[Topic Unique]Asrock 4Core1333-FullHD (Chipset AMD pour CPU Intel...)
Asrock 4Core1333-FullHD (Chipset AMD pour CPU Intel...) [Topic Unique] - Carte mère - Hardware
Marsh Posté le 19-09-2007 à 23:54:56
Je me suis décidé à prendre un truc moins cher (82 euros chez Compumsa) histoire de tester.
(ou comment attendre le X38 en perdant son argent...)
Je compte passer mon core 2 quad Q6600 Rev G0 à 3600 Mhz sur cette carte mère.
4Core1333-FullHD
Support:
LGA 775 for Intel® Core™ 2 Quad / Core™ 2 Extreme / Core™ 2 Duo / Pentium® XE / Pentium® D / Pentium® Dual Core / Pentium® 4 / Celeron® / Celeron® D, supporting Quad Core Kentsfield processors
Chipset:
ATI™ RS600 + SB600 Chipsets
Compatibilité:
Compatible with all FSB1333/1066/800/533MHz CPUs
Supports Dual Channel DDRII800/667/533 with 4 DIMM slots, maximum capacity up to 8GB
Features
Integrated ATI™ X1250 graphics, supports H/W T&L, DirectX 9.0, Max. shared memory 512MB
1 x PCI Express x 16 slot
Untied Overclocking : During Overclocking, FSB enjoys better margin due to fixed PCIE/ PCI Buses
Hybrid Booster - Safe Overclocking Technology
Dual VGA Output: Support DVI-D and D-Sub ports by independent display controllers
Supports HDCP function with DVI-D port, to enjoy better quality with High Definition HDCP Encryption contents
Supports 1080p Blu-ray (BD) / HD-DVD playback with DVI-D port
Supports PCIE Gigabit LAN 10/100/1000 Mb/s
Supports 2 x IEEE 1394 ports (one port on back panel, one header on board)
4 x SATAII 3.0 Gb/s, support RAID (RAID 0, RAID 1, RAID 0+1, JBOD and RAID 10) , NCQ, AHCI and "Hot Plug" functions
Chipset embedded HDMI Audio which supports HDMI signal through DVI-D port by using DVI to HDMI adapter (not bundled)
7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec)
Windows® Vista™ Premium 2007 Logo Ready
ASRock DVI_1394 I/O: 1 x VGA/DVI-D Port, 1 x VGA/D-Sub Port, 1 x IEEE 1394 port
Bref ça à l'air sympa, je dis l'air car on sait tous que asrock et overclocking ça fait tâche...
Specifications plus en détail:
General
CPU - LGA 775 for Intel® Core™ 2 Quad / Core™ 2 Extreme / Core™ 2 Duo / Pentium® XE / Pentium® D / Pentium® Dual Core / Pentium® 4 / Celeron® / Celeron® D, supporting Quad Core Kentsfield processors
- Compatible with all FSB1333*/1066/800/533MHz CPUs
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
*FSB1333-CPU will operate in overclocking mode.
Chipset - Northbridge: ATI™ RS600
- Southbridge: ATI™ SB600
Memory - Dual Channel DDRII memory technology
- 4 x DDRII DIMM slots
- Supports DDRII800/667/533
- Max. capacity: 8GB*
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® XP and Windows® Vista™. For Windows® XP 64-bit and Windows® Vista™ 64-bit with 64-bit CPU, there is no such limitation.
