victime de redemarrage aleatoire (1 de plus!!)
victime de redemarrage aleatoire (1 de plus!!) - Matériels & problèmes divers - Hardware
Marsh Posté le 10-03-2007 à 13:25:47
Bonjour, mon pc redemarre quand il veut sans ecran bleu. J ai fait un test de ram: ok
Des minidump sont crées. Voici le dernier:
Microsoft (R) Windows Debugger  Version 6.4.0007.2
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\Telechargement\Mini021507-02.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 1) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d4000 PsLoadedModuleList = 0x8054be30
Debug session time: Thu Feb 15 19:50:15.718 2007 (GMT+1)
System Uptime: 0 days 0:21:27.320
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {8, 2, 0, f781937a}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Unable to load image usbehci.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for usbehci.sys
*** ERROR: Module load completed but symbols could not be loaded for usbehci.sys
Probably caused by : usbehci.sys ( usbehci+237a )
Followup: MachineOwner
Ma config:
CM km2m combo series
DD Maxtor 6L250R0
CG asus radeon a9200se
Creative soundblaster live! series
amd athlon xp 1.25GHz
768 de RAM
alim advance 300w
OS XP Pro
Avez vous une idée? Merci
Marsh Posté le 11-03-2007 à 13:06:16
up!
Marsh Posté le 11-03-2007 à 13:18:15
alors, ton pc a toujours redemaré comme cela, ou bien c'est depuis peu ?
Ventes Matos PC / Apple
Marsh Posté le 11-03-2007 à 13:22:57
nettoie les radiateurs de leur poussière
Marsh Posté le 11-03-2007 à 22:26:49
Merci pour vos contributions.
"alors, ton pc a toujours redemaré comme cela, ou bien c'est depuis peu ?"
C est un second pc que j ai monté recemment. Et effectivement il a tjs fait ainsi.
"nettoie les radiateurs de leur poussière"
C est chose faite. Cependant avec speedfan, je monte au dela des 52°. Ma carte mere se mettrait elle en securité? Cette t° est elle la normale d utilisation?
Apparament le fichier n est pas d une tres grande utilité?
Message édité par jumpman le 11-03-2007 à 22:32:46
Marsh Posté le 12-03-2007 à 06:02:59
elle ne se mets pas en sécurité puisqu'elle plante ^^
Laisse la tour ouverte, et fait un test avec occt ,
regarde si c'est stable comme ça.
Si c'est le cas, soit tu laisses ouvert,
soit tu changes de ventirad.
http://www.ocbase.com/download/OCCTPT1.1.0.exe
Message édité par Xixou2 le 12-03-2007 à 06:03:13
Marsh Posté le 12-03-2007 à 06:43:59
l'alim me plaît pas du tout, tu l'a acheté combien ?
et tu es sur que ça ne puissent pas venir de la RAM ? essaye avec une seule barrette et si ça recommence, change de barrette.
Marsh Posté le 15-03-2007 à 20:15:32
"elle ne se mets pas en sécurité puisqu'elle plante ^^ "
Justement je croyais que c etait pour eviter que je crame un composant que la carte mere coupe d elle meme avan qu il ne soit trop tard.
En tout cas je fais d autre test et je vous tiens au courant
Marsh Posté le 16-03-2007 à 08:25:37
tu devrais essayer de reposer cette question dans la section "soft" voire si ca vient pas de windows, je trouve que ton rapport mentionne souvent des problemes avec le kernel ou bien formater et tout reinstaller, tu as deja essayé?
Marsh Posté le 17-03-2007 à 19:37:05
Oui le systeme est propre et formater
Marsh Posté le 23-03-2007 à 05:34:50
La puissance de l'alimentation me paraît un poil juste.
