[Topic Unique] Thermaltake level 10 GT
Thermaltake level 10 GT [Topic Unique] - Boitier - Hardware
Marsh Posté le 29-03-2011 à 10:01:17
:hello:  à tous,
Je vous présente le frères du Level 10  Le Thermaltake level 10 GT pour plus ou moins 300 €  :pt1cable:
Présentation en vidéo
http://www.youtube.com/watch?v=yfP [...] re=related
Disponibilité des premières pièces annoncée pour la première semaine d'avril.
Les photos
http://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/03bee02e-f725-4e81-9d5e-1cab804b0ed6/B_DSC_1219.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/0c3de643-2e17-4383-99b7-a964645ddc23/B_DSC_1225.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/a0b60822-8a65-44b7-a38c-2ebcaa066b0d/B_DSC_1240.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/b456775f-7c73-4237-8b63-c4c5a7bac2d3/B_DSC_1297.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/6079d2af-0155-49dc-a353-e62bf0108fcb/B_DSC_1307.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/fd2e376f-cea4-4048-a403-86a288f071de/B_DSC_1320.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/62be6b46-5872-41f9-a68e-714eb8e21da0/B_DSC_1471.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/0150a5af-641a-456b-adb6-68c700be9c59/B_Triple%20Colorshift.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/ecd897a1-9402-49be-bb2c-ebe777c31cd8/B_DSC_1408.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/c6f7c057-0782-4f3c-b497-284100911572/B_DSC_1411.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/2892e6ac-bcda-4831-a3a1-cfbdfab5a5e6/B_DSC_1459.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/c87e8959-aa0a-419a-b18f-b580bf07d6fb/B_DSC_1369.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/f1abd7ef-8330-4c95-bb79-d09ea79a993a/B_DSC_1339.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/95869d82-0ca7-4d2f-b855-28c58abc084d/B_DSC_1325.jpg.jpghttp://www.thermaltakeusa.com/Upload/Product/Product/2039/Photos/5800d7e3-7df0-410f-b63f-a51662e6d9f0/B_Air%20Flow%2002.jpg.jpg
Descriptif de materiel.net
En avance sur son temps !
Ce petit bijou de 58 cm de haut et 12,7 Kg entièrement constitué de noir (à l'intérieur également) vous donnera d'abord une fois ouvert un sentiment d'espace et de liberté puisqu'il a été conçu pour embarquer à son bord un maximum de composants ! Il vous laissera le choix pour la taille de votre carte mère, puisqu'il peut accueillir les formats les plus récents comme l'E-ATX, ou plus classiques comme l'ATX ou le Micro-ATX. Son large espace lui permet de pourvoir héberger les cartes graphiques les plus récentes et les plus longues ! L'USB 3.0 fait également parti de l'aventure, avec 2 ports présents sur le dessus, en plus des 4 USB 2.0 en façade, des ports audio et du port e-SATA sur le dessus également !
Objet de nombreuses attentions, les disques durs sont ici traités comme des rois. Chaque unité profite ainsi d'un rack personnel. Ce dernier accepte les formats 3.5" mais également les formats 2.5" et donc les SSD. Après installation du disque, le rack se fixe sur un backpanel Hot-Swap pour un branchement / débranchement à chaud de vos unités.
Tempête de fraîcheur
Toujours basé sur une architecture séparant les différents éléments, ce Level 10 GT a été pensé et conçu à la perfection pour refroidir vos composants les plus puissants ! Attention aux yeux : il embarque 4 ventilateurs intégrés de (3 de 200 mm et 1 de 140 mm) dont 3 répondant à la technologie ColorShift. Celle-ci vous propose 5 types d'éclairage différents avec plusieurs couleurs selon vos envies. Vous pourrez également contrôler la puissance des ventilateurs à l'aide d'un bouton sur la partie supérieure.
Une multitude d'équipements de série
Contrairement aux voitures où vous devez rajouter toute une pléiade d'options, ici tous les équipements sont de série ! Prenons par exemple la sécurité qui est maximale puisque vous pourrez verrouiller le boitier grâce à un système de clés en 3 endroits, de quoi partir en LAN l'esprit tranquille ! Halte à la poussière qui encrasse les boitiers : ici des filtres à poussière sont présents en de nombreux endroits ! Le Level 10 GT est équipé et prévu pour le watercooling et dispose d'un support pour poser votre casque audio: il fallait y penser !
