pb de fichiers[access97-vba] - VB/VBA/VBS - Programmation
Marsh Posté le 03-06-2002 à 15:48:20
Essaie les macro suivantes...
Tu récupères la chaine dans une variable string
Dim strFileToOpen as String
strFileToOpen = Openit()
et ensuite tu peux utiliser
DoCmd.TransferText acImportDelim, "importation", "Import", strFileToOpen
Option Compare Database
'***************** Code Start **************
'Ce code fut originalement écrit par Ken Getz
'Il ne doit être ni altéré, ni distribué
'sauf comme partie intégrée à une application.
'Vous êtes libre d'utiliser ce code
'à la condition de laisser cette note, sans modification.
' Code courtesy of:
' Microsoft Access 95 How-To
' Ken Getz and Paul Litwin
' Waite Group Press, 1996
Type tagOPENFILENAME
lStructSize As Long
hwndOwner As Long
hInstance As Long
strFilter As String
strCustomFilter As String
nMaxCustFilter As Long
nFilterIndex As Long
strFile As String
nMaxFile As Long
strFileTitle As String
nMaxFileTitle As Long
strInitialDir As String
strTitle As String
Flags As Long
nFileOffset As Integer
nFileExtension As Integer
strDefExt As String
lCustData As Long
lpfnHook As Long
lpTemplateName As String
End Type
Declare Function aht_apiGetOpenFileName Lib "comdlg32.dll" _
Alias "GetOpenFileNameA" (OFN As tagOPENFILENAME) As Boolean
Declare Function aht_apiGetSaveFileName Lib "comdlg32.dll" _
Alias "GetSaveFileNameA" (OFN As tagOPENFILENAME) As Boolean
Declare Function CommDlgExtendedError Lib "comdlg32.dll" () As Long
Global Const ahtOFN_READONLY = &H1
Global Const ahtOFN_OVERWRITEPROMPT = &H2
Global Const ahtOFN_HIDEREADONLY = &H4
Global Const ahtOFN_NOCHANGEDIR = &H8
Global Const ahtOFN_SHOWHELP = &H10
' You won't use these.
'Global Const ahtOFN_ENABLEHOOK = &H20
'Global Const ahtOFN_ENABLETEMPLATE = &H40
'Global Const ahtOFN_ENABLETEMPLATEHANDLE = &H80
Global Const ahtOFN_NOVALIDATE = &H100
Global Const ahtOFN_ALLOWMULTISELECT = &H200
Global Const ahtOFN_EXTENSIONDIFFERENT = &H400
Global Const ahtOFN_PATHMUSTEXIST = &H800
Global Const ahtOFN_FILEMUSTEXIST = &H1000
Global Const ahtOFN_CREATEPROMPT = &H2000
Global Const ahtOFN_SHAREAWARE = &H4000
Global Const ahtOFN_NOREADONLYRETURN = &H8000
Global Const ahtOFN_NOTESTFILECREATE = &H10000
Global Const ahtOFN_NONETWORKBUTTON = &H20000
Global Const ahtOFN_NOLONGNAMES = &H40000
' New for Windows 95
Global Const ahtOFN_EXPLORER = &H80000
Global Const ahtOFN_NODEREFERENCELINKS = &H100000
Global Const ahtOFN_LONGNAMES = &H200000
Function Openit() As String
Dim strFilter As String
Dim lngFlags As Long
strFilter = ahtAddFilterItem(strFilter, "Excel File (*.xls)", "*.XLS" )
Openit = ahtCommonFileOpenSave(InitialDir:="G:\EIF-MIS\Bma\DOCS-Excel\G&E\Inclusions", _
Filter:=strFilter, FilterIndex:=3, Flags:=lngFlags, _
DialogTitle:="Select Excel File" )
' On a fourni les options dans lngFlags,
' la fonction y place donc les options en sortie.
' Debug.Print Hex(lngFlags)
End Function
Function GetOpenFile(Optional varDirectory As Variant, _
Optional varTitleForDialog As Variant) As Variant
' Un exemple pour obtenir une base de données Access.
