Terratec Noxon Audio 2 en test (serveur audio wifi,...) + Enceintes! - Matériel - Video & Son
Marsh Posté le 22-01-2007 à 11:47:36
Merci pour ce test !
Comme prévu, j'attends avec impatience le test avec un petit NAS, pour savoir si ce genre de matos peut aller "chercher" des fichiers partagés par un dsique dur externe wifi.
D'ailleurs, as-tu accès aux fichiers partagés ou seulement aux fichiers "servis" ?
Mercii.
giboo
Marsh Posté le 22-01-2007 à 12:26:39
j'ai pour l'instant utilisé les fichiers "servis" par le serveur twonkmusic.
je vais regarder si je peux utiliser autre chose ...
Marsh Posté le 22-01-2007 à 19:40:15
je viens de regarder sur un autre forum et je suis tombé sur ça:
http://www.nas-forum.com/forum/index.php?showtopic=124
et sur ça:
http://www.whatpc.co.uk/personal-c [...] 5979/noxon
"With the supplied Twonkyvision software installed on your PC, the Noxon 2 will be able to access any mp3 and wma files stored on your hard drive - this includes those wma files with DRM (digital rights management).
The Noxon 2 is a UPnP (Universal Plug and Play) device and will therefore also talk to any UPnP NAS (network attached storage) drives on your network.
The advantage of using a NAS is you don't have to have your PC constantly switched on to provide the Noxon 2 with content.
We tried out the Noxon 2 with Iomega's Storcenter and although it worked, we did find it a fair bit slower than when using it with the Twonkyvision software running on a PC.
There was no problem in terms of playing audio, but browsing through the music library often involved some frustrating 10 second pauses."
et ici :
http://www.synology.com/enu/forum/ [...] ight=noxon
Terratec Noxon 1 (DS106e/SoLan)
Terratec Noxon 1 (DS106j/Marlborough)
Terratec Noxon 2 (DS101/CS406e/Narsil)
Terratec Noxon iRadio (DS106/417/toddel68)
la FaQ ici indique
http://www.synology.com/enu/suppor [...] p?q_id=298
he DMA that have been tested on the Synology Product are listed as follows:
Brand Model Remark
TERRATEC NOXON 1 audio
TERRATEC NOXON 2 audio Play music only
Marsh Posté le 23-01-2007 à 10:30:32
Merci pour cette belle enquête !
Je me tate a utiliser un pocketpc en player (écran tactile, pas de soucis de configuration des partages réseau, etc.)... L'avantage du noxon est sans aucun doute le pour spdif...
Marsh Posté le 23-01-2007 à 15:36:14
vi, je cherche maintenant un petit ampli avec entrée spdif pour etre bien clean. j'ai pour l'instant de petite enceintes amplifiées et le son est quand meme bien clean.
par contre, j'ai updaté le noxon avec le dernier firmwaire directement : 3.5 et j'ai installé la derniere version de twonk
Marsh Posté le 25-01-2007 à 10:05:03
trouver un petit ampli, avec une entrée spdif...
je crois qu'il n'y a que les gros ampli audio/video type homeciné ![]()
Marsh Posté le 25-01-2007 à 10:16:50
ouais je suis en train de regarder ça .. je me dit par contre, que pour les radio qui stream à moins de 128 et l'usb, la qualité sonore ne mérite pas une entrée numérique ... par contre, faut vraiment personnaliser les radio, car il y a trop de radio, pour les genre "pop/rock", faut browser sur plus de 1000 radios ..bref, difficile de faire un choix !
Marsh Posté le 26-01-2007 à 10:09:29
Mon NAS ne contient que des rip perso en OGG q7
donc la qualité est au rendez vous...
:-D
En même temps, ma sono est actuellement reliée par jack-RCA du fait d'une trop grande distance pour mon cordon numérique d'un mètre entre source et ampli.
Et comme c'est déjà très bien...
Marsh Posté le 26-01-2007 à 10:41:32
oui, pareil, j'encode tout en VBR 320k , q7 ( en mp3)
je suis en train de chercher un petit ampli pour remplacer les petites enceintes
j'ai eu une autre réponse concernant le NOXON + synology :
http://www.nas-forum.com/forum/index.php?showtopic=998
pas de souci visiblement ...