BIOS - 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
Audio, Video and Networking
Graphics - Integrated ATI™ X1250 graphics
- DX9.0 VGA, Pixel Shader 2.0
- Max. shared memory 512MB
- Dual VGA Output: support DVI-D and D-Sub ports by independent display controllers
- Supports HDCP function with DVI-D port
- Supports 1080p Blu-ray (BD) / HD-DVD playback with DVI-D port
Audio - 7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec)
- Chipset embedded HDMI Audio
LAN - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111B
- Supports Wake-On-LAN
Expansion / Connectivity
Slots - 1 x PCI Express x16 slot
- 1 x PCI Express x1 slot
- 2 x PCI slots
- 1 x HDMR slot
Connector - 4 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 0+1, JBOD and RAID 10), NCQ, AHCI and "Hot Plug" functions
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x IEEE 1394 header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports)
Rear Panel I/O ASRock DVI_1394 I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x VGA/D-Sub Port
- 1 x VGA/DVI-D Port
- 1 x Parallel Port (ECP/EPP Support)
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x IEEE 1394 Port
- 1 x RJ-45 Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Other Features / Miscellaneous
Hybrid Booster - CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version)
Accessories - Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 cables
- 1 x SATA data cable (optional)
- 1 x SATA 1 to 1 power cable (optional)
- 1 x COM port bracket
Hardware Monitor - CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, CPU Vcore
Form Factor - Micro ATX Form Factor: 9.6-in x 9.6-in, 24.4 cm x 24.4 cm
OS - Microsoft® Windows® 2000 / XP / XP 64-bit / Vista™ / Vista™ 64-bit compliant
Certifications - FCC, CE, WHQL
Les images:
http://img1.qq.com/digi/pics/4610/4610929.jpg
http://www.ocworkbench.com/2007/asrock/4Core1333-FullHD/ASRock%204Core1333-FullHD%20001%20copy.jpg
http://www.ocworkbench.com/2007/asrock/4Core1333-FullHD/ASRock%204Core1333-FullHD%20002%20copy.jpg
Pour ce qui est le l'overclocking, ça s'annonce mal mais je tente la chose... Première fois que je prends le risque de foutre en l'air une carte mère mais bon vu le prix...
http://overclocking-masters.com/fo [...] pid=203770 -> ça sent pas bon...
Message édité par renardin6 le 20-09-2007 à 08:33:20
Marsh Posté le 20-09-2007 à 02:05:20
Non le lien que tu donne est pour l'overclocking d'un cpu a fsb 333Mhz qui s'obtient deja par overclocking sur cette carte, il est normal que le resultat ne soit pas super.
Par contre pour ce qui est l'overclocking des cpu a fsb 800 ou 1066Mhz elle est deja bien mieux et permet de fixer la frequence de la ram independamment du fsb.
Marsh Posté le 20-09-2007 à 08:14:51
Ah bon, tu as déjà la carte? Moi je l'aurai demain...
Avec un Zalman 9700, je peux passer le FSB à 400 sur cette carte mère? J'ai de la crucial cas 4 à 800 Mhz...
Des conseils? Je dois faire attention à quoi dans mon réglage? (on est sur asrock quand même)
Message édité par renardin6 le 20-09-2007 à 08:24:34
Marsh Posté le 20-09-2007 à 09:34:54
tout est ds le topic en signature!  :)
pas de fsb@400 avec ce chipset (gd max fsb@370 si le cpu tient vu qu'il y a pas de vcore ajustable...)
Message édité par pvhk le 20-09-2007 à 09:37:42
Topic unique-monter un PC matx à base de C2D: petit mais costaud
Marsh Posté le 20-09-2007 à 14:16:03
bah...X38 en octobre... Merci quand même pvhk :)
Message édité par renardin6 le 20-09-2007 à 14:16:25
Marsh Posté le 08-10-2007 à 15:16:51
Moi j'ai cette carte qui se comporte très bien en overclocking par contre le radiateur sur le chipset ATI chauffe dur. Sinon rien à redire de cette carte
Marsh Posté le 09-10-2007 à 23:06:26
Asrock a été mesquin car l'adaptateur DVI vers HDMI n'est pas fourni avec la carte mère, ils ont organisé un tirage au sort avec comme lot un connecteur DVI->HDMI et un cable HDMI nommé Lucky Draw : heureusement que j'ai gagné :)
Marsh Posté le 10-10-2007 à 08:32:30
Tu as quoi comme proc et a combien l'oc tu?
Marsh Posté le 10-10-2007 à 08:48:46
Dessus j'ai un malheureux Pentium E2140 overclocké à 2,4Ghz et d'une stabilité exemplaire.
Marsh Posté le 10-10-2007 à 12:31:51
Tu n'a pas reussi a pousser plus?
Marsh Posté le 10-10-2007 à 14:29:24
Si on peut le monter plus mais il chauffe et comme j'ai un boitier Hiper (de merde au passage), le ventirad ne fait que 3cm de haut et à donc une mauvaise dissipation thermique.
