[Topic Unique] Coolermaster HAF X
Coolermaster HAF X [Topic Unique] - Boitier - Hardware
Marsh Posté le 26-05-2010 à 14:35:50
Bonjour et bienvenue sur le topic unique du Coolermaster HAF X
Caractéristiques
                                   http://www.coolermaster.com/upload/product_feature/HAF_X-prouct_highlight_r1.jpg
                                   http://www.coolermaster.com/upload/product_feature/HAF_X-prouct_highlight_r2.jpg
Color   Black
Material  Steel + Plastic
Dimension (W / H / D)  230 x 550 x 590 mm / 9.1 x 21.7 x 23.2 inch
Weight  Net Weight:14.35 kg / 31.6 lbs ; Gross Weight:16.08 kg / 35.5 lbs
M/B Type  M-ATX / ATX / E-ATX / GIGABYTE XL-ATI
5.25" Drive Bay 6 (2 converted SATA HDD drive bay available)
3.5" Drive Bay 5 Hidden
I/O Panel USB 3.0 x 2,USB 2.0 x 2, IEEE 1394a x 1, e-SATA x 1, Audio x 1, Mic x 1,
Expansion Slots 9
Cooling System Front:230 x 30 mm red LED fan on/off x 1
Top:200 x 30mm fans x 2 (one optional)
Side:200 x 30mm fan x 1
Rear:140 x 25mm fan x 1
VGA Fan Duct:120 x 25 mm or 120 x 38 mm fan x 1(optional)
VGA Holder:80 x 15 mm fan x 1(optional)
Power Supply  Bottom / Standard ATX PS2(optional)
le HAF X dispose d'un VGA fan duct ce qui est très utile pour refroidir une GTX 480. En effet, il a été prouvé qu'en mettant un ventilo directement prêt d'une Fermi, le ventilo devient beaucoup plus silencieux très loin des 3800trs !
Citation de Coolermaster
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, graphics cards and is even compatible with USB 3.0 devices.  With specialized support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this as close as it gets to a system builder's 'dream case'.
Déballage :
http://www.youtube.com/watch?v=tIs_OW4DYLg
Test en vidéo
http://www.dailymotion.com/video/x [...] haf-x_tech
Fiche produit en pdf :
http://www.coolermaster.com/upload [...] 0sheet.pdf
manuel
http://www.coolermaster.com/upload [...] l-0517.pdf
Message édité par Fssabbagh le 26-05-2010 à 15:20:57
Messatsu !
Marsh Posté le 26-05-2010 à 15:10:10
autres tests :
http://www.ninjalane.com/reviews/cases/cm-hafx
http://www.legitreviews.com/article/1311/1/
http://lanoc.org/review/hardware/c [...] ster-haf-x
disponible début Juin normalement
Message édité par Fssabbagh le 26-05-2010 à 15:25:12
Messatsu !
Marsh Posté le 26-05-2010 à 15:32:14
Il fait bien classe ce HAF X,d'une finition que  je trouve impeccable.Par contre la couleur noir plus de poussière visible.
donc il sort en juin et  coutera 200$ donc 162 euro? correct le tarif par rapport au HAF 932.
Marsh Posté le 26-05-2010 à 15:50:23
drap
topic ventes: https://lc.cx/xnz7 - topic recherches: https://forum.hardware.fr/forum2.ph [...] w=0&nojs=0
Marsh Posté le 26-05-2010 à 16:03:47
drap
Marsh Posté le 26-05-2010 à 16:40:22
Messatsu !
Marsh Posté le 26-05-2010 à 21:53:58
Apparement la version francaise sera différente et sera sans le latéral..
http://www.cowcotland.com/news/203 [...] haf-x.html
Marsh Posté le 27-05-2010 à 08:40:35
le 200mm sur la porte vient sur le toit...
on pourra quand même en rajouter un sur la porte de toute façon
ils veulent qu'il ressemble plus au 840 :D
Marsh Posté le 27-05-2010 à 11:17:36
Pour les filtres à poussière c 'est pas trés clair. Selon le manuel y en a un sur le ventilo avant. Mais c'est tout?!
Marsh Posté le 27-05-2010 à 12:00:27
oulà non
y en a vraiment partout !!
regarde le test vidéo :wahoo:
d'ailleurs c'est un clin d'œil  et son 230mm latéral sans filtre : foutre une ventilation pareille avec ce genre d'imperfection peut coûter cher. D'ailleurs thermaltake a été vraiment très con sur ce coup puisqu'ils ont bien mis un filtre sur le 230mm latéral du Element G
Message édité par Fssabbagh le 27-05-2010 à 12:02:40
Messatsu !
Marsh Posté le 27-05-2010 à 12:46:11
Oups j'avais pas regardé ;)
Et un nouveau test ici :
http://www.hardwaresecrets.com/art [...] eview/1003
Il manque un filtre au niveau de la prise d'air de l'alimentation...
Marsh Posté le 27-05-2010 à 14:52:14
il a l'air d'être un poil moins pratique que le 932 pour le watercooling... dommage d'avoir enlevé l'emplacement pour le fillport au sommet (tant mieux ça evitera de me donner envie de changer le mien lol)
Marsh Posté le 27-05-2010 à 20:34:29
bien méchant ce haf x ...
le déjà très bon 932 améliorer de partout.les tests son unanime,il est excellent.
tentant  :d
Un Ami ? C'est quelqu'un à qui on peut téléphoner à trois heures du matin en disant qu'on vient de commettre un crime et qui vous répond seulement : " Où est le corps ?! " ~/~ Alain Delon
Marsh Posté le 27-05-2010 à 22:00:41
Oui du très grand HAF en perspective!
