probleme dns avec sbs2003
probleme dns avec sbs2003 - Infrastructures serveurs - Systèmes & Réseaux Pro
Marsh Posté le 03-09-2009 à 15:00:08
Bonjour à tous
j'ai des problèmes critiques (impossible pour un pc distant de se connecter via vpn) sur sbs2003
Dans le journal j'ai les alertes suivantes
Merci pour votre aide
ID 5722
The session setup from the computer INTERPOL failed to authenticate. The name(s) of the account(s) referenced in the security database is INTERPOL$. The following error occurred:
Access is denied.
id 6702
DNS server has updated its own host (A) records. In order to ensure that its DS-integrated peer DNS servers are able to replicate with this server, an attempt was made to update them with the new records through dynamic update. An error was encountered during this update, the record data is the error code.
id4004
The DNS server was unable to complete directory service enumeration of zone 3MUSIQUE. This DNS server is configured to use information obtained from Active Directory for this zone and is unable to load the zone without it. Check that the Active Directory is functioning properly and repeat enumeration of the zone. The extended error debug information (which may be empty) is "". The event data contains the error.
id4015
The DNS server has encountered a critical error from the Active Directory. Check that the Active Directory is functioning properly. The extended error debug information (which may be empty) is "". The event data contains the error.
