Achat De Ram Chez Mongallet
Achat De Ram Chez Mongallet - Carte mère - Hardware
Marsh Posté le 11-04-2005 à 09:49:58
bonjour, je compte me rendre à paris demain et donc par la meme occasion je vais allé rue montgallet que je ne connias pas du tout!!! je ne sais pas dans quel magasin allé.
en fait je voudrais acheter une barrette de ram SO-DIMM DDR de 512mo pour mon ordi portable et je ne sais pas laquelle prendre, voilà ma config :
Portable GERICOM Centrino
CPUID Output
Number of CPUs   1
Name    Intel Pentium M
Code name   Banias
Specification   Intel(R) Pentium(R) M processor 1400MHz
Family/Model/Stepping  695
Extended Family/Model  0/0
Brand ID   22
Package    mPGA-479M
Core Stepping   B1
Technology   0.13µ
Instructions Sets  MMX, SSE, SSE2
Clock Speed   1394.4 MHz
Clock multiplier  x14.0
Front Side Bus Frequency 99.6 MHz
Bus Speed   398.4 MHz
Stock frequency   1400 MHz
L1 Data Cache   32 KBytes, 8-way set associative, 64 Bytes line size
L1 Instruction Cache  32 KBytes, 8-way set associative, 64 Bytes line size
L2 Cache   1024 KBytes, 8-way set associative, 64 Bytes line size
L2 Latency   5
L2 Speed   1394.4 MHz (Full)
L2 Location   On Chip
L2 ECC Check   enabled
L2 Data Prefetch Logic  yes
L2 Bus Width   256 bits
Chipset
Northbridge  Intel i855GM/GME rev. A2
Southbridge  Intel 82801DB (ICH4-M) rev. 3
Memory Type  DDR
Memory Size  256 MBytes
Memory Frequency 132.8 MHz (3:4)
CAS#   2.5
RAS# to CAS#  3
RAS# Precharge  3
Cycle Time (tRAS) 6
Memory SPD
DIMM #1
General
Memory type  DDR-SDRAM
Manufacturer (ID) Nanya Technology (7F7F7F0B00000000)
Size   256 MBytes
Max bandwidth  PC2100 (133 MHz)
Part number  NT256@64SH8B0GM-75
Manufacturing date Week 12/Year 03
Attributes
Number of banks  2
Data width  64 bits
Correction  None
Registered  no
Buffered  no
Timings table
Frequency (MHz)  100 133
CAS#   2.0 2.5
RAS# to CAS# delay 2 3
RAS# Precharge  2 3
TRAS#   5 6
DMI System Information
System #1
 manufacturer Gericom
 product  M350C/M375C
 version  None
 serial  12345678
 UUID  FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
DMI Baseboard
Baseboard #1
 vendor  KAPOK
 model  Intel 852/855GM
 revision None
 serial  12345678
DMI System Enclosure
System enclosure #1
 manufacturer KAPOK
 chassis type Portable
 chassis serial 12345678
DMI Processor
CPU #1
 manufacturer GenuineIntel
 model  Pentium III
 clock speed 1394.0MHz
 FSB speed 1394.0MHz
 multiplier 1.0x
CPU #2
 manufacturer unknown
 model
 FSB speed 65024.0MHz
Marsh Posté le 11-04-2005 à 09:53:26
Dans n'importe quelle boutique, un peu sérieuse, il testeront la ram devant toi sur ton ordi.
Sinon va par curiosité à Surcouf comparer les prix avant car tu seras surpris de la peu de différence de prix avec certaines boutiques.
Et question SAV ;) c'est pas une garantie jusqu'au pas de la porte comme certaines enseignes de Montgallet.
Message édité par Mastic84 le 11-04-2005 à 09:54:01
Marsh Posté le 11-04-2005 à 09:55:28
512MO DDR-SDRAM SO-DIMM PC2100 de marque (Corsair, Kingston, Samsung par exemple)
Marsh Posté le 11-04-2005 à 09:55:37
Vala une liste de tarifs avec les boutiques qui le pratique.http://www.rue-montgallet.com/prix [...] ow=0&nbf=4
Message édité par Profil supprimé le 11-04-2005 à 09:55:46
Marsh Posté le 11-04-2005 à 10:00:14
merci!!
dois-je prendre une ram de marque??
la ram a 67euros ne conviendrait-elle pas??
Marsh Posté le 11-04-2005 à 10:11:48
prend une de marque tel que a-data par exemple qui est tres bien. le Noname c pas bien et pas seulement dans les ram, mais pour tout.
