Problème Switch Cisco - Windows & Software
Marsh Posté le 03-05-2006 à 14:48:50
connecte toi en port console et poste ici le résultat d'un sh ver et d'un sh run
Marsh Posté le 03-05-2006 à 15:03:58
Alors voila pour le sh ver :
CiscoRuedin1#sh ver
Cisco Internetwork Operating System Software
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(9)EA1, RELEASE SOFTWARE (
fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 24-Apr-02 06:57 by antonino
Image text-base: 0x80010000, data-base: 0x804E8000
ROM: Bootstrap program is CALHOUN boot loader
CiscoRuedin1 uptime is 39 weeks, 5 days, 21 hours, 58 minutes
System returned to ROM by power-on
System image file is "flash
c2950-i6q4l2-mz.121-9.EA1.bin"
cisco WS-C2950G-24-EI (RC32300) processor (revision D0) with 20815K bytes of mem
ory.
Processor board ID FOC0636W27A
Last reset from system-reset
Running Enhanced Image
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0A:F4:31:5C:80
Motherboard assembly number: 73-7280-05
Power supply part number: 34-0965-01
Motherboard serial number: FOC06360BEH
Power supply serial number: PHI0633009E
Model revision number: D0
Motherboard revision number: A0
Model number: WS-C2950G-24-EI
System serial number: FOC0636W27A
Configuration register is 0xF
Et pour le sh run :
CiscoRuedin1#sh run
Building configuration...
Current configuration : 3178 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname CiscoRuedin1
enable password 7 111B0C00131B05
ip subnet-zero
ip domain-name word
spanning-tree extend system-id
spanning-tree uplinkfast
spanning-tree vlan 1 priority 40960
Marsh Posté le 03-05-2006 à 15:14:46
ton switch n'a pas d'adresse ip et le serveur web n'est pas activé.
Marsh Posté le 03-05-2006 à 15:25:24
j'ai pas de switch sous la main, mais ça doit donner ça en console
configure terminal
ip address adresse_ip masque
ip http server
Marsh Posté le 03-05-2006 à 15:51:27
Voici les sous-commandes possible de la commande IP :
CiscoRuedin1(config)# ip ?
Global IP configuration subcommands:
access-list Named access-list
accounting-list Select hosts for which IP accounting information is
kept
accounting-threshold Sets the maximum number of accounting entries
accounting-transits Sets the maximum number of transit entries
alias Alias an IP address to a TCP port
default-gateway Specify default gateway (if not routing IP)
dhcp-server Specify address of DHCP server to use
domain-list Domain name to complete unqualified host names.
domain-lookup Enable IP Domain Name System hostname translation
domain-name Define the default domain name
finger finger server
ftp FTP configuration commands
gdp Router discovery mechanism
gratuitous-arps Generate gratuitous ARPs for PPP/SLIP peer addresses
host Add an entry to the ip hostname table
host-routing Enable host-based routing (proxy ARP and redirect)
hp-host Enable the HP proxy probe service
http HTTP server configuration
icmp ICMP options
igmp IGMP options
local Specify local options
name-server Specify address of name server to use
radius RADIUS configuration commands
rcmd Rcmd commands
reflexive-list Reflexive access list
security Specify system wide security information
source-route Process packets with source routing header options
subnet-zero Allow 'subnet zero' subnets
tacacs TACACS configuration commands
tcp Global TCP parameters
telnet Specify telnet options
tftp tftp configuration commands
Marsh Posté le 03-05-2006 à 15:53:52
conf t
interface vlan1
no shut
Marsh Posté le 04-05-2006 à 07:45:52
Hello, j'ai reussi avec la commande interface vlan1 mais cela ne fonctionne toujours pas j'ai refait un sh run pour uqe tu puisses voire le details :
CiscoRuedin1#sh run
Current configuration : 3188 bytes
version 12.1
no service pad
ip subnet-zero
ip domain-name word
interface FastEthernet0/1