Les Caracteristiques:
Sons Design:
Châssis                  Acier
Couleur extérieure  Noir
Couleur intérieure  Noir
Porte vitrée          Oui
Dimensions                 282 x 590 x 584 mm
Poids                         12,7 Kg  :na:
Carte mère
Format(s)                 E-ATX / ATX / Micro ATX
Ports d'extension        8
Plaque amovible         Non
Alimentation
Alimentation fournie  Non
Format(s)                  ATX
Position                  Basse Voir photos
Les Baies HDD etc....
Baie 3.5" - interne (max)  5
Baie 3.5" - externe (max)  1
Baie 2.5" - interne (max)  5 via emplacements 3,5"
Baie 5.25" (max)                  4
Cage pour HDD                 Oui
HDD orienté(s) à 90°         Oui
Kit anti-vibrations         Oui
La Ventilation
Nombre de ventilateurs fournis  4
Ventilateurs fournis  1 x 200 mm frontal (ventilateur Colorshift 3 couleurs)
1 x 140 mm arrière
1 x 200 mm supérieur (ventilateur Colorshift 3 couleurs)
1 x 200 mm latéral (ventilateur Colorshift 3 couleurs)
Emplacements supplémentaires  1 x 120 mm arrière
Régulateur de vitesse  oui, 2 vitesses
Filtre anti-poussière  Oui
Entrées d'air          Oui
Passes-tuyaux watercooling  Oui
Ergonomie (Front panel )
2 x USB 3.0
4 x USB 2.0
1 x eSATA
2 x HD Audio
Les liens
Constructeur
http://fr.thermaltake.eu/
Les teste
http://benchmarkreviews.com/index. [...] &Itemid=61
Boutique en ligne
http://www.materiel.net
http://www.generation-nt.com/achet [...] 34071.html
http://www.topachat.com/pages/deta [...] 49217.html
Je ferrais les Modification de mon poste aux fil du temps
Message édité par sheldon2 le 29-03-2011 à 10:22:13
Marsh Posté le 29-03-2011 à 10:26:43
Je passe commande de se boitier le 7 avril  :love:
Marsh Posté le 29-03-2011 à 16:49:45
Si le prix est de 300e, je trouve qui ne l'ai fais pas du tout.
Je l'aurais plus situer entre 150/200e sauf si on me prouve vraiment qu'il vaut son prix
Marsh Posté le 29-03-2011 à 17:27:23
Encore si esthétiquement il était proche du Level 10 mais en plus petit, pourquoi pas 300€, mais là on est quand même assez loin du Level 10 même s'il y a "un air" de ressemblence...niveau qualité ça n'a pas l'air d'être ça... :/
Marsh Posté le 29-03-2011 à 21:10:42
Sur les vidéo il ma l'air de bonne qualité mai c'est vrais que le prix et un peux trop élevé   :o
si je le prend c'est surtout pour les partie séparer Mais dommage que lalim soie avec la CM  :pfff:
Message édité par sheldon2 le 29-03-2011 à 21:12:25
Marsh Posté le 29-03-2011 à 22:45:10
+1 les tofs sont un peu trompeuse,il rend mieux en vidéo   :jap:
Message édité par Cizia le 29-03-2011 à 23:08:23
Un Ami ? C'est quelqu'un à qui on peut téléphoner à trois heures du matin en disant qu'on vient de commettre un crime et qui vous répond seulement : " Où est le corps ?! " ~/~ Alain Delon
Marsh Posté le 30-03-2011 à 08:41:48
Traduction du testes de chez benchmarkreviews.com
Merci google ^^
Les performances de cette affaire a été excellente. Le fond de panier SATA, câble multiple trous de routage, et l'intérieur de grandes rendre facile à construire dans, tandis que la porte latérale arrière à ouverture et caddies disque pop-out difficile d'apporter des améliorations le système d'un jeu d'enfant. Les serrures de sécurité et grande poignée de transport indiquent que Thermaltake pense que vous pourriez prendre ce à des LAN, et bien que cela est certainement possible, 28-livre de l'affaire poids à vide peut-être plus que la plupart des gens veulent essayer de trimballer. Les trois ventilateurs de 200 mm, combinés avec le ventilateur arrière 140mm, un refroidissement suffisant avec peu de bruit, bien que sous stress les cartes vidéo et exécuter un CPU plus chaud de quelques degrés que ce qu'ils font dans le cas Fortress FT02 Silverstone.
Fonctionnellement, Thermaltake a réussi à intégrer et même améliorer certaines des caractéristiques de l'original Niveau 10 cas. Pop-out caddies disque dur sont sont améliorées avec le fond de panier standard SATA, et les fans inclus un refroidissement beaucoup mieux que les fans plutôt faible inclus avec le niveau 10, qui ont été tout simplement insuffisant pour les systèmes multi-GPU haut de gamme. L'élimination de certains "bling" des fonctionnalités telles que les baguettes lumineux et dur feux de présence disque est compensée dans une certaine mesure par les fans contrôlée éclairage.
