Problème de flashage Carte mère - Carte mère - Hardware
Marsh Posté le 02-01-2009 à 17:54:40
| Flash14 a écrit :   |
Tu avais fait comment la première fois?
Je ne comprends pas bien ce que tu fais, tu arrive sous dos avec le lecteur C:\  c'est ça?
vérifie sous dos ce qu'il y a sur ta clé  avec la commande dir.
si tu n'a pas de partition FAT, il y a une procédure spéciale:
Flashing the BIOS for Non-FAT file system
1. Know your model number
a. Open your case and look for the MS-XXXX number on the motherboard between the PCI slots, also check the version number that is written there as well. (some motherboards are named like K8N Diamond, make sure you have the right version number)
b. Boot up your system & take a look at the top left screen during POST, you should see something like “W7100NMS V1.1 021705” This means the board is MS-7100 with BIOS version 1.1
Hint: Many systems are clearing this message very fast, the bios version is then unreadable, and you can either press “PAUSE” or disable the “Quick Boot” in the BIOS setup.
3. Download the BIOS that matches your motherboard AND version number (some motherboards are named like K8N Diamond; make sure you have the right version number). BIOS can be found according to the CPU type of your board like if your CPU is AMD 939 type then look here
http://www.msi.com.tw/program/prod [...] (AMD%20K8)
if you cannot find the BIOS that matches your board, try here <http://www.msi.com.tw/support/bios/more.php>
4. Extract the file you have downloaded to a floppy (not the win ME/98 startup floppy) by double clocking the file in windows mode and supplying the path a:\
5. Boot the computer using windows ME or windows 98 startup disk. It must be one of these! A plain boot disk will not be good enough.
If you do not have Windows ME or 98 to create the floppy you can make one on a friend's computer.
6. When boot is done there will be a message on the screen showing:"Diagnostic tools were successfully loaded to drive" followed by a single letter.
This letter is the letter assigned to the RAMDRIVE. This RAMDRIVE is a virtual drive in the system memory and can be accessed and controlled like any other drive with DOS commands such as:
MD - Make Directory
Copy - copy a file
Delete - Delete a file
There is one important difference which is that being in the system memory this drive is wiped once the computer is restarted or shut down.
7. Replace the startup floppy with the one containing the flash utility and bios ROM files previously extracted in windows.
8. Copy the 2 files to the RAMDRIVE by using the DOS command copy.
Here is an example, in this example the flash utility is AWFL865.EXE ,the ROM file is  W7100NMS.110  and the RAMDRIVE letter assignment is D
copy awfl865.exe d:\
copy w7100nms.110 d:\
9. Change the current working directory to the RAMDRIVE root directory, with the example case of the RAMDRIVE being drive D this is done by simply done with the command d:
10. Execute the flash utility with the ROM file as a command line argument, with this example:
awfl865 w7100nms.110
If you wish to save the current bios you must specify the full path a:\filename. Specifying only a file name will save the bios to the RAMDRIVE which will be wiped after restarting the computer and the file will not be saved.
a:\bios.old is an example of the correct way to save the bios.
11. Reboot your system when prompted
Marsh Posté le 03-01-2009 à 01:16:00
La première fois j'ai utilisé l'utilitaire MSI live Update mais avec ce logiciel je ne peux pas flasher avec un bios plus ancien :S
Merci pour le plan mais j'ai du mal a comprendre   et même avec un traducteur pas très compréhensible les fenetre de windows 98 ou ME ^^
Je pense que mon problème vient du bios que j'ai téléchargé car c'est lui qui ne veux pas se lancer. Pourtant dans l'exemple, le nom du bios ressemble au mien : A7365IMS.140 ( pour le mien ) et W77100NMS.110 ( dans ton exemple ) . Il semblent semblables...
Dans ce que j'ai pu lire il parle d'un dossier au format .bin mais je n'en ai aucun...et également d'un dossier autoexec.bat que je ne trouve pas non plus   . J'ai lu ça ici:
 . J'ai lu ça ici:
http://www.ixtremtek.com/forums/showthread.php?p=2972
Pourtant j'ai bien téléchargé le bios sur le site de MSI.
Donc voila je désèspère
Marsh Posté le 03-01-2009 à 07:05:39
a priori tu mets un espace entre c:\ et le nom du bios ? Parce qu'il n'en faut pas !