Marsh Posté le 21-02-2007 à 09:43:43
noxon vient de sortir une nouvelle bêbette : à michemin entre le noxon iradio et le noxon 2
http://www.pcinpact.com/actu/news/ [...] ns-fil.htm
le test ici :
http://www.planet-sansfil.com/?p=436&page=1
Marsh Posté le 24-02-2007 à 07:49:14
Cool des utilisateurs de ce produit!
Bon ça tombe bien car j'ai des questions à vous poser à propos de ce produit, car je ne trouve les réponse dans aucun test.
1. Pour la liste des radios je suppose que le Noxon Audio va le récupérer auprès d'un service en ligne. Mais est-il possible d'ajouter des adresses de radios directement dans la mémoire du Noxon sans passer par ce service en ligne?
Ca m'embête vraiment d'être dépendant "ad vitam eternam" d'un service en ligne pour diverses raisons:
- si ce service en ligne s'arrête
- s'il devient payant
- une question de vie privée aussi
- si jamais certaines radios ne peuvent pas être intégrées au service (shoutcast, radio privées, stream perso, etc...)
- etc...
1bis. Si oui à la question 1, peut-il accepter des adresse avec l'extension .pls et/ou .m3u proposant plusieurs streams?
exemple: http://www.bassdrive.com/v2/ qui ont dans leur playlist des serveurs relais de secours au cas où l'un d'entre-eux tombe en rade. C'est bien pratique car si le stream s'arrête ça passe direct au relais suivant dans la playlist
2. y-a-t-il une mémoire tampon, et si c'est le cas fonctionne-t-elle bien?
Histoire de savoir si le Noxon peut encaisser une micro-coupure de réseau ou de streaming sans broncher
3. Des problèmes avec le support UPnP? La navigation est fluide?
4. certe l'ogg et l'aac sont désormais supportés pour la lecture de fichier avec le nouveau firmware, mais les stream de radio en ogg ou bien en acc++ ça passe aussi?
Ah oui, au sujet de l'UPnP (dans la série j'arrête mes questions et je file quelques trucs en vrac...)
-Si jamais vous avez la suite Nero installée sur votre PC. Vérifiez si jamais vous n'avez pas le composant Nero MediaHome c'est tout simplement un serveur UPnP très simple à utiliser http://www.nero.com/nero7/eng/Nero_MediaHome.html et ça évite de se tapper Twonkyvision
- pour ceux qui ont une machine linux ou un petit serveur linux maison: http://ushare.geexbox.org/
- et pour ceux qui n'ont pas envie d'avoir un gros PC qui tourne 24/24h (bruit, facture EDF, etc...) pour mettre sa musique en partage sur son réseau et accessible via le Noxon, ya ce petit truc bien sympa http://en.wikipedia.org/wiki/NSLU2 sur lequel on peut brancher des disques durs directement via port usb. On peut en faire beaucoup de chose, notamment un serveur de stockage en réseau (NAS), un serveur UPnP et plus (voire le projet: http://www.nslu2-linux.org/ )
Certe le NSLU2 ne sera pas le super NAS professionel de la mort à débit Gigabit et accès disque 300Mo/s, mais c'est une solution très économique et parfaite pour mettre en partage une collection de musique ![]()
Marsh Posté le 27-02-2007 à 11:15:13
bonjour,
voila quelques réponses.
le noxon va chercher sa liste sur le site web : http://www.radio567.com/
on peut personnaliser le site en rentrant la MAC addresse du noxon et on arrive sur un profil personnalisable et l'on peut "tuner" sa page.
pour la question 1bis: je te réponds ce soir en faisant le test!
2- il ya une mémoire tampan, mais je n'ai vu aucun moyen de la configurer ( taille du buffer, etc..) : cependant, je n'ai pas vu de coupure pour l'instant qq soit la radio.
3- pour l'upnp j'ai installé le soft fourni :twonkvision. Lors du premier "browse" ça été un peu long car j'ai pas mal de titre sur les disques (30 Go), mais ce qui est top, c'est que twonk indexe tout : tri part auteur, genre, album, c'est sympa ... mais fastidieux quand tu as plus de 5000 albums sur les disques. Sinon très fluide et pas de souci notable.
4- pas testé car la navigation s'effectue via le titre ( ou le genre, ou le pays) et je ne vois pas le type de radio ( shoutcast, stream windows..) je ne vois juste que la qualité ( 96khz, 64,) et si la radio est stéréo ou pas.
voila
ce site est un service du site http://vtuner.com/
Marsh Posté le 01-03-2007 à 22:28:04
Je trouve enfin ici quelques infos sur le noxon2. J'en profite pour vous soumettre mon problème, car j'ai des soucis avec le Noxon :
Mon gros problème est qu'à l'allumage, le noxon ne retrouve plus ou n'affiche plus le serveur UPnp.
