Dodge => Bordel les fous... - Auto / Moto - Discussions
Marsh Posté le 21-01-2003 à 18:50:40
j'ai entrevu ça dans le dernier Turbo...600km/h potentiels. Mouais.
J'te la mets dans l'angle sans gros probleme, celle la...
Au fait, j'crois que c'est un dupe de *feu* Blabla....
Marsh Posté le 21-01-2003 à 18:51:16
deja posté sur blabla
Dodge Tomahawk
avec un moteur de viper
DIMENSIONS:
Length: 102 inches
Width: 27.7 inches
Height: 36.9 inches
Wheelbase: 76 inches
Seat Height: 29 inches
Weight: 1,500 lbs.
Track, Front: 8.75 in
Track, Rear: 10 in
Weight Dist: 49F/51R
Ground Clearance: 3 in
Fuel: 3.25 gallons
ELECTRICAL SYSTEM:
Alternator: 136-amp high-speed
Battery: Leak-resistant, maintenance-free 600 CCA
Lighting: Headlights consist of 12 five-watt LEDs, front, with beam-modifying optics and masked lenses. Eight LEDs, rear. Headlamps articulate with wheels.
TRANSMISSION:
Manual, foot-shifted two-speedAluminum-cased two-speed, sequential racing-style with dog ring, straight-cut gears
Gear Ratios: 1st 18:38; 2nd 23:25
Clutch: Double-disc, dry-plate with organic friction materials, hand lever actuated with assist
Final drive: Dual 110-link motorcycle-style chains
Front Sprockets: 14 teeth
Rear Sprockets: 35 teeth
ENGINE
Type and Description: 10-cylinder 90-degree V-type, liquid-cooled
Displacement: 505 cubic inches (8277 cc)
Construction: 356-T6 aluminum alloy block with cast-iron liners, aluminum alloy cylinder heads
Bore x Stroke: 4.03 inches x 3.96 inches (102.4 x 100.6)
Valve System: Two pushrod-actuated overhead valves per cylinder
with roller-type hydraulic lifters
Fuel Injection: Sequential, multi-port electronic with individual runners
Compression Ratio: 9.6:1
Power (SAE net): 500 bhp (372 kW) @ 5600 rpm (60.4 bhp/liter)
Torque (SAE net): 525 lb.-ft. (712 Nom) @ 4200 rpm
Max Engine Speed: 6000 rpm
Fuel Requirement: Unleaded premium, 93 octane (R+M/2)
Oil System: Dry Sump
Oil Capacity: 8 qts. Mobil1 10W30 Synthetic
Cooling System: Twin aluminum radiators mounted atop engine intake manifolds, force-fed from front-mounted, belt-driven turbine fan
Coolant Capacity: 11 qts.
Exhaust System: Equal-length tubular stainless steel headers with dual collectors and central rear outlets
BODY/CHASSIS:
Layout: Longitudinal, centrally mounted engine, rear-wheel drive
Chassis Construction: Monocoque, engine is central, stressed member
Body Construction: Billet aluminum
SUSPENSION:
Front: Outboard, single-sided parallel upper and lower control arms made from polished billet aluminum. Mounted via ball joint to aluminum steering uprights and hubs. Five degrees caster. Single, fully adjustable centrally located coil-over damper (2.25-inch coil with adjustable spring perch); pullrod and rocker-actuated mono linkage. Center-lock racing-style hubs
Rear: Hand-fabricated box-section steel inboard swing arms, incorporating "hydral-link" lockable recirculating hydraulic circuit parking stand. Single fully adjustable centrally located Koni coil-over damper (2.25-inch coil with adjustable spring perch); pushrod and rocker-actuated mono linkage. Center-lock racing-style hubs
STEERING:
Type: Dual hub center type.
Steering Linkage: Rocker arm and push/pull rod with roller bearings. Polished billet aluminum steering yoke with turned aluminum grips and billet levers
Steering Lock: 20 degrees, left and right
Lean Angle: 45 degrees, left and right
TIRES and WHEELS (4):
Type and Material: Billet aluminum discs, asymmetrical
Size, Front (2): 20x4
Size, Rear (2): 20x5
Tires Mfr. and Model: Dunlop custom-made symmetrical
Size, Front (2): P120/60R-20
Size, Rear (2): P150/50R-20
BRAKES:
Front: 20-inch perimeter-mounted drilled machined stainless steel rotors, one per wheel. Two four-piston fixed aluminum calipers per wheel (16 pistons total), custom designed. Blue anodized caliper finish. Hand-activated.
Rear: 20-inch perimeter-mounted drilled cast-iron rotors, one per wheel. One four-piston fixed aluminum caliper per wheel (8 pistons total), custom designed. Blue anodized caliper finish. Foot-activated.