La qualité de la construction de l'affaire a été très bonne, même si je pense qu'il ya beaucoup trop de plastique pour une affaire dans cette gamme de prix. On peut soutenir que, si, Thermaltake appliquée de l'argent qui aurait été consacré à plus de métal des caractéristiques fonctionnelles, comme le câblage du ventilateur pré-configuré et fond de panier SATA, et en regardant les choses de ce point de vue, je pense que c'est un compromis raisonnable.
La valeur de ce cas est plus difficile à évaluer, mais il dépend de ce que vous cherchez. Les caractéristiques de ce cas qui tiennent compte de son coût sont celles qui rendent le développement et la modernisation d'un système plus facile, si vous avez tendance à construire un ordinateur et non pas le changer pour un an ou deux, votre argent pourrait être mieux dépensé ailleurs. Si, d'autre part, vous êtes le type qui va rarement une semaine sans plonger dans le matériel, l'achat de ce cas est une décision beaucoup plus facile à faire.
L'apparence est toujours subjective. Les fabricants cherchent à rendre leurs produits distinctifs, et d'accomplir cela de différentes manières. Cas visant à enthisiasts et les joueurs sont presque toujours en noir ces jours-ci, en effet, le cas passionné de noir ordinateur est un stéréotype autant que le boîtier de l'ordinateur beige a été dans les années 1990, même si, le niveau 10 GT a une apparence distincte que les amateurs et les joueurs apprécieront (même s'il est difficile de l'imaginer dans un environnement de bureau).
Thermaltake a fait un excellent travail avec le niveau 10 GT, ce qui porte le style et la plupart des caractéristiques de l'original de niveau 10 à un prix qui, bien que toujours élevé, est au moins plus abordable pour beaucoup. Costing "seulement" $ 269,99 à Newegg, c'est maintenant un de mes cas préférés sur l'ordinateur. Mais bon, si vous voulez vraiment le nec plus ultra, l'original de niveau 10 est toujours disponible à Newegg pour seulement $ 699,99!
Marsh Posté le 30-03-2011 à 18:13:26
Design by Lada :o
VDS Signature 850W, Koss SB49, Ventilos ||| Feed-Back ||| Sauve toi, sauve moi, et tu sauras où l'acheter le courage
Marsh Posté le 31-03-2011 à 13:30:45
:D
Marsh Posté le 03-04-2011 à 11:11:10
Si la qualité, le silence et le refroidissement sont tel que le prix je pourrai m'y tenter, affaire à suivre.
Marsh Posté le 04-04-2011 à 22:42:13
Mouais :o
J'ai le poignet loin derrière | Top hontes HFR | [VDS] Montres | [VDS] de l'histoire
Marsh Posté le 20-04-2011 à 02:25:05
un truc me fait peur....n importe quel ventirad passe dedans?
Marsh Posté le 14-05-2011 à 12:19:28
Pour répondre à kruugh, je possède ce boîtier, j'ai un Noctua NH-U12P SE et ça passe large. Maintenant, n'ayant pas de NH-D14 ni de Silver Arrow, et n'en n'ayant jamais vu, je ne saurais te dire.
En terme de qualité; l'ensemble est d'excellente qualité, pour le silence, il ne fait strictement aucun bruit.
Marsh Posté le 09-06-2011 à 18:42:59
un bon lvl 10 gt c'est un lvl 10 gt plié :o
http://hfr-rehost.net/preview/self/pic/39222f90372786479e6ba0682473414727df40fe.jpeg
[Mon Topic ACH/VDS/ECH]
Marsh Posté le 09-06-2011 à 21:51:31
aie :/
300e a la poubelle :D
Marsh Posté le 12-07-2011 à 22:26:18
Cizia a écrit :
aie :/
 :??:  tu lui a fait quoi?
quel horreur
  [:what has been seen]
Marsh Posté le 12-07-2011 à 22:45:01
quel horreur
c'est pas le miens hein   :D
une tof trouvé par darck
Marsh Posté le 13-07-2011 à 10:32:55
ouf! pour toi
ça fait mal au cœur de voir ça
Marsh Posté le 17-09-2011 à 18:38:02
Salut à tous j'ai un problème très urgent je suis en train de monter mon PC à base d'asus P8Z68 et je ne sais pas où brancher le petit ventilo à l'arrière du boitier je dois le brancher où sur la carte mère ? de même je ne sais pas du tout où sont les fils des ventilos du dessus, de la porte, et celui pres du lecteur disque est ce que ça correspond à la grosse prise a 4 broches ? mais ou la brancher ?