Je dois le rebooter, voir le débrancher pour que enfin, il le retrouve... et encore, il faut des fois le faire plusieurs fois de suite. Bref, je suis à la limite de faire jouer la garantie...
Notez que je peux accéder aux fichiers enregistrés par le biais des favoris, ce qui montre que la liaison est bien là...
J'ai essayé Tonky, Ezlink manager, mis à jour le firmware du Noxon, rien n'y fait ...
J'ai essayé deux config réseau : DHCP et IP fixe, idem
Je suis connecté via une Freebox v5 WIFI en mode routeur avec adresse attriibué via l'adresse MAC du Noxon, tout marche bien chez moi au niveau du WIF, les signaux sont excellents...
Si quelqu'un à une idées, des tests à faire avant que je renvois cet appareil...
Merci !
Marsh Posté le 02-03-2007 à 00:26:22
sebus38, si tu as un autre PC sur ton réseau, tu peux essayer Geexbox.
Tu graves le CD et tu bootes l'ordi dessus.
Geexbox intègre un client UPnP et du coup verra ton serveur sur le réseau et pourra le parcourir, si celui-ci fonctionne bien.
Ca ne te permettra pas de règler un éventuel problème au niveau du Noxon, mais ça te permettra au moins de savoir si le problème vient de ton serveur UPnP ou pas.
Marsh Posté le 02-03-2007 à 09:13:28
Oui je vais essayer ça, mais j'ai des doutes vu que j'ai testé deux serveurs différents ? Mais bon, on sait jamais... J'ai pas de deuxième PC, seulement un portable, mais j'imagine que Geekbox s'installe bien dessus. J'espère trouver une solution car sinon je trouve ce matériel vraiment bien
Marsh Posté le 02-03-2007 à 09:24:35
| monsieur a écrit : pas besoin d'installer geexbox, c'est un Live CD qui fonctionne juste en mémoire vive et disparait après extinction. |
Ah oui c'est vrai
Marsh Posté le 02-03-2007 à 20:43:07
| monsieur a écrit : sebus38, si tu as un autre PC sur ton réseau, tu peux essayer Geexbox. |
Re,
Voila, j'ai pu lancer GeexBox mais ... :
- Quid de la connexion WIFI de mon PC via GeexBox ? Parceque le Noxon se connecte en WIFI sur le serveur évidemment
- Quid de la definition du repertoire de MP3, je n'ai pas trouvé ce genre d'option sur GeexBox ?
Bref, dans tout les cas après démarrage, le Noxon n'a rien détecté du tout...
A suivre !
Sebus
Marsh Posté le 02-03-2007 à 21:38:18
Je crois que tu as mal compris ma phrase: geexbox ce n'est pas pour tester ton noxon, mais pour tester ton serveur UPnP.
Car geexbox est (entre-autre) un client UPnP tout comme le Noxon. Bref la geexbox n'enverra rien du tout à ton noxon...
J'ai d'ailleurs testé le serveur Tonkymusic via geexbox cet après-midi pour voir ce que ça donnait.
Marsh Posté le 02-03-2007 à 22:19:48
OK, dans ce cas, je n'ai pas de PC dispo pour tester tout ça ![]()
Marsh Posté le 03-03-2007 à 19:07:08
Je suis pas mal intéressé par la bête mais j'ai une petite question concernant les podcasts. J'ai pas mal cherché à droite à gauche sans trouver de réponse ... alors est ce qu'un heureux utilisateur du Noxon 2 pourrait nous dire d'où vient la liste des podcasts disponibles. Peut on en ajouter d'autres soi meme comme ça semble être le cas pour les radios ? Y a-t-il par exemple les podcasts de Radio France dans la liste ?
Merci ...
Laurent
Marsh Posté le 03-03-2007 à 19:37:22
| laurent456 a écrit : Peut on en ajouter d'autres soi meme comme ça semble être le cas pour les radios ? |
Même question, sachant qu'avec des services comme rss-one on peut avoir directement les podcasts sous forme de playlist winamp au format m3u http://www.rss-one.com/index.php?p [...] findtype=2 et qu'une conversion rss/xml vers m3u/pls peut se faire très facilement via un script php
En gros, des screenshots de l'interface de http://www.radio567.com et de ses fonctionalités seraient les bienvenus
Marsh Posté le 04-03-2007 à 12:57:40
Bon, je reviens après quelques tests : il apparait qu'en ramenant la Freebox à côté du Noxon, ce dernier semble bien marcher et retrouve bien le serveur. Je sais pas ce que je dois en déduire car le signal WIFI n'était pas bien loin auparvant ? Bref, à suivre...