Marsh Posté le 27-05-2010 à 22:01:08
Double post à supprimer
Message édité par Tar Aldarion le 16-06-2010 à 19:42:10
Marsh Posté le 27-05-2010 à 22:40:21
la portière du X me plairai pour mon 932 par contre...
Marsh Posté le 28-05-2010 à 11:18:36
tentant  :d
:D
je sens que y'en a encore un qui va encore changer de boitier avant la fin de cet été :D
( moi aussi je sens )
Marsh Posté le 29-05-2010 à 09:40:10
certainement  le plus " puissant " ( abouti ) des boitiers CM , on peut juste regretter son poids ( 14 kg à vide :ouch: ) , l'absence d'un potentiometre pour les ventilo , et son look bien que en progres par rapport au HAF 932 ( nettement plus homogene )  me semble moins sexy que le storm sniper mais la ce n'est qu'une question de gout .
Marsh Posté le 29-05-2010 à 09:49:07
les ventilos sont à 700trs donc c'est ni inaudible ni bruyant : on entends bien un léger grondement dans la vidéo mais rien de bien méchant
Marsh Posté le 29-05-2010 à 16:25:27
en tout cas pour les intéresser le boitier et déjà en precommande cher materiel.net http://www.materiel.net/ctl/Boitiers/57812-HAF_X.html a 179 euros
Marsh Posté le 29-05-2010 à 18:19:04
ARgl... ne pas craquer !  [:canardeur]
>>>>Mon feed<<<< - Le Jour J -
Marsh Posté le 30-05-2010 à 10:47:22
SI vas y craques et sois le premier feedback XD
Marsh Posté le 30-05-2010 à 11:06:06
il est vraiment pensé a tout,c'est un fait   :jap:
mais je regrette un peu le design de la façade
moins agressive que celle du 932 et bien alambiqué [:ronfl4]
Message édité par Cizia le 30-05-2010 à 11:07:54
Marsh Posté le 30-05-2010 à 17:36:39
Moi je regrette surtout l'absence de filtre au niveau de la prise d'air de l'alim.  :(
Marsh Posté le 30-05-2010 à 20:37:10
en même temps comme une bonne alim n'a pas un ventilo soufflant fortement t'en a pas vraiment besoin
Marsh Posté le 30-05-2010 à 20:49:52
il suffira de bloquer un filtre style alumino en dessous  :)
http://www.rsssim.com/images/140_112/157092-012_140x112.jpg
Marsh Posté le 01-06-2010 à 08:16:18
test de Hardware Canucks en vidéo :hello:
http://www.youtube.com/watch?v=jLFbjR97moM
Messatsu !
Marsh Posté le 07-06-2010 à 09:42:12
:sol:    :love:
Message édité par davids le 07-06-2010 à 09:42:36
Marsh Posté le 07-06-2010 à 16:00:04
achètes en un et on fais le champagne sur le forum
 :D
Marsh Posté le 07-06-2010 à 19:53:19
Il sort quand exactement ?
Marsh Posté le 08-06-2010 à 14:37:29
mi juin  :)
Marsh Posté le 08-06-2010 à 14:46:46
ça approche :)
Marsh Posté le 08-06-2010 à 19:02:53
déjà préco depuis le 26/05 pour ma part :D
FeedBack => http://forum.hardware.fr/hfr/Achat [...] 9404_1.htm
Marsh Posté le 09-06-2010 à 07:59:32
on va changer de serveur dans notre société
là on est sur un dell poweredge 1900
la sortie du HAF X me donne des idées du coup [:yes papa !!!]
Messatsu !
Marsh Posté le 09-06-2010 à 13:31:00
fait nous un petit feedback quand tu l'auras recu et que ta config sera monté dedans, ca serait sympa :)
et puis quelques photos aussi, ca serait cool :D
je me tate a l'acheter ..
Marsh Posté le 09-06-2010 à 15:39:50
un test HAF X vs ATCS 840 serait pas mal d'ailleurs
payer 200€ pour un boîtier alu avec support carte mère amovible , soit ce qui distingue en gros le 840 du HAF X
Messatsu !
Marsh Posté le 10-06-2010 à 20:52:59
Bah le look et l'objectif du boitier sont quand même différents
D'un coté tu met un HAF, look gamer moderne, qui privilégie la ventilation au silence.
De l'autre, un ATCS, sobriété absolue, silence privilégié (même si un très bon compromis de ventilation).
Marsh Posté le 10-06-2010 à 20:56:33
+1
I9 10850k+Freezer II 420mm/Z490 TuF gaming +/2x16Go 3600mhz cl16/RTX 3080TI gaming x trio/RM850 80+Gold/1To M2 Crucial P5/Meshify 2XL/4 ventilos boitier F14 PWM/Acer XB273KGP 4k 144hz 1ms/W10
Marsh Posté le 11-06-2010 à 09:12:53
ok sauf pour le silence vu que les ventilios sont les mêmes  ;)
non ?
Messatsu !