description RUECHBA002
no ip address
duplex full
speed 100
spanning-tree portfast trunk
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
duplex full
speed 100
interface FastEthernet0/4
description RUEDIN06
no ip address
duplex full
speed 100
interface FastEthernet0/5
description RUE-GENEVE
no ip address
interface FastEthernet0/6
description HP4100TN
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
description RUE-ORLANDO
no ip address
interface FastEthernet0/9
description RUE-CHISINAU
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
description RUE-LAUSANNE
no ip address
interface FastEthernet0/12
description RUE-DUBLIN
no ip address
interface FastEthernet0/13
description RUECHBA001
no ip address
duplex full
speed 100
interface FastEthernet0/14
description RUE-DETROIT
no ip address
duplex full
speed 100
interface FastEthernet0/15
description ALINGHI
no ip address
interface FastEthernet0/16
description BARCELONE
no ip address
duplex full
speed 100
interface FastEthernet0/17
description RUECHBA000
no ip address
duplex full
speed 100
interface FastEthernet0/18
description SWITCH IT
no ip address
interface FastEthernet0/19
description HUB INTEL RH
no ip address
interface FastEthernet0/20
description RUEDIN03
no ip address
duplex full
speed 100
interface FastEthernet0/21
description RUE-FORM1
no ip address
interface FastEthernet0/22
description RUE-VATICAN
no ip address
duplex full
speed 100
interface FastEthernet0/23
description RUEDIN04
no ip address
duplex full
speed 100
interface FastEthernet0/24
description RUE-TIMEAS
no ip address
duplex full
speed 100
interface GigabitEthernet0/1
switchport mode trunk
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 149.133.6.101 255.255.254.0
no ip route-cache
shutdown
ip default-gateway 149.133.6.100
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
Marsh Posté le 04-05-2006 à 07:49:43
l'interface vlan est "shutdown", j'ai dit dans mon précédent post de faire "no shut" dessus ![]()
Marsh Posté le 04-05-2006 à 08:53:41
AH ok excuse moi j'ai oublié de faire ça. Now je l'ai fait mais je suis desolé de te dire que ça marche toujours pas.
Peut-être y a-t-il un problème avec le snmp ? je ne connais pas trop cette technologie mais j'ai regardé sur un autre switch de mon reseau et quand je fais un sh run j'ai d'autres lignes qui s'affichent :
interface VLAN1
ip address 149.133.6.105 255.255.254.0
no ip directed-broadcast
no ip route-cache
snmp-server engineID local 0000000902000008A35F3880
snmp-server community private RW
snmp-server community public RO
line con 0
exec-timeout 0 0
transport input none
stopbits 1
line vty 0 4
password ruedin
login
line vty 5 15
password ruedin
login
end
Marsh Posté le 04-05-2006 à 09:44:24
ça ne ping meme pas sur l'adresse que t'as rentré sur l'interface vlan 1 ?
Marsh Posté le 04-05-2006 à 09:47:15
Non cela ne me donne rien du tout ! enfin ça me donne : "delais d'attente dépassé" !
Marsh Posté le 04-05-2006 à 14:26:38
Juste encore une question si je change le nom du switch ça coupe momentanément la connection ?
Marsh Posté le 03-05-2006 à 13:55:40
[size=2]Bonhou,
[/size]
[size=2]Alors j'ai un problème avec mon Switch Cisco Catalyst 2950 séries. Sur ce Switch sont branchés tous mes serveurs (6 pour être précis).
[/size]
[size=2]Normalement si j'ai a administrer ce Switch je le fais via un browser. Mais depuis un certain temps je ne peux plus y accéder de cette manière et lorsque je le Ping il ne réponds pas !!!?!!!
[/size]
[size=2]Mais les serveurs continuent d'être accessibles. Lorsque je connecte en terminal via un câble RS-232 alors j'arrive à accéder au Switch !
[/size]
[size=2]Quel quun a déjà rencontré ce problème ? Comment faire pour résoudre ce problème sans redémarrer le Switch ?
[/size]
Merci d'avance
