[Topik UNIK] iRiver P10 / P.Ple; le nouveau PMP made in Korea
iRiver P10 / P.Ple; le nouveau PMP made in Korea [Topik UNIK] - Matériel - Video & Son
MarshPosté le 20-05-2008 à 13:45:08
Yop yop à tous,
Pour les aficionados d'iRiver, la marque Coréenne aux célèbres et nombreux PMP (qui a dit iPod killer ??!!!), vient de sortir en Corée donc un nouveau baladeur: le P10 ou P.Ple.
Size: 108.0(W) x 73.5(D) x 19.2(H)mm Weight: 205.0g USB: Device: USB 2.0 / Host: USB 2.0 GUI: Adobe Flash Lite 2.1 Interface: touch screen, power, menu, volume rocker, hold, reset PC Software: iriver plus 3
Marsh Posté le 20-05-2008 à 13:45:08
Yop yop à tous,
Basic Version
Weight: 205.0g
CPU: RMI AU1250 600MHz
OS: WinCE 5.0 Core
Capacity: HDD 33GB 3.302mm (1.3" )
Display: 101.6mm (4.0" ) TFT LCD WVGA (800x480) 1.6M color
Power: DC 5V 2A
Battery: Lithium Polymer 3,000 mA
Line Out: 3.5 Earphone Jack, AV-Out
Speaker: mono
Mic: internal
Audio Support: MP3 (8~320Kbps), WMA (5~320Kbps), OGG (48~500Kbps (Q1~Q10)), FLAC, APE, WAV
Equalizer: Flat, Rock, Pop, Classic, Jaz, Ubass, Live, Dance, USER EQ, SRS WOW HD
Playback Time: 7.5hr
Video Type: AVI, WMV, MPG
Format Support: MPEG1/2 (720x480 (8Mbps) Audio MP3, AC3), MPEG 4 SP/ASP (720x480 (1.5Mbps) Audio MP3, AC3, AAC), XviD (720x480 (2Mbps) Audio MP3, AC3, ACC), WMV7/8 (480x272 (1Mbps) Audio WMA), WMV9 (720x480 (1.5Mbps) Audio WMA)
Frame: 30fps
Subtitle: SMI
Playback Time: 3.5hr
Other Support: JPEG, BMP, TXT, DOC, XLS, PPT, PDF, HWP, CSD
PIMS: schedule organizer, anniversary, contacts, memo
Package Contents: P10, earphones, USB cable, USB host gender, AC adapter, stilus, portable stand, CD, manual
Pro Version Addition
E-Dictionary: Korean, English, Japanese, Chinese (YBM)
DMB Type: Korean ground based
Antenna: internal rod type
Kézako le DMB: http://fr.wikipedia.org/wiki/DMB
- Images du bestiau:
- Prix: environ 200 et 250€.
Pas encore de sortie de prévu hors Corée.
Patience donc...........sauf si vous souhaitez commandez là-bas, direction le store iRiver Korea
29/05/2008: MAJ des spécifications; merci à DAPreview.net
Message édité par Le Taz le 29-05-2008 à 14:13:55
Profil D3