Marsh Posté le 10-03-2007 à 14:48:39
coucou
comme promis quelques snap du site web des radio:
quand on a rentré son adresse MAC , un ecran apparait avec la liste des radios, triables par genre, langage et localisation géographique:
si on veux, on peux ajouter sa propre radio:
les formats possible sont
mp3
windows media
AAC
un exemple de sélection, genre electronique, en france avec les statuts, le bitrate des radios...
voila voila ...
Marsh Posté le 10-03-2007 à 19:32:09
merci gizmo31
j'ai pu trouver ça: http://entertainfr.terratec.net/mo [...] &artid=415
Bon, j'ai essayé l'interface de radio567.com (en vrai), je n'ai pas trouvé le moyen d'y changer les podcasts
Niveau connection, le Noxon semble se connecter à cette adresse http://bridgeco.vtuner.com/setupap [...] ginXML.asp (trouvé en fouillant dans le fichier du firmware) intéressant pour en analyser la structure xml et se refaire le même service par soi-même à terme
On y découvre en parcourant la structure que la liste des podcasts est imposée (ils la choisissent pour vous), en voici la liste pour les podcasts french:
http://bridgeco.vtuner.com/setupap [...] France-All
Note aux possesseurs de Noxon: ne communiquez l'adresse mac de votre appareil à personne, et ne diffusez pas de photo de l'arrière de votre appareil (où y figure l'adresse mac)
Marsh Posté le 13-03-2007 à 21:17:03
Je viens d'acquérir un iRadio et ma foi c'est vraiment pas mal.
J'ai un peu testé toutes les fonctionnalités autour de la radio et ça marche vraiment nickel.
Par contre impossible de voir mon serveur Twonky. Après un peu de recherches, ben je me suis rendu compte que c'est ma livebox qui fait routeur et qu'elle est pas compatible UPNP (c'est une Sagem, l'Inventel le fait). Donc faites bien attention à ça. J'ai entendu dire que le prochain firmware devrait le gérer, mais il arrive pas avant cet été. Je suis bon pour me choper un routeur wifi (ce qui n'est pas plus mal soit dit en passant), à moins que quelqu'un ait une solution...
Pour les podcast je n'ai pas trop regardé encore mais je n'ai pas encore réussi à y mettre les miens.
Ah si Terratec pouvait nous filer les sources du Firmware ... (histoire d'améliorer l'interface web par exemple qui est très pauvre)...
Marsh Posté le 14-03-2007 à 02:47:20
tiens tiens... au détour de recherches je suis tombé sur ça:
cliquer pour agrandir
un projet commencé en 2005: https://troubadix.multimedia.fh-aug [...] unkertrac/
qui tourne sous linux et se base sur une carte mère mini-itx epia.
Une petite review en anglais: http://www.mini-itx.com/projects/rundfunker/
Même si c'est un peu hors sujet (quoi que l'iRadio s'en inspire très très fortement je trouve), ça n'en reste pas moins une très belle réalisation.
Marsh Posté le 14-03-2007 à 13:01:13
Jai un Noxon 2 et un iRadio avec le dernier firmware.
Quelquun sait sils sont compatibles, nativement, avec les formats lossless? Apparemment, ni les wma lossless, ni les Flac passent nativement. Pour les wma il faut passer par le serveur Mediaconnect de Microsoft pour un décodage à la volée ce qui est très gourmand en terme de ressources de lordinateur et la qualitée du son ne me semble pas optimale. Merci de vos réponses.
Raponzolo
Marsh Posté le 15-03-2007 à 17:04:47
monsieur: superbe cette boiboitte !
raponzolo : je ne sais pas.. envoyez un mail au support terratec ??
Marsh Posté le 15-03-2007 à 17:43:26
| gizmo31 a écrit : monsieur: superbe cette boiboitte ! |
Ouaip, et ya même de la place pour y coller deux disques durs de portable 2.5". Le problème c'est ensuite de faire cohabiter une enceinte (un gros aimant donc) et des disques dont le procédé d'enregistrement est magnétique.
