sort element [XSL] - XML/XSL - Programmation
Marsh Posté le 30-03-2005 à 08:41:01
voici mon probleme I have to "sort" an XML using the following XSL. This XSL gets rid of the node characteristic of type SETTINGSET. I was thinking to use xsl:sort. I found examples using values but none using nodes as criteria. I have to move up the parm element just before the node characteristic. current XSL <?xml version="1.0"?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"> <xsl utput method="xml" indent="yes"/> <xsl:template match="@*|node()"> <xsl:copy> <xsl:apply-templates select="@*|node()[not(@type='SETTINGSET')]"/> </xsl:copy> </xsl:template> </xsl:stylesheet> actual XML <characteristic type="PXLOGICAL"> <characteristic type="PORT"> <parm name="PORTNBR" value="8080"/> </characteristic> <characteristic type="PXPHYSICAL"> <parm name="PXADDR" value="131.111.3.4"/> <parm name="PXADDRTYPE" value="IPV4"/> <parm name="TO-NAPID" value="Browsing_GPRS"/> </characteristic> <parm name="PROXY-ID" value="PROXY1"/> <parm name="NAME" value="Proxy 1"/> </characteristic> Expected XML: <characteristic type="PXLOGICAL"> <parm name="PROXY-ID" value="PROXY1"/> <parm name="NAME" value="Proxy 1"/> <characteristic type="PORT"> <parm name="PORTNBR" value="8080"/> </characteristic> <characteristic type="PXPHYSICAL"> <parm name="PXADDR" value="131.111.3.4"/> <parm name="PXADDRTYPE" value="IPV4"/> <parm name="TO-NAPID" value="Browsing_GPRS"/> </characteristic> </characteristic>
voici mon probleme
current XSL
<xsl:copy>
</xsl:copy>
</xsl:template>
</xsl:stylesheet>
actual XML
</characteristic>
</characteristic>
</characteristic>
Expected XML:
</characteristic>
</characteristic>
</characteristic>