Dim varFileName As Variant
' On désire que le fichier existe déjà,
' on ne veut pas changer de répertoire, en sortie
' et on n'affiche pas la mention "lecture seule"
' qui ne fait qu'embrouiller les gens
lngFlags = ahtOFN_FILEMUSTEXIST Or _
ahtOFN_HIDEREADONLY Or ahtOFN_NOCHANGEDIR
If IsMissing(varDirectory) Then
varDirectory = ""
End If
If IsMissing(varTitleForDialog) Then
varTitleForDialog = ""
End If
' Définir les filtres et utiliser "c"
' Copier cette ligne pour ajouter
' d'autres filtres.
strFilter = ahtAddFilterItem(strFilter, _
"Access (*.mdb)", "*.MDB;*.MDA" )
' Et maintenant, obtenir le nom du fichier.
varFileName = ahtCommonFileOpenSave( _
OpenFile:=True, _
InitialDir:=varDirectory, _
Filter:=strFilter, _
Flags:=lngFlags, _
DialogTitle:=varTitleForDialog)
If Not IsNull(varFileName) Then
varFileName = TrimNull(varFileName)
End If
GetOpenFile = varFileName
End Function
Function ahtCommonFileOpenSave( _
Optional ByRef Flags As Variant, _
Optional ByVal InitialDir As Variant, _
Optional ByVal Filter As Variant, _
Optional ByVal FilterIndex As Variant, _
Optional ByVal DefaultExt As Variant, _
Optional ByVal FileName As Variant, _
Optional ByVal DialogTitle As Variant, _
Optional ByVal hwnd As Variant, _
Optional ByVal OpenFile As Variant) As Variant
'Point d'entrée pour le contrôle commun
' "file open/save dialog". Les paramètres sont
' listés par après, et sont tous optionels.
' *In:
' Flags: un ou plusieurs constantes de ahtOFN_* constants, unie par des OR
' InitialDir: le répertoire présenté à l'usager
' Filter: une série de filtres pour les fichiers; utiliser
' AddFilterItem. Voir l'exemple.
' FilterIndex: Index, base 1, fournissant le filtre par défaut
' (1, si non spécifié)
' DefaultExt: Extension à utiliser si l'usager n'en entre pas.
' Seulement pour les sauvegardes.
' FileName: Valeur par défaut pour le nom du fichier.
' DialogTitle: Titre dans la barre titre du formulaire.
' hWnd: handle Win32 du parent de ce dialogue
' OpenFile: Booléen(True=Open File/False=Save As)
' *Out:
' Return Value: Soit Null, soit le nom choisi
Dim OFN As tagOPENFILENAME
Dim strFileName As String
Dim strFileTitle As String
Dim fResult As Boolean
' Fournir le caption (étiquette) du titre.
If IsMissing(InitialDir) Then InitialDir = CurDir
If IsMissing(Filter) Then Filter = ""
If IsMissing(FilterIndex) Then FilterIndex = 1
If IsMissing(Flags) Then Flags = 0&
If IsMissing(DefaultExt) Then DefaultExt = ""
If IsMissing(FileName) Then FileName = ""
If IsMissing(DialogTitle) Then DialogTitle = ""
If IsMissing(hwnd) Then hwnd = Application.hWndAccessApp
If IsMissing(OpenFile) Then OpenFile = True
' Créer une chaîne pour recevoir le résultat.
strFileName = Left(FileName & String(256, 0), 256)
strFileTitle = String(256, 0)
' Initialiser la structure avant d'appeler la fonction
With OFN
.lStructSize = Len(OFN)
.hwndOwner = hwnd
.strFilter = Filter
.nFilterIndex = FilterIndex
.strFile = strFileName
.nMaxFile = Len(strFileName)
.strFileTitle = strFileTitle
.nMaxFileTitle = Len(strFileTitle)
.strTitle = DialogTitle
.Flags = Flags
.strDefExt = DefaultExt
.strInitialDir = InitialDir
' On ne pense pas que quelqu'un veut vraiment utiliser
' ces options.