Mais bon quoi qu'il en soit je serai incapable de réaliser le niveau de finition qu'ils ont fait et l'électronique pour la gestion des boutons.
Marsh Posté le 17-03-2007 à 13:30:28
J'ai un Noxon2 et la dernière version du firmware. Depuis le début de l'utilisation (donc déjà avec l'ancien firmware), j'ai de gros problèmes de bruits de fond. Il y a en permanence un bruit de fond sourd qui varie par exemple lorsque l'on appuye sur une des touches du Noxon.
Est-ce que quelqu'un à rencontrer le même probème ? et/ou a une suggestions pour supprimer ce(s) bruit(s) ?
Petite précision, avec la même installation (routeur, ampli, diffuseurs...) et le noxon 1, je n'ai pas ce problème de bruit de fond.
Un grand merci d'avance pour votre aide!
Marsh Posté le 02-05-2007 à 09:55:34
Salut Monsieur,
As tu un autre lien que "Geekbox" pour tester un serveur upnp ? Car impossible de lire mes mp3, je n'attrape que la radio...
Merci !
Marsh Posté le 05-05-2007 à 11:57:27
Quelqu'un a-t-il testé la version 3.5.6291 Beta, qui est dispo sur le site de Terratec? Impossible de trouver les changements introduits par cette version. Ils en parlent un peu ici: http://www.ferienhaus-am-meer.de/Noxon2/ (en allemand), mais on y apprend pas grand chose...
Marsh Posté le 14-05-2007 à 12:39:15
ah ! je n'ai pas testé, mais je vais y jeter un oeil ..
pour l'instant, je n'ai rien à dire sur cette boite, aprèès plus de 5 mois non stop d'écoute .
e suis un peu paumé par la quantité de radios et un point un peu négatif est que les radios quie ne fonctionne pas ( "chanson non trouvé" ) ne sont jamais enlevés de la liste.
j'aurais aimé
* un tri par genre ( comme les tag id3) plus complet ( plus de 600 radios dans le genre "pop/rock" ) ,
* un mode "random" qui pourrait etre sympa plutot que de browser,
* la possibilité de ne voir des stations qui correspondent à certains critères ( par exemple, stream a 128k seulement, etc..)
sinon rien d'autre à dire ... à quand un petit appareil portable pour écouter tout ça sur la terrasse ? ![]()
Marsh Posté le 17-05-2007 à 14:53:22
le document officiel que j'ai est ici :
ftp://ftp.terratec.de/HomeEnterta [...] ts_New.pdf
mais rien de le beta code...
Marsh Posté le 18-05-2007 à 16:39:04
xzav1, j'ai eu des problèmes de bruits parasites. Chez moi, c'était plus des crachotements qu'un bruit sourd.
J'ai résolu ca en remplacant la connexion vers l'ampli: à la place d'une connexion analogique (blanc-rouge), j'ai mis un cable optique. Depuis, plus de problème.
J'ai un copain qui a aussi eu le meme pbl. Lui a fait joué sa garantie et à renvoyé son Noxon en Allemagne, mais ca coute, il y a des risques de pertes, ... Je n'ai pas pris ce risque là...
Marsh Posté le 21-01-2007 à 15:12:52
Update du 24/12/2007
nouveau firmware dispo!!!!
Description: Firmware Update, Manual and NOXON Firmware-Manager
Documentation: German / English
For Windows 2000 / Vista / XP
Version: 6392 | Filesize: 6.55 MB
dispo ici :
http://supporten.terratec.net/modu [...] ad&sid=501
Terratec vient de sortir un système d'enceintes pour le noxon2 qui se greffe dessous le noxon2!
lien ici :
http://entertainfr.terratec.net/mo [...] le&sid=253
le système
et là :
le prix pour le système d'enceinte est de 40 € environ ( mais j'ai pas trouvé d'autres infos)...
voila !
j'ai commandé ce petit joujou sur grosbill il ya quelques jours car je cherchais un équipement qui puisse lire de la musique en wifi, soit depuis internet, soit en utilisant ma bibliothèque musicale de mon pc ( à tester : depuis un NAS..).
d'après certains tests :
http://www.webuser.co.uk/products/ [...] 0-201.html
http://reviews.cnet.co.uk/digitalm [...] 821,00.htm
http://www.gadgetspeak.com/gadget/ [...] ticle.html
http://reddevil62-techhead.blogspo [...] audio.html
l'appareil semble tenir ses promesses.
le nouveau firmware (v3.5) inclut maintenant les fonctionnalités suivantes
( http://www.clubic.com/actualite-66 [...] dcast.html )
Terratec a effectivement publié aujourd'hui une mise à jour firmware pour ces deux produits. Estampillée 3.5, cette mise à niveau permet de lire les fichiers Ogg Vorbis, les fichiers AAC (non protégés) ou encore les Podcast disponibles sur Internet (filtrage directement depuis l'appareil par langue et par pays).