Message édité par Profil supprimé le 11-04-2005 à 10:12:35
Marsh Posté le 11-04-2005 à 10:27:00
par contre vous pensez qu'il vaut mieux attendre encore un peu que les prix baisses ou non? car le besoin de ram n'est pas urgent, si ce n'est pas la peine d'attendre je l'acheterai.
et pourquoi la noname n'est pas bonne?
pour la ram a-data, pour 5euros de plus j'ai de la corsair, c'est pas mieux?
Message édité par anonymman le 11-04-2005 à 10:28:07
Marsh Posté le 11-04-2005 à 10:39:14
Ben si t'en a pas besoin l'achete pas, si tu as l'occase comme tu dis d'aller a paris et de passer dans le 12ieme ben moi perso je l'acheterais :) surtout si tu pense ne pas revenir avant un bon moment. A propos du noname ben je vais pas etaller sur sa tu as juste a lire quelques posts et tu veras que le noname ben c'est de la m**** dans ton cas tu as tout intéré a prendre de la marque sans quoi je ne te garantit pas que cela marche longtemps.
Edit :
Corsair ben c un peut cher pour ce que c'est.
Message édité par Profil supprimé le 11-04-2005 à 10:40:29
Marsh Posté le 11-04-2005 à 13:08:03
ok merci!
sinon y'a de la kingston a 84euros, je pense que c'est du bon matos ça non?
par contre le revendeur va me s'installer sur place la barrette de ram?? mon ordi est garanti dans mon magasin (grande surface) jusqu'à juin 2005, la garantie va-t-elle sautée si je fais installé la ram a montgallet?
comment savoir si la ram que le revendeur va m'installé fonctionne sur mon ordi?
Marsh Posté le 11-04-2005 à 17:09:59
oui kingston c'est une bonne marque
par contre pour l'install et meme le prix pratiqué en boutique-> un petit coup de fil!!! ca evite les surprises
Et pour ta garantie=??? pour moi ca saute, car tu as changé un composant. Faut peut etre repasser par ton revendeur pour faire la modif
Message édité par breizhfan le 11-04-2005 à 17:10:43
        ...Smile don't shine...
Marsh Posté le 11-04-2005 à 18:21:29
ok merci de vos conseils, j'irai voir chez tdi systems ou e-soph qui m'ont l'air pas mal puisqu'ils sont pas mal notés.
Marsh Posté le 12-04-2005 à 12:27:53
bonjour
que vaut la memoire Hynix??
Marsh Posté le 12-04-2005 à 12:42:06
C'est pas de la noname mais je préfère pendre de la pqi, l'a-data a bonne réputation mais je n'ai pas testé [:spamafote]
Pour les bon magasins, fais un tour sur le forum de montgallet
Marsh Posté le 12-04-2005 à 13:15:25
Ou alors commande direct chez Crucial, c'est pas beaucoup plus cher que Montgallet, c'est pas beaucoup plus lent (ils sont très rapide pour la livraison), ils garantissent la RAM à vie, et ils garantissent que la RAM est compabible avec ton modèle spécifique de portable... Ca fait beaucoup plus de tranquilité pour quelques euros de plus!
Une RAM foireuse, c'est la pire perte de temps (et de nerfs) qu'on puisse faire...
Marsh Posté le 12-04-2005 à 13:35:15
merci pour votre aide a tous
lictor, je pense que je vais profiter de montgallet car je ne suis pas de la région parisienne, je leur demanderai de tester la ram sur mon portable, comme ça pas de souci de compatibilité!
Marsh Posté le 12-04-2005 à 13:35:52
par contre comment savoir que la ram sera bien compatible avec ma machine lorsqu'ils vont le tester devant moi?
Marsh Posté le 12-04-2005 à 13:38:47
L'idéal: tu te pointes avec ta disquette de boot avec memtest dessus, et tu demandes à pouvoir faire tourner une passe... Dans ce cas, éviter impérativement le samedi (pas bon pour les nerfs de toute façon)! Et viser plutôt les boutiques un peu plus haut de gamme (plutôt coté Charenton que Montgallet) et pas les moins chères (qui refuseront probablement)...
Marsh Posté le 12-04-2005 à 13:45:00
lictor peux tu me donner quelques bonnes boutiques sur montgallet??
merci c'est sympa
ps : pas de lecteur disquette sur mon portable donc pas de disquette boot
Message édité par anonymman le 12-04-2005 à 13:47:13
Marsh Posté le 12-04-2005 à 14:21:43
pour ce genre de chose, bonne boutique avec bon tarif et qui te laisse tester la ram: price hunter.
(si t'as pas de lecteur d7, grave un ultimate boot cd. (recherche ubcd sur google)
Message édité par DraX le 12-04-2005 à 14:22:19
| Un malentendu du cul | boum boum ! | La roulette
