iAudio X5 - Matériel - Video & Son
Marsh Posté le 14-04-2005 à 18:37:46
Un topic unique se doit d'etre un minimum documenté, regulierement mis a jour et j'en passe...
edit: j'ai retiré le [Topic unique] pour le moment...
Marsh Posté le 14-04-2005 à 18:51:00
Certes... ben voila un bon paquet d'infos sur ce pti bijoux !!! apres, si y'a un bilinque qui est chaud pour tout traduires...
Features :
MP3, OGG, WMA, ASF, FLAC, WAV and MPEG4 (eastern image) remaking
The FM radio listening and sound recording and voice it records, Line-in sound recording
TXT if (text), JPEG (image) file pyu U (image magnification and background painting designation)
HDD the internal organs (20GB/30GB), USB Host, file copy/elimination
USB 2.0 interface
260000 color TFT-LCD and resolution 160x128 Pixel
Long remaking hour: The maximum 14 hours (iAUDIO X5L 35 hours) remaking
(Headquarters of a party test standard, the LCD use hour remaking hour could be diminished.)
Multi national language support
Direction syang the integration which becomes you is empty syen
Remaking/break, recording/sound recording break while
The next music/previously music, quickly the cold/Doe cold, segment infinite repetition
Resume, Fade-In and AutoPlay function support
Search speed and the Skip (it jumps over) speed set
Volume (digital 40 phase)
The EQ which is various and sound market effect (JetEffect)
- 5 bands EQ where the user control is possible
- The scull it will be distant, Rag, POP, jazz and classic, step khel, the User
- BBE, Mach3Bass and MP Enhance, 3D Surround
The clock, egg Ram and reservation it records, going to bed reservation and conservation of electricity end
Power, LCD On/Off and Hold combination switch
LCD automatic Off hour control, Brightness and Contrast control
The RAID of easy firmware knock-down road and Ub
ID3V2, ID3V1, Filename (file life) support
Machinery and tools information confirmation (firmware version, HDD dosage and the HDD amount used, the whole folder possibility, the whole file possibility)
MAC OS support (Only Data Transfer Supported)
Linux support v 2.2 or higher (Only Data Transfer Supported)
Software
- JetShell (file transfer and MP3/WAVE/AUDIO CD PLAY and MP3 ENCODING)
- JetAudio (integrated multimedia remaking software, music/eastern image conversion function)
The iAUDIO the X5 is the succeeding work which connects the rear of previously work M3. Accurately body size of the M3 it was born again with the convex elder brother product which is profound to load the color liquid crystal screen from like that. To except the fact that the feature is the Pak style product in ramyon high power, the color liquid crystal screen
Eastern image remaking in addition was a possibility of counting piece which is possible to the virtue which gets and.
Specifications :
File support MPEG1/2/2.5 Layer 3, WMA, OGG, ASF and FLAC
WAV (11/22/44Khz,16Bit, MONO/STEREO)
MPEG 4 Video
Hard disk Hard disk (20GB/30GB)
PC interface USB 2.0 (MAX 480M bps)
Recognition Gaes possibility 2,000 folders/file 10,000 thing
Battery Built-in Rechargeable Lithium Ion Battery
All the member AC adapter DC 5.0V, 2A
Continuous remaking hour The maximum 14 hours (headquarters of a party test standard, the LCD use hour remaking hour could be diminished.)
Charging hour AC all the member adapter use hour about 3 hours
Button Main body: 5-way Jog (NAVI/MANU, VOL+, VOL-, REW and FF)
PLAY, REC and POWER & HOLD Switch
li Wool cone: PLAY/PAUSE, FF, REW, MENU, VOL+, VOL-, MODE and REC
Indication 160 x 128 Pixel and 260,000 color TFT-LCD
SNR 95dB
Output They are 16 Ohm, the phone: 20mW + 20mW
Output frequency 20Hz ~ 20KHz
Size Main body: 103.7 mm x 60.8 mm x 14.3 mm (height x width x thickness)
li Wool cone: 33.2mm x 58.6mm x 14.4mm (height x width x thickness and clip thickness exclusion)
IAUDIO X5L:
Weight 145g (The internal organs lithium ion change of air inclusion)
The remaining evening sunlight is identical with existing iAUDIO X5.
Continuous remaking hour The maximum 35 hours(headquarters of a party test standard, the LCD use hour remaking hour could be diminished.)
Charging hour AC all the member adapter use hour about 6 hours
Size 103.7 mm x 60.8 mm x 18.3 mm (height x width x thickness)
Weight 180g (The internal organs lithium ion change of air inclusion)
Marsh Posté le 28-04-2005 à 23:35:24
Dites donc, il n'y a pas bcp d'amateur du iAudio X5 par ici...
Marsh Posté le 28-04-2005 à 23:46:37
On l'attend en Europe pour début mai !!! slurp
Pour info, il est livré ac tout ca.
Le pti cable, c'est pour l'usb otg qui vous permettra de decharger votre apn directement sur le HDD sans passer par votre ordi
chouette!
Autre petites infos:
Pour la vidéos, il ne lis pas les divix directement, il faut les convertir en MPEG4 grace au logiciel fourni avec (ouf )
il lis les vidéos a 15img/sec, ca se laisse qd meme regarder !!!
jugez par vous meme ce petit extrait de smallville...
http://www.dapreview.net/reviews/x [...] movies.MOV
ralala, mais qu'est ce qu'ils sont a la masse les ipod...