En plus de cela, une option permettant de modifier la luminosité de l'écran a été ajoutée. La taille du texte peut aussi être ajustée. Le firmware permet aussi de programmer le Noxon 2 ou l'iRadio pour qu'ils s'éteignent automatiquement à une heure précise. La durée d'inactivité maximale avant mise en veille peut également être programmée.
la bête:
Standards
* IEEE 802.11b
* IEEE 802.11g
* IEEE 802.3, IEEE-802.3u
* UPnP
* Microsoft Windows Media DRM10
* Prise en charge support de données portable USB 2.0
Débit de transmission de données
* 54 Mbit/s (WLAN)
* 10/100 Mbit/s (Ethernet)
Sécurité du réseau
* Cryptage WEP (code 64/128 Bits)
* Cryptage WPA
Connectivité
* Point d'accès WIFI
* Ad-hoc (poste à poste)
Formats de données
* Radio Internet (flux MP3, MMS)
* MP3 (jusqu'à 320 kBits/s, CBR/VBR)
* ID3 V1.0 / V2.0
* M3U
* PLS
* WMA-9 (jusqu'à 320 kBits/s) sans protection anti-copie et avec protection anti-copie Windows Media DRM10
Connectique
* Sortie Line (RCA)
* Sortie écouteurs (jack 3,5 mm)
* Sortie numérique S/P-DIF (TOS-Link)
* Ethernet RJ-45
* USB 2.0 (Type A)
* Bloc d'alimentation
Caractéristiques
* Télécommande infrarouge
* Port USB 2.0
* Prise en charge Windows Media DRM10
* Mises à jour du Firmware via le réseau
* Affichage LCD clair
* Sortie audio numérique
Bloc d'alimentation
* 9V / 1A
Configuration requise PC
* Point d'accès WIFI 802.11g (recommandé) ou Carte WIFI 802.11b ou 802.11g
* Cryptage WPA (recommandé)
* Windows 2000 ou XP
* Processeur Pentium III 500 MHz minimum
* 64 MO de mémoire vive
* Application serveur UPnP, par ex. Twonkyvision (recommandé)
* Microsoft Windows Media Connect pour données cryptées avec le système Windows Media DRM10
* Accès ADSL à Internet (nécessaire pour la radio par Internet)
Configuration requise Mac
* Macintosh a processeur PowerPC® G4 or G5
* Mac OS X 10.3
* Minimum 20 Mo despace libre sur le disque dur
* iTunes installé pour lire les fichiers audio
Logiciels fournis
* TwonkyMusic (PC)
* elgato EyeConnect (Mac)
* Outil de mise à jour et de configuration
Contenu du coffret
* Adaptateur audio WIFI NOXON 2 audio
* Câble audio RCA (1,8 m)
* Câble réseau RJ-45 (3 m)
* Télécommande IR (avec 2 piles AAA)
* CD de logiciels
* Manuel
* Carte d'enregistrement
* Bordereau d'accompagnement
Le boitier est de très bonne facture, look métallique sur les coté et plastique "ipod like" en hauteur. l'affichage est clair et le setup très bien fait. il m'a fallu moins de 3 minutes pour écouter mes premières radios ( il faut mettre à jour la DB des radios internet). Noxon utilise la DB du site http://www.radio567.com/ Il suffit de rentrer la MAC adresse du noxon pour personnaliser les profils voulus (genre musicaux ,....).
J'ai fait le test des radios internet (radio et podcast , depuis mon PC et mon lecteur mp3 ( creatvie v200 muvo 1Go) et pour l'instant tout fonctionne. J'utilise un routeur linksys WRT54gl avec du wpa.
Je ferais un petit update après une utilisation intensive .. pour l'instant, rien à dire!
Produits équivalents : http://www.son-video.com/Rayons/Hi [...] Audio.html
Voila ...
gizmo
Message édité par gizmo31 le 24-12-2007 à 14:16:33