PERFORMANCE:
0-60 mph: 2.5 seconds (est.)
Top Speed: 300+ mph (est.)
Marsh Posté le 21-01-2003 à 18:55:17
Aucune idée sais tu...
Après les Vipers, Neon et cie, Dodge se lance dans les motos hautes performances...
J'ai une idée, j'vais voir John Hennessey avec sa et je lui donne comme mission de m'y coller 2 turbos comme avec ses Vipers...
Marsh Posté le 21-01-2003 à 18:55:54
| Gordon Shumway a écrit : Excellent!!  |
A 400km/h, ca n'a plus aucune utilité je pense
Marsh Posté le 21-01-2003 à 21:29:36
La question se pose pas, pas besoin de casque aux US pour les motos.
Marsh Posté le 21-01-2003 à 21:34:50
C'est monstrueux, mais je n'arrive pas du tout à apprécier ce genre de chose:
* Je n'aime pas du tout le design
* Je n'arrive pas à considérer cela comme une moto (c'est presque aussi lourd qu'une voiture, et certainement plus lourd qu'une lotus élise  )
Je ne sais pas pourquoi, ça ne me plait pas du tout et pourtant j'aime les motos et les voitures, mais la je n'arrive pas à trouver quelque chose d'interessant la dedans  trop extrême.
 trop extrême.
Marsh Posté le 21-01-2003 à 21:48:20
Pour accelerer comme un Jacky dans des bout droit pourquoi pas, mais sur une vraie route avec des virages...
Le reservoir est ridiculement petit
C'est tellement lourd que ca ferait passer une moto BMW pour un velo
Y'a que deux vitesses
Pour les 450 km/h ils se touchent grave vu l'aerodynamique de la "chose" et le vent que doit te prendre dans la gueule
Les 2.5 sec pour le 0-100 ca a rien d'impressionant
Marsh Posté le 21-01-2003 à 21:59:12
Arreter d'être rabat joie !!!
C avec ce genre de reflexion qu'on se retrouve avec un parc de voiture qui se ressemble bcp.
Que ça plaise pas OK, moi l edesign j'aime pas.
Mais le concept c du délire total est ça je trouve ça cool.
On s'en fou que ça soit plus lourd qu'une élise....
C un objet de délire, un peu genre une oeuvre d'art koi.
Marsh Posté le 21-01-2003 à 22:06:44
| Dav-X a écrit : completement nimp tu tournes tu tombes   |
Non ya un système qui fait que chaque roue est amorti indépendemment et donc tu penche et tu tournes (enfin pas très serré hein)
Marsh Posté le 21-01-2003 à 22:09:15
| Nicobule a écrit : Arreter d'être rabat joie !!!  |
J'aime bien l'art, et même pas mal de trucs bizarres ... mais la, non j'aime pas  le problème c'est que je ne trouve même pas ça original !
Marsh Posté le 21-01-2003 à 22:11:05
| nicool a écrit :   |
Sortir de série 100 modèles de moto avec un V10 8L c'est assez original non?
Marsh Posté le 21-01-2003 à 22:14:21
| Nicobule a écrit :   |
C'est peut être inédit;
Mais je ne trouve pas d'idées ou de concepts originaux la dedans ... mais c'est vraiment mon avis, je ne l'ai pas vraiment rationalisé, d'un point de vue strictement émotionnel je n'arrive pas à adhérer a cette "chose"
Marsh Posté le 21-01-2003 à 22:14:26
| Oracle Yahoo a écrit :   |
Qui a parlé d'utilité, si tu veux un véhicule utile tu prend un Kangoo.
Marsh Posté le 21-01-2003 à 22:31:55
Ben c pour qu'elle existe dans plein de musées c bien.
Car un modèle unique pour le voir en vrai
Alors que là on pourra en voir en vrai.
Marsh Posté le 21-01-2003 à 23:02:03
| popo73 a écrit : y'en a un qui se rapelle du prix ?  |
250 000$US
 ![[:natas] [:natas]](https://forum-images.hardware.fr/images/perso/natas.gif)
c pas moi qui vas en acheter un a ce prix la... ![[:leg9] [:leg9]](https://forum-images.hardware.fr/images/perso/leg9.gif)
(Le ![[:natas] [:natas]](https://forum-images.hardware.fr/images/perso/natas.gif) vise le prix et non une personne...)
Marsh Posté le 18-03-2003 à 05:30:17
8.3l ![[:titprem] [:titprem]](https://forum-images.hardware.fr/images/perso/titprem.gif)
Ok Je sors...
Marsh Posté le 21-01-2003 à 18:48:35
http://www.allpar.com/cars/concepts/tomahawk.html
Terrible!!!!
"La douleur fait penser l'homme, la pensée rend l'homme sage, la sagesse rend la vie acceptable..."
