterup.com/upload/1251436461164.png
Voici les erreurs de pc probe durant ce test :
[08/27/2009 at 07:20 pm] 1.2VHT Voltage Anormal, 0.00 V
[08/27/2009 at 07:20 pm] SB CORE Voltage Anormal, 3.01 V
[08/27/2009 at 07:20 pm] 1.2VHT Voltage Normal, 1.25 V
[08/27/2009 at 07:20 pm] SB CORE Voltage Normal, 1.55 V
[08/27/2009 at 07:38 pm] 1.2VHT Voltage Anormal, 0.00 V
[08/27/2009 at 07:38 pm] 1.2VHT Voltage Normal, 1.25 V
[08/27/2009 at 07:39 pm] SB CORE Voltage Anormal, 4.08 V
[08/27/2009 at 07:39 pm] SB CORE Voltage Normal, 1.55 V
[08/27/2009 at 07:45 pm] 1.2VHT Voltage Anormal, 0.00 V
[08/27/2009 at 07:45 pm] SB CORE Voltage Anormal, 0.00 V
[08/27/2009 at 07:45 pm] 1.2VHT Voltage Normal, 1.25 V
[08/27/2009 at 07:45 pm] SB CORE Voltage Normal, 1.55 V
[08/27/2009 at 07:47 pm] MEMORY Voltage Anormal, 0.00 V
[08/27/2009 at 07:47 pm] MEMORY Voltage Normal, 1.90 V
[08/27/2009 at 07:52 pm] Vcore Voltage Anormal, 3.26 V
[08/27/2009 at 07:52 pm] Vcore Voltage Normal, 1.36 V
[08/27/2009 at 07:55 pm] 1.2VHT Voltage Anormal, 0.00 V
[08/27/2009 at 07:55 pm] 1.2VHT Voltage Normal, 1.25 V
[08/27/2009 at 07:55 pm] 1.2VHT Voltage Anormal, 3.86 V
[08/27/2009 at 07:56 pm] 1.2VHT Voltage Anormal, 0.00 V
[08/27/2009 at 07:56 pm] SB CORE Voltage Anormal, 3.01 V
[08/27/2009 at 07:56 pm] CPU VTT Voltage Anormal, 0.00 V
[08/27/2009 at 07:56 pm] DDR2 TERM Voltage Anormal, 1.63 V
[08/27/2009 at 07:56 pm] 1.2VHT Voltage Normal, 1.25 V
[08/27/2009 at 07:56 pm] SB CORE Voltage Normal, 1.55 V
[08/27/2009 at 07:56 pm] CPU VTT Voltage Normal, 1.15 V
[08/27/2009 at 07:56 pm] DDR2 TERM Voltage Normal, 0.94 V
[08/27/2009 at 07:57 pm] 1.2VHT Voltage Anormal, 0.00 V
[08/27/2009 at 07:57 pm] SB CORE Voltage Anormal, 3.01 V
[08/27/2009 at 07:57 pm] CPU VTT Voltage Anormal, 1.10 V
[08/27/2009 at 07:57 pm] DDR2 TERM Voltage Anormal, 1.25 V
[08/27/2009 at 07:57 pm] NB CORE Voltage Anormal, 0.00 V
[08/27/2009 at 07:57 pm] 1.2VHT Voltage Normal, 1.25 V
[08/27/2009 at 07:57 pm] SB CORE Voltage Normal, 1.55 V
[08/27/2009 at 07:57 pm] CPU VTT Voltage Normal, 1.15 V
[08/27/2009 at 07:57 pm] DDR2 TERM Voltage Normal, 0.94 V
[08/27/2009 at 07:57 pm] NB CORE Voltage Normal, 1.25 V
Remarque : les erreurs de tension n’apparaissent que lors de test occt, pas dans les jeux (je joue à anno 1404 en ce moment), et pas avec le test de stabilité everest.
Je pense que c’est la carte mère (P5N32 e sli plus) qui n’alimente pas bien les composants. D’après ce que j’ai pu voir sur internet elle est réputée comme mauvaise. De plus le chipstet nvidia est réputé pour chauffer.
Je précise que mon alimentation est une ANTEC true power trio 650W et que sur celle-ci les connecteurs fan only sont hs (j’ai branché sans faire attention 3 ventilateurs alors que c’était pour2).
Je ne sais pas quoi faire….
Est-ce que la carte mère P5Q-E est vraiment bien ? Même si ça m’embête de changer alors que je compte prendre un i9/i7 en 32nm quand ils seront abordable.
Merci pour vos conseils
Marsh Posté le 03-09-2009 à 23:25:00
Perso je trouve le 12V vraiment louche, surtout avec l'alim que tu as.
Déplace ton sujet dans "Boitiers / Alims", tu trouveras plus de monde apte à t'aider.
