3 BSOD sur XP nouvellement installé - Matériels & problèmes divers - Hardware
MarshPosté le 08-10-2012 à 12:46:47
J'ai eu plusieurs écran bleu différent en peu de temps et je n'arrive pas à en trouver la cause. Help merci
Ce que j'ai fais : -Réinstallation en mettant les drivers constructeur. -2 Tests de ram. -2 Tests pour le disque dur un long,un court. 0x100000D1 -Changer la nappe de disque dur. 0x100000D1 -J'ai aussi changer le clavier Pas d'overclock c'est un vieux packardbell ml2w d1521.
On Sun 07/10/2012 16:57:35 GMT your computer crashed
This was probably caused by the following module: ntoskrnl.exe (nt+0xA892) Bugcheck code: 0xA (0x49507621, 0x2, 0x0, 0xFFFFFFFF804E63B9) Error: IRQL_NOT_LESS_OR_EQUAL file path: C:\WINDOWS\system32\ntoskrnl.exe
description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Sun 07/10/2012 13:35:21 GMT your computer crashed
This was probably caused by the following module: acpi.sys (ACPI+0xB35E) Bugcheck code: 0x100000D1 (0x2, 0xA, 0x0, 0x2) Error: CUSTOM_ERROR file path: C:\WINDOWS\system32\drivers\acpi.sys
description: Pilote ACPI pour NT The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
Marsh Posté le 08-10-2012 à 12:46:47
Ce que j'ai fais :
-2 Tests de ram.
Error: CUSTOM_ERROR