Marsh Posté le 28-04-2005 à 23:51:38
j'adore, je fais mon topic unique tout seul !!!
au fait, je tenais a présiser que les X5 20,30 et 60 Go font exactement la meme taille d'apres une sites US puisque les disques dure ont le meme diametre, seule la version X5L chopera 4mm en plus :s
Marsh Posté le 29-04-2005 à 01:52:17
Une chose: est ce que le lecteur fait 14.3mm d'epaisseur sur TOUTE sa longueur, ou est ce qu'il faut interpreter ce "14.3mm" comme un minimum? Parce qu'au vu de la forme, ça me semble bizarre. Si les 14.3mm correspondent a une epaisseur minimale, alors il doit etre bien plus epais si on compte la protuberance qui court sur la majorité de l'unité.
Marsh Posté le 29-04-2005 à 01:54:30
juju87 a écrit : |
Mouais...Sur ce coup, je pense que le concurrent direct est le Gmini de Archos (qui selon moi reste un ton au dessus pour ce qui concerne la video), meme si les iPod sont des epouvantails sur le marché.
Marsh Posté le 29-04-2005 à 09:28:02
non, 14.3 mm au minimum donc 18.3 au niveau de l'ecran et donc au total.
Cowon iAudio X5: meilleur qualité son, dictaphone qualité nickelle, USB HOST (pour decharger ton apn), autonomie 14h (archos 10h a tt casser)ou 35h en version X5L, 350euro pour le X5 20 Go (car il existe en 30 et bientot 60 Go)et ton archos 400, compatible .ogg, antichoc 12min, fourni ac sa housse de transport... etc etc etc voila de quoi de convaincre pour l'achat de ton futur lecteur HDD
ha, j'oubliai, il a la radio bien entendu
Marsh Posté le 29-04-2005 à 10:08:04
oué mais un film à 15fps c'est pas un film
Sinon il a l'air pas mal , mais je garde mon Gmini 400
Marsh Posté le 29-04-2005 à 14:42:04
juju87 a écrit : etc etc etc voila de quoi de convaincre pour l'achat de ton futur lecteur HDD |
Nah ne t'en deplaise je n'ai pas attendu ta review pour me pencher sur les produits Cowon, puisque je possede un Cowon iAudio M3 depuis un bon moment maintenant. Et je maintiens que coté video, l'Archos gmini400, pourtant "a la traine" par rapport aux dernieres nouveautés de la marque FR, reste bien superieur aux possibilités du X5. Qui n'est pas vraiment un baladeur video a proprement parler, de tte façon.
Marsh Posté le 29-04-2005 à 15:27:02
667 a écrit : Et je maintiens que coté video, l'Archos gmini400, pourtant "a la traine" par rapport aux dernieres nouveautés de la marque FR, reste bien superieur aux possibilités du X5. |
C'est à dire? Par rapport au PMA400? à l'AV400?
Marsh Posté le 29-04-2005 à 16:25:35
X5 est pas terrible pour la lecture video
Resolution tres faible et tres peu de formats supportes
Marsh Posté le 30-04-2005 à 11:59:10
Il n'est peut-être pas terrible pour la video mais par contre quelle gueule!!
Moi il m'interesse carrément! Par contre je n'ai pas bien compris la différence entre la version basique et la version "L".
Enfin sera-t-il dispo en France? Quand? A quel prix?
Tant de questions sans réponses...
Marsh Posté le 30-04-2005 à 13:08:57
la version L a une batterie deux fois plus puissante, et il est un peu plus épais (M3 --> M3L)
Marsh Posté le 05-05-2005 à 00:02:54
Toujours pas de date de sortie en France pour ce magnifique lecteur MP3?
Marsh Posté le 13-05-2005 à 00:13:52
Un test du x5 http://www.akihabaranews.com/revue_47.html
Putain, je le veux
C'est quoi la différence entre le m5 et le x5 ??
Marsh Posté le 13-05-2005 à 01:05:44
tot2012 a écrit : Toujours pas de date de sortie en France pour ce magnifique lecteur MP3? |
Voila le probleme de Cowon sur notre territoire (et ailleurs en Europe): tres bons produits (design, fonctions, etc...), mais AUCUNE disponibilité. Quand les marques auront compris que pour concurrencer les poids lourds, un bon produit ne suffit pas, encore faut-il que les gens sachent qu'il existe et qu'il soit trouvable ailleurs que via des commandes groupées sur des forums specialisés, alors ils auront fait un grand pas.
Car meme en 2005, un produit dont on ne connait pas l'existence et qui n'est pas physiquement trouvable est un produit voué a un certain echec.
Marsh Posté le 31-05-2005 à 21:18:06
Salut, au risque de me répéter, les amateurs de X5 peuvent participer à la commande groupée du forum de generationmp3. Je vous invite à y faire un tour http://www.generationmp3.com/forum [...] opic=20210
Voila les gens, venez nombreux pour avoir une bonne remise.
Marsh Posté le 14-04-2005 à 18:19:34
Bonjour tout le monde ! Petit Topic sur le X5
et non pas le M5 ?
Sa sortie officielle est annoncée pour demain je crois mais ou (quel pays) ??? Comment se le procurer ? Ou ? Sur quels sites ? et avec quels accesoires founis dans le pack? (perso je suis de grenoble mais j'ai des connaissance au canada, au pays bas et en belgique. Quel est le moyen le plus pratique ?) Merci
Message édité par juju87 le 14-04-2005 à 22:37:04