.hInstance = 0
.strCustomFilter = ""
.nMaxCustFilter = 0
.lpfnHook = 0
' Pour NT 4.0
.strCustomFilter = String(255, 0)
.nMaxCustFilter = 255
End With
' Transmettre la structure de données au
' Windows API qui, à son tour, affichera
' le formulaire "Open/Save As".
If OpenFile Then
fResult = aht_apiGetOpenFileName(OFN)
Else
fResult = aht_apiGetSaveFileName(OFN)
End If
' La fonction retourne le nom dans le membre strFileTitle
' de la structure. Il nous faut écrire du code pour
' retrouver ce qui nous intéresse.
If fResult Then
' Vous pouvez vérifier les membres de la structure
' pour obtenir plus d'information sur le fichier choisi.
' Dans cet exemple, si vous avez fourni un argument pour
' les options, on vous retourne les indicateurs (flags) dans
' cette même variable.
If Not IsMissing(Flags) Then Flags = OFN.Flags
ahtCommonFileOpenSave = TrimNull(OFN.strFile)
Else
ahtCommonFileOpenSave = vbNullString
End If
End Function
Function ahtAddFilterItem(strFilter As String, _
StrDescription As String, Optional varItem As Variant) As String
' Ajoute un nouvel ensemble de données formant un nouveau filtre.
' Par exemple, aux filtres existants, ajouter une description,
' (tel "Databases" ), un caractère null, la grille passe-partout
' (tel "*.mdb;*.mda" ) et un dernier caractère null.
If IsMissing(varItem) Then varItem = "*.*"
ahtAddFilterItem = strFilter & _
StrDescription & vbNullChar & _
varItem & vbNullChar
End Function
Private Function TrimNull(ByVal strItem As String) As String
Dim intPos As Integer
intPos = InStr(strItem, vbNullChar)
If intPos > 0 Then
TrimNull = Left(strItem, intPos - 1)
Else
TrimNull = strItem
End If
End Function
Marsh Posté le 03-06-2002 à 15:56:40
Tu connais une autre méthode pour récupérer un fichier avec une boite de dialogue Open ?
Marsh Posté le 03-06-2002 à 18:25:27
Pas compliqué : tu copies/colles les fonctions dans un module de ta base Access.
Pas la peine de comprendre tout ce bordel. La seule chose à retenir, c'est que tu vas avoir une fonction openit() qui quand tu l'appelleras ouvriras une boite de dialogue standard windows te permettant de choisir un fichier. La fonction te retournera le chemin complet du fichier que tu as selectionné.
Si tu veux l'essayer, créé une nouvelle base Access, copie tout le bordel dans un module. Met un bouton dans un form qui lance la macro suivante :
Sub Test()
msgbox openit()
end test
Tu verras le résultat...
Marsh Posté le 04-06-2002 à 09:11:00
| latruffe a écrit a écrit : Pas compliqué : tu copies/colles les fonctions dans un module de ta base Access. Pas la peine de comprendre tout ce bordel. La seule chose à retenir, c'est que tu vas avoir une fonction openit() qui quand tu l'appelleras ouvriras une boite de dialogue standard windows te permettant de choisir un fichier. La fonction te retournera le chemin complet du fichier que tu as selectionné. Si tu veux l'essayer, créé une nouvelle base Access, copie tout le bordel dans un module. Met un bouton dans un form qui lance la macro suivante : Sub Test() msgbox openit() end test Tu verras le résultat... |
ben c cool, ça marche bien !!
merci bcp
Marsh Posté le 03-06-2002 à 14:39:33
voila le pb :
comment faire pour ouvrir un fichier *.txt ?(et faire une importation avec)
si on peut l'ouvrir avec une boite de dialogue, il va y avoir un autre pb car je dois importer des fichiers grace à cette commande :
DoCmd.TransferText acImportDelim, "importation", "Import", "c:\mes documents\bd\180302tit1.txt"
Et comme vous le voir, cette commande necessite 1 chemin d'accès spécifié(ici c:\mesdocuments\bd....)
mais les fichiers à importer ne seront pas toujours les mêmes, alors...
j'espère avoir été clair
merci de toute aide