Merci de votre réponse je suis bien coincé la :s
Marsh Posté le 26-09-2011 à 11:06:34
Je possède cette tour également depuis peu, et je voulais savoir si on pouvait uniquement enlevé 2 filtre anti-poussière ? Celui du gros ventilo latérale, et en dessous du boitier. Existe-il d'autre filtre que je n'aurais pas vu ? :p
Avez vous un petit peu de poussière tout de même à l'intérieur. Perso, j'en ai un petit peu au bout d'un mois.
PS: Ah oui, est ce que les Bais des disque dur, peut-on les enlevé à chaud, ou PC éteind ?
      Et si je rajoute un Disque dur, le reconnaitra t-il directement ou je dois faire un petit détour par le Bios ?
Message édité par Iamk le 26-09-2011 à 11:08:25
Marsh Posté le 28-09-2011 à 11:00:18
petit up !
Marsh Posté le 02-10-2011 à 21:48:15
pti up
Marsh Posté le 21-06-2012 à 19:41:22
Une question me tarabuste ... La poignet sort du cadre de la tour ? On dirait à l'arrière sur les photos ...
Marsh Posté le 23-06-2012 à 17:44:13
Je viens de commander la version Snow Edition chez LDLC, je vous donnerai mon avis très bientôt !
Marsh Posté le 24-06-2012 à 19:28:48
Hâte de voir ça !
Marsh Posté le 24-06-2012 à 19:33:42
Surtout que je vais la bidouiller pour y mettre du watercooling ...
Marsh Posté le 29-06-2012 à 20:38:47
Voici un album de ma version Snow Edition ...
https://plus.google.com/photos/1150 [...] 4817098177
Si vous souhaitez avoir en photo une partie plus précise... demandez !
Message édité par tueurdepatates le 29-06-2012 à 20:39:17
Marsh Posté le 14-08-2012 à 13:01:33
Je me pose quelques question sur ce boîtier, peut être pourrez vous y répondre.
J'ai lu et vu plusieurs reviews mais en vain :
La baie 3"1/2 en dessous des 5"1/4 sert à quoi ?
Est ce une emplacement Hotswap pour HDD ? Suffit il juste de glisser le HDD dedans ?
Jai trouvé tout seul
C'est ça d'avoir des yeux de taupe  :D
Au sujet des ventilateurs :
Ils sont branchés sur une prise Molex : est il possible de les en désolidariser pour récupérer les prises 3pin et ainsi utiliser le rheobus de notre choix ?
Est il possible de remplacer les ventilos de 200 (front et top) par des 120/140 ?
Certains testeurs ont retenu le manque de place pour le câble management, est ce si terrible que ça ?
Message édité par Scr@t le 15-08-2012 à 07:50:09
« La théorie, c'est quand on sait tout et que rien ne fonctionne. La pratique, c'est quand tout fonctionne et que personne ne sait pourquoi. » - Albert Einstein
Marsh Posté le 15-08-2012 à 11:16:20
J'ai trouvé quelques unes des réponses que je recherchait.
- l'emplacement 3"1/2 n'est finalement rien d'autre qu'une baie pour floppy (ou plutôt lecteur de cartes)
- le ventilateur de 200mm de dessus peut être remplacé par 2 de 120mm
- le 200mm latéral peut être remplacé par un 140mm
- pour le 200mm frontal, je n'ai pas trouvé
- je n'ai pas non plus trouvé si je pourrai utiliser mon propre rheobus (avec les ventilos d'origine).
- niveau cable management, ça semble plus que correct
Autre question, jaimerai connaître les dimensions du rectangle entre les 4 pieds du boîtier. C'est pour voir s'il tiendrai sur le support que j'ai prévu.
Marsh Posté le 16-08-2012 à 05:28:35
C'est encore moi, mais aucune questions cette fois ci.
Les questions qu'il me restent je pourrai bientôt y répondre par moi même  :)
Boital commandé (avec 2-3 autres trucs)  :whistle:
Comment dire, le Level 10 GT est quelque peu a l'opposé de ce que je cherchait (truc sobre, matière noble, 6x5"1/4) mais vu que les TJ07 et autres boîtiers du même acabit se font vieux, j'ai jeté mon dévolu sur ce L10GT (principalement pour les emplacements Hotswap).
J'espère que je me sentirai plus à mon aise qu'avec mon CM690IIA.
De toutes façon, il est possible que je ne le garde pas très longtemps...
