athlon xp 64 2800 (FBS) 1*200mhz - Carte mère - Hardware
Marsh Posté le 30-01-2005 à 20:46:28
oui mais je veux savoir juste si s,es normal que avec ma msi
k8mm et mon a64 2800+ sa m'écris
< Host Interface >
Front Side Bus Speed: 1x 200MHz (200MHz data rate)
Marsh Posté le 30-01-2005 à 20:06:56
je comprent pas j'ai acheté un xp 64 puis j,ai fait l'analyse avec sisoft sandra puis il me dis que j,ai juste 1X 200mhz de front bus !!!! cpu
voici les info de mon bios et mon processeur avec sisoft sandra
je doit faire quoi dans le bios je connais le bios mais ce processeur s,es tou nouveau pour moi
<<< CPU & BIOS Information >>>
<< System BIOS >>
< System BIOS >
Manufacturer: American Megatrends Inc.
Version: Version 07.00T
Date: 04/02/01
Plug & Play Version: 1.00
SMBIOS/DMI Version: 2.30
(EE)PROM Size: 256kB (2Mbit)
< Features >
Can be Updated (flashed): Yes
Can be Shadowed: Yes
Is Socketed: Yes
Supports APM: Yes
Supports ACPI: Yes
Supports Plug & Play: Yes
Supports ESCD: Yes
Supports Enhanced Disk Drive: Yes
Supports Selective Booting: Yes
Supports LS-120 Boot: Yes
Supports ZIP Boot: Yes
Supports BIOS Boot Block: Yes
Supports Network Boot: No
NEC PC-98 Spec Compatible: No
< Performance Tips >
Tip T201: System BIOS is old. Check for an update.
Notice N224: SMBIOS/DMI information may be inaccurate.
Tip T212: BIOS can be shadowed so check whether it is.
Tip T211: BIOS is flash-able and socketed so it can be upgraded
when needed.
Tip T2: For more information about tips, press F1 and scroll
to the Tips section.
<< Processor 1 >>
< Processor(s) >
Model: AMD Athlon(tm) 64 Processor 2800+
Co-Processor (FPU): Built-in
Speed: 1.80GHz
Model Number: 2800 (estimated)
Type: Standard
Generation: 15th (15x86)
Revision/Stepping: C / 0 (0)
< Caches >
Internal Data Cache: 64kB synchronous write-back (2-way, 64 byte line size)
Internal Code Cache: 64kB synchronous write-back (2-way, 64 byte line size)
L2 On-board Cache: 512kB ECC synchronous write-back (16-way, 64 byte line
size)
< Host Interface >
< Mainboard Upgradeability >
Socket/Slot: Socket-754
Supported Speed(s): 3.00GHz (or more)
Supported Voltage(s): 3.3V, 2.9V
< Environment Monitor 1 >
Model: Winbond W83697HF ISA
Version: 6.00
Mainboard Specific Support: No
< Processor Sensors >
CPU Temperature: 28.5°C / 83.3°F
Auto Fan Speed Control: No
CPU Fan Speed: 2519rpm
CPU Core Voltage: 1.49V
< Features >
Co-Processor (FPU) Built-in: Yes
Virtual Mode Extensions: Yes
Debugging Extension: Yes
Page Size Extension: Yes
Time Stamp Counter: Yes
Model Specific Registers: Yes
Physical Address Extension: Yes
Machine Check Exception: Yes
Compare & Exchange Instruction: Yes
Local APIC Built-in: Yes
Fast System Call: Yes
Memory Type Range Registers: Yes
Page Global Enable: Yes
Machine Check Architecture: Yes
Conditional Move Instruction: Yes
Page Attribute Table: Yes
36-bit Page Size Extension: Yes
Unique Serial Number: No
Cache Line Flush Support: Yes
Debug Trace & EMON Store: No
ACPI Technology: No
MMX Technology: Yes
Fast Float Save & Restore: Yes
SSE Technology: Yes
SSE2 Technology: Yes
Self Snoop: No
Hyper-Threading Technology: No
Auto Clock Control: No
IA-64 Technology: No
< Extended Features >
Extended Fast System Call: Yes
Extended AMD MMX Technology: Yes
3DNow! Technology: Yes
Extended 3DNow! Technology: Yes
MP Capability: No
AA-64 Technology: Yes
< Power Management Features >
Voltage Control: Yes
Frequency Control: Yes
Thermal Sensor Built-in: Yes
< Advanced Settings >
< Variable Range MTRR Settings >
MTRR 0: 00000000-0FFFFFFF (0MB-256MB) WB
Message édité par ironamd le 30-01-2005 à 22:19:04
