Pb d'USB qui se deconnecte lors de transferts DD à DD - Matériels & problèmes divers - Hardware
Marsh Posté le 18-03-2003 à 15:06:33
ben si ton modem bouffe de l electricité sur l usb
et que ton dd aussi t a trouver d ou vient le problem je croit
peut etre un hub avec alimentation externe resoudrait le problem
Marsh Posté le 18-03-2003 à 15:24:40
Ah ben merde
avec une antec true color 330 W , tu crois ?
Marsh Posté le 18-03-2003 à 15:29:06
c'est du kt133a ça, le chip est buggé au niveau de l'ide et des transferts de (gros) fichiers, faut lui donner à manger le bon pci latency patch.
Marsh Posté le 18-03-2003 à 16:11:09
Section 4: The 686B bug
4.1 What is the "686B" bug?
In early 2001, it was discovered that new motherboards with the KT133A chipset could damage data that was being copied between IDE hard disks. The problem was narrowed down to the VT82C686B chip on the motherboard. When the computer's PCI bus was busy, any data copied between the primary and secondary IDE buses could be corrupted. In addition, the computer could crash or reboot during this copying.
The problem occurred more often when a Creative Labs Soundblaster Live card was present.
4.2 Does this patch fix the "686B" bug?
Yes, sort of. This patch is a workaround for the problem, not a complete solution. This patch adjusts the PCI bus to permit the 686B chip to deliver more data without interruption, which has the effect of reducing or eliminating the 686B bug.
Please note that this patch has grown over time to solve more than just the problem of 686B IDE corruption.
4.3 Is the "686B" bug VIA's fault?
The problem seems to be the fault of a bug in the VT82C686B chip. VIA has acknowledged the issue and began working with motherboard manufacturers to stabilize motherboards that have the problem.
4.4 Does this patch do something to the 686B chip?
No. This patch changes settings in the chip that is controlling the 686B. This patch does not directly adjust the 686B chip.
http://www.georgebreese.com/net/so [...] qvl019.htm
Marsh Posté le 18-03-2003 à 22:17:11
3 h après :
Merci beaucoup.
je download et j'essaie meme si je me chie un peu dessus de mettre un nouveau truc qui change la config
J'ai pas souvent de longues periodes de stabilité
Marsh Posté le 18-03-2003 à 15:01:16
Kt7a
TB1.2
512sdram 133
DDmaster Seagate barracuda ata 5 80Go
DDslave IBM 180gxp 80Go
Salut à tous
Connecté par un modem Sagem fast 800 USB sur freeadsl,la synchronisation passe au rouge d'un coup dès que je transfert de gros fichiers de DD à DD: je suis alors obligé de débrancher l'usb du modem pour enlever le petit triangle de la barre des taches puis je le reconnecte et là , normal , rouge puis jaune puis vert (synchronisé) et je peux me reconnecter .
Quelqu'un a t-il une solution ?
Merci d'avance