Allé, je n'ai plus qu'à attendre le facteur ;)
Marsh Posté le 15-01-2013 à 21:43:18
Bonjour, je déterre ce post pour les intéressés qui cherchent ce boitier à moindre cout:
en ce moment sur ldlc, avec le code SPLASH, vous obtenez 100€ de réduction, ce qui vous fait le boitier à 99€ + frais de port.
voilou. :love:
Marsh Posté le 24-06-2013 à 23:06:20
Bonsoir,
Ce code marchait peut être en janvier 2013 mais maintenant il est obsolète.
Je me tâte à commander le Level 10 GT sur LDLC à 199 € en vue de remplacer mon Cooler Master 690 II Advanced pour gagner en place de composants dans la tour et pour pouvoir évoluer mon refroidissement Cooler Master H-80 en modèle H100i ou H110i, ce qui est actuellement impossible dans le CM 690.
Pourriez-vous me dire si le changement de boitier est interessant ?
Ma config :
Asus P7X79 PRO
Cooler Master 850Watts Modulaire Silent Pro
Core i7 3930k
32 Go RAM,
2x Asus Geforce 670 GTX DCU II TOP
4 HDD SATA
Marsh Posté le 24-06-2013 à 23:53:15
Normal, les codes de réductions sur LDLC durent rarement plus de 48H
C'est d'ailleurs le cas sur la grande majorité des sites web (surtout quand le code vaut -50%).
J'ai fait le même switch CM690IIA => Level10GT
C'est clair que le Level10Gt est plus spacieux et permettra a ton hardware de mieux respirer. Il te permettra également de moins galérer au montage et d'avoir un cable management plus propre avec moins d'efforts.
Mais si je suis sur que le H100 rentre, je ne crois pas que ce soit le cas du H110.
Mais pour le H110 le problème ne sera pas la place mais le fait que le boitier n'est par percé pour un rad de 280. Mais un petit coup de Dremel et ça devrait passer (a confirmer tout de même, je regarderai demain).
Donc oui, le changement de boitier est intéressant à tout point de vue.
Maintenant, a part si tu es absolument fan du design du Level10GT, je pense qu'il y a mieux à ce prix là actuellement.
Marsh Posté le 25-06-2013 à 18:38:19
Salut scr@t
Merci pour ta réponse !
Donc si je comprend bien, tu me conseille vivement de passer du CM690A vers le level 10 GT sans hésitation mais de faire attention au watercooling.
Que possède tu dans ton boitier pour refroidir ton CPU afin d'avoir une idée ? En faite, j'envisageais le H110i car il est plus moderne que le H100 mais je pense que l'un comme l'autre serait de toute façon plus efficace que mon H80.
Oui, je trouve que le design est original et ne ressemble pas à la plupart des boitiers. Je ne vois pas d'autres boitiers qui me tenterai même si au début, j'hésitais entre le CM690A et le HAF-X.
Message édité par michael34750 le 25-06-2013 à 18:44:21
Marsh Posté le 26-06-2013 à 09:40:58
Ah non, je ne te conseille rien, je te donnes juste des éléments pour que tu choisisses.
Si j'avais encore mon CM690IIA aujourd'hui, je n'envisagerai pas le Level10GT car d'autres boîtiers me plaisent plus (mais bon, les goûts et les couleurs) et correspondent mieux a mes besoins (lesquels ont évolué depuis).
Pour ce qui est du WC, un RAD 240 passe en top (Corsair H100 par ex).
Le boitier n'est pas prêt pour un RAD280 (H110)
Dans le Level10GT, j'ai un Corsair H80i pour refroidir un Core i5 2500k.
C'est suffisant pour le maintenir sous 40°C
Marsh Posté le 26-06-2013 à 10:43:19
Salut !
Merci  pour tes explications
"Si j'avais encore mon CM690IIA aujourd'hui, je n'envisagerai pas le Level10GT" ==> Si tu veux on fais un échange de boitier lol
J'espère vraiment concernant mon H-80 (et non H-80i) que c'était simplement un problème de la pompe car je n'ai jamais été stabilité à 40° avec ce WC ! C'est l'une des raisons qui me poussent à l’évoluer pour éviter que le problème ne recommence.
Je te souhaite une agréable journée
Marsh Posté le 31-07-2013 à 23:15:32
Allez un petit retour après plusieurs mois d'utilisation:
Positif:
Refroidissement nickel, il faut,dire,que j'ai rajouté / changé par des noctuas (mis à part les 2 contenant des leds ou j'ai mis les réducteurs vendus avec les noctuas
Idem pour le proc, le nh-d14 passe nickel...
Point négatif, 1 seul, une vibration au niveau du ventilo "stock" supérieur, qui demande une petite claque de temps en temps.
Forum: http://grimrock.guildjdr.com/forum