Mais effectivement le premier truc à faire c'est taper "dir" pour lister les fichiers présents. Mais le prompt ne devrait pas être c:\ mais celui correspondant à ta clé !
Marsh Posté le 03-01-2009 à 10:58:27
Donc je ne devrais pas avoir C: / mais pluto F: / ? comment faire pour changer ?
Je vais essayer sans l'espace pour voire.
Marsh Posté le 03-01-2009 à 11:03:36
Si tu es sous C:\ tu tapes F:\ et là tu devrais avoir un prompt de F:\
Si jamais ça prompt en pointant sur un dossier il faut simplement taper "CD.." (sans les " ) pour revenir au dossier racine.
(genre pour passer de C:\Program files\ à C:\)
Marsh Posté le 03-01-2009 à 11:14:17
Bon j'ai testé quelque trucs.
c: /Afud408 A7365IMS.140 et la j'ai eu un ouveau message d'erreur=> " Error: Problem opening file for reading " ... j'ai donc un problème de fichier
Par contre quand je rajoute les commandes /p/b/n/c/o derrière j'ai toujours le message  " Error: Unknows command "   .
Donc pour accéder a la clé usb je dois donc taper " C: /F: /? et derrière je tape Afud408 A7365IMS.140 c'est bien ça?
Marsh Posté le 03-01-2009 à 11:16:17
Non tu tapes "F:\" et ça devrait changer le prompt.
Ensuite tu peux taper ta commande Afud408 A7365IMS.140
Maintenant tu devrais recopier le fichier parce-qu'on dirait bien qu'il est corrompu.
Marsh Posté le 03-01-2009 à 11:17:17
ben le problème c'est que j'ai automatique C: / qui apparais devant la ligne.
Pour copier le fichier sur la clé usb il faut bien le faire sous Dos c'est sa?
Marsh Posté le 03-01-2009 à 11:25:05
Si quand tu tapes F:\ ça change pas c'est qu'il n'a pas de lecteur F ...
Essaye plutôt A:\ (vu que ta clé usb doit être une clé de boot -> elle fait croire au DOS que c'est une disquette)
Euh non tu peux le faire sous windows. C'est juste qu'on dirait que ton fichier est corrompu vu le message d'erreur que tu as.
Marsh Posté le 03-01-2009 à 11:39:02
Bon j'ai essayé avec A: / et j'ai un message " Seek error reading drive A: Abort,retry,fail? "
J'ai taper "dir" pour voire et la clé usb est bien la.
J'ai recopier le fichier mais j'ai toujours le message d'erreur qui dit qu'il n'arrive pas a ouvrir le fichier.Pourtant j'ai téléchargé 2fois le bios.
Marsh Posté le 03-01-2009 à 19:16:52
si tu veux taper quelquechose c'est :
a:\ et pas
a: /
Marsh Posté le 03-01-2009 à 19:56:37
Bon et bien par je ne sais quelle miracle, j'ai réussi a flasher le bios ^^
j'ai retapper exactement pareil que la dernière fois et il c'est lancé .
En tout cas merci a vous
Par contre j'ai toujours mon maudit problème de voltage   , dès que j'oc un peux le proco, la voltage n'en fait qu'a sa tete et je me retrouve avec 1.4v au lieu du vcore stock
 , dès que j'oc un peux le proco, la voltage n'en fait qu'a sa tete et je me retrouve avec 1.4v au lieu du vcore stock  .
Je vais essayer avec le vcore en auto dans le bios voir si ça y change quelque chose.... J'en ai marre de cette carte de m**de
Marsh Posté le 02-01-2009 à 16:09:49
Bon voila je souhaite flasher ma carte mère avec un Bios plus ancien car depuis que j'ai flashé le bios par un nouveau, j'ai des problème pour régler les voltages.
Donc voila je souhaite flasher avec une clé usb car je n'ai pas de lecteur disquette.
Donc j'ai rendu ma clé usb bootable et j'ai mis dessu le fichier Afud408.exe qui permet le flashage ainsi que le bios qui se nomme A7365IMS.140
Je lance Afud408 et j'arrive dans un programme. Je dois donc taper le nom du bios pour que le flashage se lance mais le problème c'est que ça ne marche pas et j'ai un message " command unknown".
J'ai essayé plusieurs commande différntes: C
donc voila si quelqu'un peux me dire si mes commandes sont bonnes et que c'est un problème de bios ou mauvaises commandes.
Merci d'avance
